Question about Sony KP-61V75 61" Rear Projection Television
No Audio on Primary Screen
I've confirmed that "mute" is not on, but I am still not getting audio on my TV. However, if I put on the picture-in-picture and switch audio to the secondary/small picture, I do get audio. If I then switch the secondary/small picture to be the primary, the audio is again lost. I'm totally confused! What is the difference between the audio for the primary and secondary pictures? I am assuming that this will help me track down the problem. Thanks!
    Scholar:
  • 167 Answers
HELLO . WELL THE DIFFRENCE BETWEEN THEM IS THAT THEY ARE TUNER'S AND THEY ARE SEPRATE FROM EACH OTHER.!!! JUST LIKE THE VHS TUNER'S YOU HAVE .!!! THERE IS THE PRIMARY WITCH .!!! WOULD BE (A) AND THEN THE SECONDARY WITCH WOULD BE (B) IT SOUND'S LIKE YOU NEED TO REPLACE THE AUDIO BOARD. OR THE (IC'S) ON THE BOARD. IT WOULD BE CHEPER TO DO. IF YOU KNOW HOW.? " WELL "GOOD LUCK"
Posted on Jul 30, 2008
No audio sound & tv is not on mute
If you have not already confirmed, check the settings for external speakers is set to internal or similar.
Dec 16, 2014 | ViewSonic Televison & Video
No sound is coming out of my tv
Check whether mute function is on or not. Enter its sound menu and check it. If it is not off there, the fault is with its audio processor section, mute section, or audio output section. To make it confirm, your set need a through checkup. Contact any experienced service technician.
Feb 15, 2013 | RCA Televison & Video
No audio input from TV on DVD Home Theatre
U have audio signal incompatibility. If the audio output is digital it may not work with an analog input, etc.
May 08, 2017 | Audio Players & Recorders
I have a Samsung LE40B650T2 - no sound direct from the TV
It sounds that the sound processing section [digital circuts] are working well, and the fault must be either to the speakers, settings or to analogue audio amplifier section. Make sure that the Mute function is OFF. If it is OFF, and still you do not get audio output by tV speakers, surely the fault must be to audio amplifier circuits, provided speakers are OK. If your TV has a headphone out socket, this socket should also checked for proper interconnection.
Jun 24, 2012 | Samsung LE40B650T2 40 in. Full HD Crystal...
No audio on Sceptre TV
I think that you missed to check its speakers. Check it. If they are found OK, the audio output section circuit should be troubleshooted.
Jun 11, 2012 | Sceptre X46BV TV
I have a Vx2433WM and am using it as a tv for my PS3 through hdmi connection. The audio stopped working. I tried muting and un-muting but nothings happening. How do I get my audio back??
Welcome to Fixya. If the volume is not working on the monitor the next thing you need to check is the HDMI cable. If possible to replace the cable so that we can determine the problem if this is caused by the cable, the monitor or the PS3. You can also try to connect the PS3 to a different TV using the same cable and see if you will hear a sound. Please let me know what happen so that we can continue troubleshooting.
Thanks
Sep 28, 2011 | ViewSonic VX2433WM 23.6" Monitor
Can't get tv audio through my Philips HTS3510.
Here is the user manual and quick start guide:
http://www.p4c.philips.com/cgi-bin/dcbint/cpindex.pl?slg=en&scy=ph&ctn=HTS3510/98
Be sure your connections are correct.
Press AUDIO SOURCE repeatedly to select
the audio output of the connected device (TV)
There could be audio settings on your TV which you can select only Internal or only external speakers or both. Be sure the setting is correct on your TV.
Be sure your TV and your HTS3510 are not set to "mute"... Don't laugh... I've done it before...
Jun 09, 2011 | Philips Televison & Video
I have a Sharp LC37D43U TV that has no audio. The volume indicator shows can be moved up or down but no sound comes through the speakers. The picture works fine. I have nothing else connected to the TV....
It appears you ve discovered the sound task levers required to adjustment properties. Your Tv can still move levers even when the volume is set to mute. Select the unmute button before any voice or audio would be reactivated. Assuming that seting the TV on mute has predominant integrety over the volume functions where not unmuting usually with the same button on the remote would not achieve accessibility to the volume functions. refer to the TV user guide for diagnostic audios. Good luck
Jan 09, 2011 | Sharp Televison & Video
My view sonic monitor has no sound
Troubleshooting Sound Issues Verify that the audio cable is connected to the AUDIO OUT or LINE OUT output on the Sound Card and plugged into the AUDIO IN or LINE IN of the Monitor.   Make sure there are no cables connected to the Headphone Jack (located next to the AUDIO IN port) on the monitor. If there is, please disconnect that cable and try the speakers again. Connecting a cable to the Headphone Jack disables the speakers. If there is no cable connected into the Headphone Jack, test a pair of headphones into that jack to see if you can hear sound out of the headphones. If you are able to hear sound out of the headphones, disconnect the headphones and try the speakers again.   Verify that the Mute on the monitor is not on or the Volume is not turned down.    Verify that the Mute on the computer is not on or the Volume is not turned down.<    If there is still no audio from the monitor's speakers, connect the Audio cable to another audio source like a portable CD player or tape player headphone output. If audio can be heard through the monitor's speakers, then there may be an issue with the computers sound card.    Connect another set of computer speakers (if available) or headphones to the AUDIO OUT or LINE OUT output on the Sound Card. If NO audio can be heard then there is an issue with the sound card. Verify with the computer's manufacturer for additional assistance.   LCD TVs Troubleshooting No Sound from a LCD TV No Sound when using RGB (when connected to a PC) Confirm the audio cable is plugged into the Audio in on the LCD TV and the audio out on the computer. Note: On the N1700W use the GREEN mini-jack; on this model Audio is SHARED between DVI and RGB, there is only 1 audio channel for data connections. The N1700w is designed to take a 1.0v RMS audio signal for optimal sound quality.   Confirm that both the LCD TV Mute and Windows Mute are off. A general message will be displayed on screen to indicate status of Mute (On or Off).   Press the Volume Up Button on the monitor or remote to confirm the Volume is not set to zero.   Confirm that PC volume is sufficient by using Windows/Macintosh Volume adjustment settings.   Try plugging another audio source such as a CD or Cassette Player directly into the Audio port on the LCD TV to confirm the speakers work, or try plugging headphones or external speakers into the sound card on the Computer. If the Headphones or External Speakers do not work, contact the manufacturer of your Computer for further support. No Sound when using S-Video/Composite/ Component Video Confirm the audio cable is plugged into the Audio in on the LCD TV and the audio out on the S-Video, Composite, or Component Video device.   Confirm Mute is off. A general message will be displayed on screen to indicate status of Mute (On or Off).   Press the Volume Up Button on the LCD TV or Remote to confirm the Volume is not set to zero.   Try plugging headphones or external speakers into the audio port on the S-Video, Composite, or Component Video device. If the Headphones or External Speakers do not work, contact the manufacturer of your S-Video, Composite, or Component Video device.   Note: Some ViewSonic monitors do not include speakers.
Nov 23, 2010 | ViewSonic E70f 17" CRT Monitor
Volume on tv is locked volume wont go up or down and not even able to put on mute
Go to Menu from remote.
Select "Audio" and confirm "Internal" speakers vs. "External". Internal is the built in speaker sna external is when you are using a surround sound or reciever for audio.
Check this and follow up.
Jun 29, 2010 | Sony Bravia KDL-46V4100 46 in. LCD HDTV
Televison & Video Logo
77 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
