Question about Dyson DC14 Animal Bagless Upright Cyclonic Vacuum
The clip or latch that holds the Motor Inlet Cover of my Dyson DC14 is broken. Any way to fix this? It appears attached to the large body of the vacuum.
  • Official Brand Answer
  • 2,572 Answers
I'm sorry to hear the catch has broken on your DC14. Our Helpline should be able to assist you in resolving this - please give us a call free on 0800 298 0298 (UK), or 1-866-693-9766 (US). It will help if you have the machine to hand when you call.
We'll look forward to hearing from you.
Best wishes,
Jack
Dyson Online Customer Support
http://www.dyson.com
Posted on Feb 22, 2012
  • 107 Answers
SOURCE: Dyson DC14 hose attachment
hose should work as is. you just remove the handle from the main unit and **** away. Manuals are available at dyson.com.
Posted on Dec 08, 2008
SOURCE: Dyson dc14 power button
I tried this and it fixed my problem. 10 minutes later...the Dyson was up and running again.
Posted on Dec 19, 2008
SparkyNZ
  • 43 Answers
SOURCE: no suction at sweeper on dyson dc14
that suggests that there is a blockage in the vacuum head. i would advise you do what you can to clean the head as best as possible and any tubing that is integral to the sweeper head.
Posted on May 16, 2009
SOURCE: My dyson dc14 suddenly stopped working while
Check mains fuse, if OK, suspect mains cable broken where it enters the machine. Wriggle the cable with the machine switched on.
If it's done a lot of work, the motor brushes could be worn out.
Posted on Jul 31, 2009
  • 3 Answers
SOURCE: Dyson DC14 Brush Bar won't turn
You don't need to take it for repairs, I just corrected the same problem on the phone with a tech. Have the head on your lap, make sure the end nearest the little belt has the rounded side of the bar facing you. The squared off end faces towards the machine. Place your left hand pointy finger under the bar (the 2 inch bar next to the little belt) and lift up, while finessing the loose end of the bar into place, with the rounded part still facing you. Then it sort of snaps into place. Now, replace the face plate. In the upright mode, starting at the carpet dial, switch the dial back and forth between carpet and bare floor, ten times. (the tech actually referred to this as re-setting the vac. LOL) Plug the vac in, incline the hand, and start. It should work. It didn't for me the first time and made a horrible sound. That meant I had to go and repeat the process again, but lo and behold, IT WORKED! When in doubt, call the tech and don't let them get away from you; have them stay on the line until the problem is resolved.
Posted on Oct 10, 2009
How do I FIX MY DYSON DC14 VACUUM
Hi there, it's Jack at Dyson.
I'm sorry to hear you're having difficulty with your DC14 - it sounds like this spring may have come out of the clip which secures the Telescope Reach wand in place. Normally the spring will locate behind the clip, keeping the wand locked securely onto the main body of the vacuum until you remove it for above-floor cleaning.
We'd be happy to talk you through replacing the spring - if you have further difficulty in doing this, you would also be able to order a replacement wand if needed.
When you have your DC14 easily to hand, please give the Dyson Customer Helpline a call on 0800 298 0298 (UK), 1-866-693-9766 (US), 1-877-397-6622 (CA) or 1800 239 766 (AU).
We'll look forward to speaking with you.
Mar 13, 2015 | Dyson Vacuums
Troubleshooting dyson dc01 upright hoover
If you are referring to the bearing cover on the wheel, this appears to be purely cosmetic. The disc is clipped onto the wheel and can easily be replaced IF you have not broken off the latches.
Aug 19, 2014 | Dyson Vacuums
Dyson hose is broken how do I replace it
The colored pieces on the vacuum are latches. You can remove most parts. For the hose, you may have to remove the cannister to get to the latch through a hole in the main upright part of the vacuum. You can find parts with a search of the Internet. You will have to get the hose with both ends attached, but one source has it for $21.95.
Oct 20, 2013 | Dyson DC14 Animal Bagless Upright Cyclonic...
The catch fell off the motor inlet cover on my new Dyson DC14. How do I replace it?
I'm sorry to hear about this, but if you get in touch with us directly, we should be able to help. Please call us free on 08002980298 (UK), or 1866MYDYSON (US) so we can resolve this for you as quickly as possible. We'll look forward to hearing from you.
Kind regards,
Jack
Oct 23, 2011 | Dyson DC14 All floors Bagless Upright...
Where does the catch go on a dyson dc24 motor inlet cover?
Hi Philippa,
Apologies for our delayed response. It appears your inquiry was submitted sometime ago, and hopefully you have been able to resolve the issue in the meantime. However, if you need assistance regarding your motor inlet cover, we recommend you call us directly at 1-866-693-9766 (US) or 0800 298 0298 (UK).
Best wishes,
Jessica
Oct 23, 2011 | Dyson DC14 Animal Bagless Upright Cyclonic...
Have a DC25, I can not return the handle to the upright position. Nothing appears to be broken
Occasionally, customers have problems locking their Dyson vacuum in the upright position. This is a minor problem common with the Dyson DC07 and DC14 series and can easily be fixed by the customer. This page will show how to fix this problem. Although we show a Dyson DC14 Animal on this page, these instructions will work on any Dyson vacuum in the DC07 and DC14 series.
During shipping, moving parts on a Dyson vacuum can shift in position. One of these parts is a swinging arm in the base of the unit. This arm holds a removable elbow pipe in the vacuum's air passage. This arm can move out of the way so that you can clear out a blockage in the air passage. When this arm is out of position, the vacuum will not lock in the upright position. Fig. 1 Shows the base of a Dyson DC14 Animal locked upright. The red arrow points to the swinging arm. Fig. 2 shows the vacuum with the swing arm out of position. Since the swing arm is lower than it should be, it doesn't line up with the tab on the main body indicated by the red arrow.
Lean the handle of your Dyson all the way back and locate the black button on the right side of the vacuum indicated by the red arrow in Fig. 3.. Press the button down and hold it to unlock the swing arm.
While holding down the black button, pull the swinging arm (Shaded red in Fig. 4) all the way up. Fig. 5 shows the swinging arm in the correct position. Release the black button to lock the swing arm back in place.
The vacuum can now lock in the upright position as shown in Fig. 6. Note how the tab on the swinging arm overlaps the tab on the main body..
dcramer531_17.jpgdcramer531_18.jpgdcramer531_19.jpgdcramer531_20.jpgdcramer531_21.jpgdcramer531_22.jpg
Dec 11, 2010 | Dyson DC25 All Floors Bagless Upright...
Brush not turning
The belt doesn't have to be broken to be non-functioning. If the belt is intact but stretched it won't turn the brush. You can get belts here:
Dyson DC14 Belts
Feb 14, 2010 | Dyson DC14 Animal Bagless Upright Cyclonic...
My Dyson DC14 motor screams like a siren. What can i do to fix it?
The clutch system has a worn out bearing. You will have to have a Dyson dealer or warranty center replace it for you.
Dec 11, 2009 | Dyson DC14 All floors Bagless Upright...
Dyson DC14 Animal Bagless Upright Cyclonic Vacuum Logo
217 people viewed this question
Top Dyson Vacuums Experts
AskDyson
AskDyson
Samyfam
Samyfam
Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
