Question about Honda Karcher G2400HH-R Pressure Washer
Karcher 3600 gx390 backfires - Honda Karcher G2400HH-R Pressure Washer
    Novelist:
  • 97 Answers
Usually this (back-fire/after-fire) happens because of a dirty carburetor, or bad gas. Gas can go bad with age or it can be bad because of water from condensate. I'm not familiar with this particular engine, but if it more than 1 spark plug, a fouled-out plug can also be the culprit. If you clean your carburetor, I suggest just using a bit of gas to soak it and brush it etc. That carburetor cleaner is rough stuff and it will burn you badly. I don't use it unless I've got a stubborn one. Hope this helps.
Posted on Feb 22, 2012
Why does my gx390 13hp backfire through carburetor when trying to start
it is too rich mix or timing is too much forward.
filter change was correct procedure, check valve if it is closing.
Feb 12, 2015 | Garden
Flywheel key probably sheared allowing to much spark advance.
How do you change a rupture disk for karcher 3600 4.0 GPM
try putting a plug and then try again if you hear the pump not unloading when u release the trigger then the new rupture disk would rupture due to a faulty unloader you can use a pressure relief valve for a better replacement.let me know 30 years exp,
Jul 28, 2013 | Karcher HEX HD SCREW 1/4-20x1.25
Backfire when turning off
let it idle down after using it then shut it off the carb could be leaking a little with the bad fuel we get only lasting 30days i always turn off the gas and run the gas out of the carb
Aug 15, 2012 | Karcher 2500 PSI Pressure Washer
Brand new gx390 Black Max generator backfires when shut down. Might this be plug gap problem?
If you can access throttle linkage to the carburetor, slow the engine speed to idle before turning off. As mentioned in the previous answer ... turning off the fuel valve and letting it run dry is good if you are not planning to use it real soon.
Aug 11, 2011 | Honda Electrical Supplies
Honda Karcher G2400HH-R Pressure Washer Logo
332 people viewed this question
Top Honda Garden Experts
John Trevino
JOHN LAPIER
Are you a Honda Garden Expert? Answer questions, earn points and help others
