SOURCE: 2005 scion xb Stereo problem
If the Stereo Got wet, The first thing that will stop is the Internal Amplifier. On these Pioneer Stereo's the Only thing that You can do is Replace the Head Unit. Please Rate My Response! Thanks!
SOURCE: Replace front speakers
its actually pretty easy. just remove the screws on the door panel. dont forget the one in the handle at the bottom. then remove the little triangle cover behind the mirror on the door. lightly pull from the bottom and the door panels pop clips will slowly come undone....once the door panel swings outwards pretty easily just lift up on the panel and it will come off....once its undone you can either remove the harness for the window switches and lock or just let the panel sit to the side still attached. either way works its just preference. then you just remove the speaker and replace with any 6.5inch you would like... reinstallation is the same..
SOURCE: need help to remove 2005 Scion xB water pump
1st ...that should be covered under 6 year 50k power train warranty from the dealer.
But if your over....you need to unbolt the right side motor mount (on the water pump side) and lift the engine some with a floor jack to get clearance,
SOURCE: Remove 08 Scion XB Navigation
The trim around the stereo and center vents pulls straight out. It is held in by plastic reusable clips. No tools needed.
SOURCE: How do I install alt. belt on 2005 scion xb?
I just looked at my '04 xB. It looks very straight forward.
loosen the bolt that holds the alternator to the bracket.
carefully slide the alt to the bottom. (Also be aware of the plug and wires on the alt.They should never hold the weight of the alternator. You dont want them breaking prematurely.)
Pull the belt off, remove the belt from the crank shaft pulley.
Do the reverse, and you will have replaced the belt.
Make sure to check the belt in about a week or so.
New belts will stretch over time. Make sure you keep the tension tight enough to work correctly, but not so tight that the alernator shaft is warped.
I usually place the new belt on both pulleys and give a good "medium" pull on the alt while tightening. Find the middle of the belt and squeeze them together, depending on the type and length of the belt, there should be about 1/4" of flex on both sides.
