Question about Amana NGD5200TQ Dryer
Dryer does not heat
Ran fine last night.
  • 3 Answers
Your heating element has gone bad, it needs replaced
Posted on Feb 22, 2012
Hello,I just picked an electric ROPER dryer last night.I assembled it plugged it in and it worked fine.This morning I put a small load of laundry in it and it worked fine.I then put in a second load and...
The most likely part that has gone out is the thermal fuse. What will make that go out so quickly is a blocked vent causing excessive heat build in dryer. Did the dryer that this new one replaced havea similar problem of not starting or perhaps it ran but took forever to dry a load of clothing? if that was the case the venting caused the problem with both old and new dryer
Good luck
I hope this helps,if it does please give me a 4 thumbs up rating
Gene
Jul 30, 2011 | Roper Dryers
No heat, I have verified 220 service both breakers are not tripping, 220 plug gets current. No obstruction in vent also ran without vent pipe attached I did notice last night sensor dyer level light...
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
May 03, 2011 | Maytag MDE9700AYM Electric Dryer
Not drying - indicator show AF
you might need to replace the heating element
Sep 05, 2009 | Dryers
My dryer was working fine last night, then today, no heat. The vent is cleaned, nothing in there...heating element?
Heating element maybe not likely.
Probably thermal switch overheat protection tripped.
Try putting in lower heat mode (touch up or permanent press) see if you get heat.
Some thermal switches can be reset most have to be replaced. $20.00 to $45.00 Plus labor $??.?? to $???.??
Hope this helped. need more help MSG Back. Please rate. Good Luck!
Mar 12, 2009 | Whirlpool LEQ9858P Electric Dryer
GE Electric Dryer Heats up but does not automatically turn off
Change the sensor in the drum. Theres a sensor that tells it if there is moister in the enclosure.
Feb 12, 2009 | GE DBXR463GB Gas Dryer
Whirlpool electric dryer ran all night and won't heat
Yes it will heat. The two are normally not dependent on the other. The element could be bad. Check the breaker first, then the connections in the back, then the element. The timer could be bad itself allowing it to run all night. This could be a blessing in disguise as the clothes would have been damanged possibly from all the excess heat.
Dec 26, 2008 | Whirlpool LER4634J Electric Dryer
NO HEAT
CK IF YOU HAVE 220V COMMING IN OR THE HEATING ELEMENT IS GOOD. OR CK THE THM FUSE.IS NO GOOD. BUT IF DRYER RAN OVER NIGHT AND DIDNOT TRUN OFF YOU HAVE TIMER PROBLUM. THE DRYER SHULD TRUN OFF EVEN YOU HAVE HEAT IN THE DRYER OR NOT.
May 03, 2008 | Roper REX4634KQ Electric Dryer
Kenmore gas dryer
lots of people point the finger at the dryer when they have a problem you could have bad thermal cutoffs on the back of the flame tube BUT is your washer spinning properly to remove the majorityof water from the clothes
Jan 02, 2008 | Kenmore 75944 Gas Dryer
Doesn't Heat
replace magnetron, check highvoltage related circuit.
Nov 06, 2007 | Sunbeam SMW777 Microwave Oven
Amana NGD5200TQ Dryer Logo
Top Amana Dryers Experts
Tim Whalen
Sal De
Are you an Amana Dryer Expert? Answer questions, earn points and help others
