Question about Canon imageRUNNER C3220 Color Copier
How do I print to tab paper on Canon imageRUNNER C3220
I want to print tabs using 5th cut tab stock. What are the settings I need to program the printer/file.
MSR
  • 35 Answers
Tab stock is not supported on this model. See the Media Guide.
http://opd.usa.canon.com/html/consumables/pdf/consum_iR_CiR_CLC_iP.pdf
Posted on Nov 09, 2008
Our canon C3220 is not printing from one of the computers in the office. It is putting all print jobs on hold due to authentication required
Auth Required sounds odd. The only thing i could think would cause this is if the copier itself has Department Managment enabled. This is used to limit printing by quanity and sometimes restricting color prints. IF everyone else in the office is required to enter a code to print and this one does not then you need to enable department ID via the driver settings. Right Click your print driver and go to properties and select "Device Settings" from the tabs on the top of the window. Under this menu there should be a box that says Department ID select that and try it out. Another way is to "aquire" the copiers device status a button labeled somewhat to this effect should also be in that same window.3_15_2012_4_29_14_am.jpg
Mar 13, 2012 | Canon imageRUNNER C3220 Color Copier
How can you print the Configuration Page on a Canon 3220? We are trying to find out what the IP address of the printer is.
For a Canon C3220:
- Choose the Printer tab on the touch screen - Under Printer Status, go to Settings - Go to Functions - Go to Print Pages - Select Configuration
The configuration page will print out. Thanks for using FixYa!
For configuration page instructions on other copiers, printers, and fax machines, check out the How to print config pages blog.
May 03, 2011 | Canon imageRUNNER C3220 Color Copier
Large paper printing
12 x 18 is the largest size paper that can be used on this copier. If anything larger is used the machine will jam. The copier uses a series of paper sensors to track and time the paper throughout the printing process. The max is 18 inches anything over that cuase the machine to jam.
Apr 14, 2010 | Canon imageRUNNER C3220 Color Copier
When printing in color on a canon c3220, images have 'ghosts' or shadows
try to check your paper cassette setting and try to use user mode * select " auto adjustment / cleaning to fix the problem.
Jan 24, 2010 | Canon imageRUNNER C3220 Color Copier
Hello, I am in Brazil, and my Canon ImageRUNNER C3220, is the problem of off alone, just off the digital display but not print anything when it is so, the technicians who were found not fix the problem,...
If the printer appears as offline in windows, consider disabling SNMP monitoring. Sometimes SNMP falsely tells windows that the printer is offline for events like "toner low, replacement not needed" and "low paper, drawer x"
Go into printers & faxes, right click on your printer and select properties, go to the ports tab, press configure port, un-check SNMP Status enabled.
Mar 03, 2009 | Canon imageRUNNER C3220 Printer
Input IP address on IR C3220 with ImagePass-C2
go to printer tab then function then print pages then configuration page. and you'll see the ip address
Feb 11, 2009 | Canon imageRUNNER C3220 Printer
Canon Color ImageRunner - Tab Instructions
To be able to print using tab paper from the driver
Since the tab paper can only be fed from Stack Bypass, single reverse tab paper cannot be
used. The tab paper must be single forward.
1. Go to the printer and put some tab paper in Stack Bypass
2. Press Letter on C3200 LCD panel and press Next
3. Select Tab paper and press Done
4. Go to Windows Start menu and choose Settings
5. Open Printers folder
6. Select Canon iR C3200 PS3’s Properties
7. Click on Device Settings tab
8. Click on Form to Tray Assignment button
9. Making sure that Stack Bypass is highlighted and Paper Size is Letter, select
Tab Paper by scrolling down the Paper Type list
Page 2
Hint:
In order to print to Tab paper, it is necessary to select Tab Paper in the Form to Tray
Assignment dialog box before using this option. Otherwise, the option of printing to Tab paper
is not available from the print driver.
10. Click OK to close Form to Tray Assignment
11. Click OK to close Properties window
12. Open Word document called “tabs.doc”
13. Go to File menu and select “Print…”, and change the current printer to Canon
iR C3200 PS3.
14. Click on Properties
15. Click on Paper Source tab.
16. Select Paper Type option
17. Choose Tab Paper from Paper Type list. As soon as you select “Tab Paper”,
Conflict Information dialog will appear. Click on OK.
Page 3
Hint:
In order to change the tab position, click on Tab Position button. Clicking this button opens a
dialog box for specifying the width for shifting the image data to be printed on the tab part of
the paper.
Hint:
The conflict information displayed pertains to the finishing of the document. Tab paper must
be grouped, not collated. Since the default value for finishing is Collate, the driver
automatically adjusted the finishing option to resolve the conflict.
18. Click on OK to close the Properties window.
19. Click on OK to print the tab paper.
20. Go retrieve your output.
Note:
Please note that this procedure for printing on tab paper is not the same for all drivers. CCD
drivers would be similar to this procedure, but depending on the OS Platform, exact buttons
and steps would vary. However, from such drivers as imagePASS-C1 PS and Macintosh drivers
would work completely different from this procedure. Although we will not cover each
procedure step by step, we encourage you to take time to make yourself familiar with the
procedures.
Sep 30, 2008 | Canon imageRUNNER C3200 Color Printer
Canon Color Imagerunner c3220
Go to the Printer Tab, select Printer Status/Settings, select Functions, go to page 2, select Run Setup, select Yes, and then you're in like Flynn.
Sep 03, 2008 | Canon imageRUNNER C3220 Printer
Printing 5 tab index paper from a Word template
does this printer support this size of paper in paper size menu most printers of this type dont be sure this is possible with this machine because you mentioned the they have tabs you could get some serious paper jams with media this small i would try this operation on a small inkjet printer before trying it on this unit thus causing other problems especially with cardstock this thick
Jan 11, 2008 | Canon imageRUNNER C3220 Color Copier
Canon imageRUNNER C3220 Color Copier Logo
490 people viewed this question
old marine
old marine
