Question about Palm LifeDrive Mobile Manager Handheld
Lifedrive wifi Every time i switch my wifi on it resets the lifedrive. what do i do.
  • 1,606 Answers
Does the wifi work at all after it resets? Have you applied the level 2 palm srvice pack to the LD? I believe the update changes how the wifi operates. If you go to www.palmone.com and go to the lifedrive page you should see a list of downloads for it. If you click on the 2.0 update there is a description of how to tell if you need this or if it is already installed. You just need to check the version of one file. Download and install the patch and see if that fixes everythng.
If that doesn't fix it you may have a more serious problem that could require replaceing or fixing the LD
Posted on Jul 09, 2009
I have a Palm LifeDrive. It has data belonging to the clerk that sold it to me. How can I erase it, so I can install my data (for example I need to erase all the passwords the guy put on the Palm, because...
To wipe all user informations from your device, slide and hold the power button to the right, and whilst keeping it in that position, briefly press the reset pin with the stylus pen (or, if it is missing, a paper clip would do). Release the power switch only when the reset screen comes up. Then, press the D-pad's Down key. This process will take some time (up to 25 minutes).
Hope it works for you.
By the way, if you happen to miss the LifeDrive user guide, feel free to download it from this location.
Cheers! Carlos
May 22, 2010 | Palm LifeDrive Handheld
Wifi connection issues with Palm One LifeDrive
It sounds like you need to setup the network settings on the palm or the wep or securty key or both.
When it shows the network id tap edit then enter the wep or wpa key if needed, then tap details to get to the screen where you enter the normal network details.
Usually it is just the security key that causes this. Get that code in and you might pop right on.
Dec 09, 2009 | Palm LifeDrive Mobile Manager Handheld
No free space on lifedrive
do a reset then check your card info tab
Jan 28, 2008 | Palm LifeDrive Handheld
LifeDrive Not Responding
Here is the only thing I found related to your issue-
http://kb.palm.com/SRVS/CGI-BIN/WEBCGI.EXE/,/?St=2,E=0000000000825355002,K=8658,Sxi=6,Case=Obj(26419)
Nov 10, 2007 | Palm LifeDrive Handheld
Palm LifeDrive
just press the time in the top left hand corner of the lifedrive and a dropdown menu comes down with the option "delete" but this is only for apps. if you want to delete media files, search for a file manager on freewarepalm.com
Apr 21, 2007 | Palm LifeDrive Handheld
Preventing hard drive spindown
SharkCache or RLock maybe cause some reset when you use your LifeDrive. In other word, SharkCache or RLock makes the LifeDrive unstable. It will conflict with some program you install in the LifeDrive. Speed or Stable ? You can judge by yourself.
Sep 15, 2005 | Palm LifeDrive Mobile Manager Handheld
Sep 15, 2005 | Palm LifeDrive Handheld
Wikipedia with lifedrive?
tr3 files are desktop PC files, they must be converted to .pdb files by the TomeRaider desktop program. Changing the file extention does not convert the data to Palm format, it is still PC data.
How do I fix my Outlook Calendar synchronization problem?
Palm tech fixed my problem. It turned out some items in Outlook Calendar were corrupted, thus preventing a synch with LifeDrive. The fix is to export the Calendar items and import them. This process fixes corruption. After doing that I successfully synchronized Calendar with LifeDrive. More specifically. I moved Calendar items to a different folder, thus emptying the main Calendar folder. I exported the Calendar items in the new folder to a CSV (Windows) file. Then, I imported that CSV (Windows) file into the main Calendar folder. Finally,I did a synch and all worked perfectly.
Sep 13, 2005 | Palm LifeDrive Handheld
Palm LifeDrive Mobile Manager Handheld Logo
129 people viewed this question
Top Palm Computers & Internet Experts
Michael Vincent Cruz
ray gallant
Raj Patel
Are you a Palm Computer and Internet Expert? Answer questions, earn points and help others
