2006 Harley Davidson FXDWGI Dyna Wide Glide Logo
Posted on Feb 22, 2012
What are the torque specs foe the caliber bolts,the wheel bolts,the tree bolts,fork caps,and bottom fork bolts for an 2009 dyan wide glide
5 Related Answers
Anonymous
  • 4565 Answers
  • Posted on Nov 08, 2009
SOURCE: 97 fxdl, difference between narrow/wide glide componants
You need the complete front end including the wheel. The FXDWG is somewhat of an oddball in that a lot of parts fit only that bike. A lot of other parts will not fit a Wide Glide. This even applies to the exhaust system.
Measure the diameter of your upper fork tubes, they're 39 mm tubes. The Wide Glide uses 41 mm tubes. The Wide Glide also uses a 21" front wheel.
Anonymous
  • 150 Answers
  • Posted on Jul 25, 2009
SOURCE: need the torques specs for the 2 nuts on the clutch on a harley
50 ft lbs and it is a left is tight nut...don't worry about adjuster nut on clutch just good ole tight will work on that one. compensating nut ( one in front) is 150 ft lbs.
m22loud
  • 136 Answers
  • Posted on Oct 18, 2009
SOURCE: what is the fork size on 06 1200c want to know if
should be 39mm dia forks , fxr parts is what your looking for second hand ,or in kit form harley list it i there cat (expencive) jp cycles, us. cheaper alternative. you wil also need wheel spacers , disc spacer and longer wheel axel.
email me and i can list all the part num you need, [email protected]
Anonymous
  • 155 Answers
  • Posted on Mar 28, 2010
SOURCE: what size is the upper front fork on a stcok 2000 dyna
35 mm
Anonymous
  • 4565 Answers
  • Posted on Jun 12, 2011
SOURCE: I have a 2006 Harley
You didn't say which Dyna series bike you have but I'm going to say that Sportster specs are not the same as for a Dyna. If you think you have a gap between your triple tree and the steering head of the bike, something may not be assembled correctly. I'd take to a shop or a dealer and have them check the front end.
Good Luck
Steve
2answers
2005 Harley Davidson FXDWG Dyna Wide Glide front fork spring replacement @
Hi, Anonymous for this scenario you will need your service manual that has all fastener torque specs -fluid capacities and a wiring diagram on the back pages, parts fiche, and owners manual if you can not find the best tool you ever bought for your Harley, despair not, for a mere zero $0 you can download another one.
For more information about your issue and valuable "FREE" downloads that you will need for viewing or printing please click on
the blue links below and for more specific information or questions at no charge please feel free to contact me at [email protected]. Good luck and have a wonderful day.
https://www.youtube.com/watch?v=6ofwhtMLcrA
http://www.mediafire.com/file/6cp9fbatnw1z4di/2005+Harley+Dyna+Service+Manual.pdf
https://partsfinder.onlinemicrofiche.com/ronnies/showmodel.asp?make=hdmc
https://ownersmanuals2.com/harley-davidson/dyna-wide-glide-2005-owners-manual-66390
https://www.6ya.com/ to speak to me personally
How much trouble is it to change front fork seals on a 2000 wide glide and do you have instructions on it?
If, notice I said "if", your bike has the standard 41mm wide glide front end, changing the fork seals is not that difficult.
Get the bike up off the ground on a stable lift. Safety is paramount.
Now take the front wheel and fender off. Take the large "Bolt" out of one of the fork tubes at the upper triple tree. There are special sockets made to do this with so that you won't scratch your chrome upper tree. Loosen the pinch bolt on the lower triple tree. Put some lubricant on the fork tube and work it down and out of the triple trees. You may have to spead the lower triple tree by driving a chisel into the slot from the bottom side.
Once you have one of the fork tubes out. Remove the plug at the top. There will be a large spring under the plug. Usually it doesn't have much pressure on it with the tube fully extended and if it's the stock spring. With the plug and the spring out, you can pour the oil out of the tube. Notice which direction the spring comes out of the tube. I must go back in with the tapered end down.
Look on the bottom of the tube where the axle goes through. You'll see an allen head or socket head bolt in there. It' should be an 8mm sized bolt but it takes a "piloted" hex key. Now, you can use a standard hex key but it must be in new condition since the bolt head is so shallow. I have found that a hex key socket used with an air wrench is best to get the screw out. With the screw, you can now seperate the upper fork tube from the lower slider.
Remove the retainer ring in the top of the slider and pry out the old seal. Install the new seal in the proper direction. Reassemble the fork assembly. Now, add the proper amount of oil to the tube before you install the upper plug. The forks take 10.2 to 11.2 ounces of oil each. The lower figure is for a "Wet" refill and the higher number is for a "Dry" refill. If you take your fork tube apart and pour out all the oil, use the "dry" figure of 11.2 ounces type "E" or 30 weight fork oil. If the forks are too stiff with this oil, drop back to 20 weight fork oil.
Good Luck
Steve
Fork needs charging how do I go about it?I need to put new seals and fluid in the left side fork. How do I go about it?
Start by lifting the bike off the ground and making sure it is steady and won't fall over. Remove the front wheel and front fender. Make sure you keep up with where each spacer goes.
Loosen the clamp bolt in the lower triple tree. Take the large "nut" off the top of the fork tube at the upper triple tree. At this point, the fork leg should start to slide downward out of the triple trees. But, most of the time they won't. Take a small chisel and locate the slot on the lower triple tree. Drive the chisel into the slot from beneath to spread the clamp. Make sure the clamp bolt is all the way out or at least very loose to allow the triple tree to expand. You can use a brass drift to help drive the fork leg down from the top. Use plenty of oil to help it slide.
Once you have the fork leg out, you can drain the fluid by either removing the drain plug on the lower slider and pumping the fluid out or simply take the top cap out of the tube. When you take the top cap out of the tube, the large sping in the tube will push the cap up. I don't think it will be too strong to get back in. On the earlier models, they weren't. With the top cap off, take the spring out and pour the old fluid out. Look at the lower slider where the axle goes through, you'll see a hex head bolt. Use an 8mm hex key to remove the bolt. This is a special piloted key. You can use a regular hex key but it must be in very good shape. I'd recommend using one with an air wrench. Once you get the bolt out, simply pull the upper tube out of the lower slider.
Replace the seal in the lower slider and reassemble in reverse order. Make sure you install the large spring with the tapered end down. Refill with the appropiate amount of fluid for a "dry" fork tube. I used 30 weight fluid in mine but that may be too stiff for you. If so, 20 weight is the next common. Honda may have a 25 weight fluid. Honda has some wierd fork oil weights.
Good Luck
Steve
3helpful
My front fork o-ring seal is leaking, how do I
There is a seal in the "slider" of the front fork, the part that moves up and down. I haven't had a chance to work on the later forks but the earlier 41mm forks are quite simple.
Start by taking the drain plug out of the bottom of the slider and work the slider up and down to blow out all the oil. Then, remove the front wheel. Remove the top cap from the upper tube and loosen the top plug. Now, with the top plug loose, loosen the pinch bolts and slide the fork out of the triple trees. Remove the top plug carefully, There is a BIG spring in there. Once you have the plug out lift the spring out and set it asside. Notice the tapered end of the spring. It goes back in first. Turn fork tube upside down and allow as much oil to drain out as possible.
Now, look at the bottom of the slider where the axle goes. Up in a hole there is an allen head bolt. it is designed to use a special wrench but a regular 8mm allen key in GOOD shape will take the bolt out. It's best to use an air wrench to do this with. With the bolt out, the slider should slide right off.
Down inside the top part of the slider is where the seal is. Theres a snap ring, a spacer, and a seal. Replace the seal and put a little oil on it to assist reassembly. Put everything thing back together and add the appropiate about of oil. Since your forks are much larger than mine, I have no specs as to the quantity. The owners manual should tell you or a call to a local Harley dealer. Sorry but thats a good as I can do. There is a "wet" measurement and a "dry" measurement. Since you disassembled your fork, use the "dry" quantity of oil
Need torque specs for the triple tree bolts holding the fork tubes top and bottom. 2009 Honda VTX 1300 C
20 nm on all of them this may not seem alot but the clamps bend over the forks and clamp onto them many thanks buddy
Torque spec. for shocks
use 2-3 drops loctite 242 (blue) to threads of bottom bolt and torque to 25-40 lbs.
Same with the lower stud .....
happy trails
Top Harley Davidson Experts
Arnie Burke
Arnie Burke
Sean Wright
Sean Wright
ZJ Limited
ZJ Limited
Are you a Harley Davidson Expert? Answer questions, earn points and help others
