Question about Maytag Skybox Beverage Vendor
Maytag skybox not dispensing
Just bought this unit. Cools great, but it doesn't dispense cans. When I press the selection, the red light comes on and then all 4 lights begin flashing. I've unplugged it and plugged it back in. I've loaded the cans correctly. Does anyone know what's happening and how I can fix it? Thanks!
SOURCE: Maytag Skybox Beverage Dispenser/Refrigerator
TroJo, Try PartSelect.com for Skybox parts. I ordered a part on Monday night and installed it on Wednesday night. The parts are not that hard to find. Appliance repair services can replace your compressor or add freon. Be sure you have plenty of ventilation behind your machine. Jonmon
Posted on Jul 19, 2007
Master_Tech
  • 770 Answers
SOURCE: maytag skybox-2 problems
maybe bad fans and a dispenser motor post your email and iwill send you the svc manul so we can look into it deeper
Posted on Mar 04, 2008
SOURCE: Skybox won't dispense anything
Looks like I also found the answer to the problem of Skybox not dispensing. I replaced the sensor in the dispensing door and my Skybox now works great!
Part is available from partselect.com just look up your Skybox model number, mine was Skybox model MBV1976AAB. The diagram on the website should show you the exploded view of the door section of your Skybox. You are looking for partselect.com part number 901892 or on the exploded view it will be number 21. The Maytag part number is 11001182, board flipper sensor. My Skybox had been down for two years and now works again!
Posted on Apr 10, 2008
  • 4 Answers
SOURCE: maytag ice dispenser wiring diagram model MSD2456GEB
apc...appliance parts center has a good web site that might get you a wiring diagram. or your local appliance supply store might.
Posted on Jul 10, 2008
  • 3 Answers
SOURCE: Maytag Skybox dispenser
I also have one of these vending machines. The problem Maytag had with these and the reason why they are discontinued is that it was not made with an automatic defroster. SO, ice litterally builds up on the entire motor in the back and then the buttons do not work. Here is an easy test. Unplug the machine for 24 hours and if there is ice on the motor it will melt off(to where I dont know!!). Try the buttons again and see if they work. Mine did. They also had to come out and replace one of the pieces inside because the ice broke it! Mine by the way does not work anymore because the other problem they have had with these is that the compressor goes bad!! Once THAT happens, its more expensive to fix than it's worth! Good luck! Maytag SUCKS!!!
Posted on Nov 13, 2008
The vending on my maytag skybox stopped working
What do the led's do when you try to dispense a product?
May 05, 2014 | Maytag SkyBox MBV1976A Beverage Dispenser
The maytag skybox doesn't get cold anymore. we had it outside for a while (we didn't realize you couldn't have it outside) & it worked great all last summer. this spring, we realized it...
First you need to find out if the compressor is kicking on or not. If it isn't then it could be the starting capacitor (item 23), start relay (item 7) or the compressor itself. Since you had it outside I would suspect the capacitor or relay. http://www.searspartsdirect.com/partsdirect/part-model/Maytag-Parts/Refrigerator-Parts/Model-MBV1976AAB/3048/0168000/M0510224/00001
Does the skybox make noise (like your refrigerator starting a cycle)? If not, I would unplug it for a short while and let it set. Then when you plug it back up listen for noises on whether the compressor kicks on or not. If it doesn't then you can check the cap and relay board. Or have your compressor checked for operation and freon.
Jun 21, 2011 | Maytag SkyBox MBV1976A Beverage Dispenser
Skybox won't dispense. Door lights on, but no button lights at al
check the unit out to see if its frozen up. there is also sensors that corrode on them due to condensation. if it is frozen just unplug it and let it thaw out.
Dec 27, 2008 | Maytag SkyBox MBV1976A Beverage Dispenser
Maytag Skybox - Dispense Problem/Lights Flashing
I returned the machine to where I bought it. It not only didn't dispense, it also didn't refrigerate. sorry I don't have an answer for you.
Sep 06, 2008 | Maytag SkyBox MBV1976A Beverage Dispenser
CAN A SKYBOX 'MAYTAG' BE PERMENENTLY INSTALLED OUTSIDE
The Maytag SkyBox is not a commercial vending machine. It is designed for INDOOR use only. The possibility of electric shock is likely from a unit that has gotten wet. In addition, the electronics are not designed to withstand the outdoor elements.
Aug 10, 2008 | Maytag SkyBox MBV1976A Beverage Dispenser
Another Dispensing Problem
what is your email i will send you the manual so you can troubleshoot it better
May 15, 2008 | Maytag SkyBox MBV1976A Beverage Dispenser
Maytag Skybox
Looks like I found the answer to the problem of Skybox not dispensing. I replaced the sensor in the dispensing door and my Skybox now works great!
Mar 27, 2008 | Maytag SkyBox MBV1976A Beverage Dispenser
Mar 23, 2007 | Maytag SkyBox MBV1976A Beverage Dispenser
check the door where the cans come out. there is a sensor or the left side. if it is too far away from the door or if it's broken, it will do exactly what you said. i read somewhere that you can adjust the sensor closer to the door. i just bought one of the last one of these on the shelves 2 days ago and mine won't cool at all. stupid maytag..
Mar 01, 2007 | Maytag SkyBox MBV1976A Beverage Dispenser
Maytag Skybox Beverage Vendor Logo
231 people viewed this question
Top Maytag Refrigerators Experts
John Tripp
John Tripp
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
