Question about Kenwood Car Audio & Video
What kind of face plate goes on a ken wood model no 50601474
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Kenwood Master
  • 2,226 Answers
Sorry, but that is not a Kenwood model number. Typically it will be kdc-???? if it is a cd player. The model number should be on either the top or bottom of the deck. If you find the model number, you should be able to find a face for it at pacparts.com.
Posted on Feb 22, 2012
Kenwood kdc-mp522 face plate goes out when pushing on buttons
Clean the contacts on the back of the face plate and where it connects to the deck.
Mar 17, 2016 | Kenwood Car Audio & Video
Where is model number located on regency wood stove
Hi chery;
There should be a plate or decal on the back of the stove.
It will have the make, model, serial #, and clearances required from combustibles.
Oct 24, 2015 | Home
Stereo shut down
Did you check fuse block in the car as well as the stereo fuses?
When the face plate is down does that model have any indicator lights in the rest of the deck to see if it is getting power? My old ken wood used to have a red light that blinked behind the faceplate.
Sep 06, 2014 | Kenwood KDC-X993 EXCELON Flip-Face CD/MP3...
Cd player on mazda 626 plays cleaner but will not play cd's
Mazda's have a history of this and no one like's to work on them,just want to sell you one,I called a dealer to get mine repaired and other shops,no one work's on them anymore.So I bought a ken wood,had it 11 years,still like new,has clock on it and can remove face.
Nov 16, 2013 | 2000 Mazda 626
My stereo screen goes blank when I touch any control nob is there a way to stop this from happening. My unit is a ken wood excelon kdc-x996.
You have to go into the menu for the different functions, The display probaly is turn off, It will show display options,
Nov 05, 2012 | Televison & Video
Manual for nu-tool wood lathe nwl 900
Hi had any one got a manual for Nutool NWL 900 also a face plate
Jan 27, 2012 | Tools & Hardware - Others
Ladies citizen eco drive wrist watch face plate is cracked
A qualified watchmaker can replace it for you.
Hope this helps,
Ken
www.yellowstonewatch.com
Apr 06, 2010 | Citizen Eco-Drive BL006056H Wrist Watch
The motorized face plate only sits at the half-way
the flexible cable that goes from the face to the main motherboard is probably bad and needs to be replaced
Dec 10, 2009 | Kenwood KRC-X858 Cassette Player
TEAC model A1500 tape recorder
What i did to solve this problem on my A-1500 was to remove the tension arm, the pinch roller and the front face holding screws , pull off the rubber faces from the reel hubs and remove them, remove the front metal face plate... in back remove the wood backing panel... inside the deck rear, remove, (without letting them fall into the mechanism) 4 screws that anchor the heavy front cast piece that holds the capstan flywheel...carefully lift the cast piece that holds the flywheel. away from the deck face just enough to allow the old belt be removed, and the new one installed...ensure the belt is installed and goes all around the flywheel..and is not pinched when you push the casting back against the deck face and reinstall the 4 rear anchor screws. place the belt around the upper drive motor pulley wheel.. small diameter part on motor pulley and large diameter part on flywheel for users of 60 hz. Ensure 60hz is selected on switch..or 50hz if that is what you need.(for 50hz ensure belt is on large motor pulley part and smaller flywheel diameter part. with deck lying down or leaning, place a few drops of light lube oil into the felt at the bearing hole for the flywheel. Give the deck a test playback before completely reassembling and putting all the parts back where they were.
Nov 18, 2007 | Audio Players & Recorders
Car Audio & Video Logo
66 people viewed this question
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Jeff Turcotte
Jeff Turcotte
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
