Question about Dell Latitude D531 Laptop Computer PC Notebook
What's your problem?mouse pad cursor jumps on my D531 after a new hard drive
coldsilver20
  • 113 Answers
SOURCE: Dell Cursor Typing Blinking Problem
this is because you must deactivate your touchpad. you can do this by holding the Fn key and pressing the F* key that shows a picture of a touchpad in the same color as the Fn.
or you can go to control panel and turn it off in the mouse settings. but just attaching a mouse will allow the touchpad to stay active and therefore still be sensitive enough for your hand to "tap" th cursor.;
Good luck and pls rank this response! :D
Posted on Mar 16, 2009
gpetti2009
  • 92 Answers
SOURCE: Dell Cursor coldsilver20
Make shure that you have the correct drivers installed also go to control panel click on hardware and click mouse ,check if you see your mouse propertys listed if not go to divice manager click on the mouse and make sure that there are no driver conflicks is there are uninstall and than reinstall the drivers,
joecoolvette
  • 5660 Answers
SOURCE: Cursor jumps around
I have suggested in the past that people with this type of problem download Intellipoint Mouse software, from Microsoft.
It's a free download, and so far, I have had a good rate of this solution working.
Here is the download page from Microsoft.com,
http://www.microsoft.com/downloads/details.aspx?familyid=EA22BD62-4873-406A-BBBE-C587D35A53BF&displaylang=en
Posted on May 13, 2009
anandsharad
  • 137 Answers
SOURCE: how can I stop cursor from moving to new location
Does this happen when the adapter is connected or not.. most of the time is an adapter problem. try checking it on the battery and on the adapter. If you find change in the erratic moment on the battery. its an adapter problem.
To reinstall the touch pad driver for your machine. click on the following link.
For windows vista:- http://tinyurl.com/ntq4a3
For windows Xp: - CLICK HERE
Again, i would strongly advise you to change the adapter and use the computer. ;)
All the best
Posted on Sep 22, 2009
steve6375
  • 395 Answers
SOURCE: dell touchpad cursor jumps
Have you installed the touchpad driver?
Posted on Jan 03, 2010
My mouse pad is too sensitive, the pointer jumps, scrolls when ever i touch the pad to move the cursor. what can i do?
To change the settings on your mouse pad you should be able to go to:
1. windows Start Button
2. Control Panel
3. Hardware and Sound
4. Devices
5. Mouse
This should get you into the settings for the mouse and you can find different settings to change. Depending on your system layout of these controls they might slightly vary, but that should get you into the mouse controls so that you can change the sensitivity.
Sep 30, 2013 | Samsung RV510-A02 T3500 2.10G 320GBDVDRW...
Why is cursor jumping using Gmail or Facebook on windows 8
Your OS is out of date and now obsolete. Win 10 has the patches you require for stability.
Jun 09, 2017 | HP Hewlett Packard 2000-410US 15.6"...
Unstable, jittery cursor
Lets give this a try: Click the Start button> click Control Panel> click Hardware> and then click Mouse. Click the Pointer Options tab, and then do the following: Uncheck the Hide pointer while typing box. Hope this helps you. Let us know either way. Make it a great day!
Apr 30, 2012 | Compaq Computers & Internet
Jumping cursor on laptop
clean the mouse pad ,,, if doesn't work uninstall pad's driver and re-install the correct one... some laptops comes with joystick if yours have one clean it with a contact cleaner or disable it by unplugging it's cable ,,, if it didn't solve your problem replace the mouse pad or use a usb mouse ... :)
Mar 06, 2012 | Sony Computers & Internet
On my CF-51 the touchpad is erratic and occasionally the screen cursor will jump. The OS is Windows XP. Everything else works perfectly.
I had similar issues with cursor jumping even while using a mouse.
Very simple & quick fix is to simply "disable" touch pad through "start up" mode use a mouse.
You have to disable in start up menu or pad will re-enable itself next time you boot.
I never liked a mouse before being forced to use it .... now it's not so bad.
Jun 22, 2011 | Panasonic Toughbook CF-51 Notebook
I have a Dell Inspiron 1545 which has three problems, the battery discharges faster than when used by another computer of the same make, the screen lighting often blinks severally before it completely goes...
http://download.cnet.com/ccleaner/
run crude cleaner to get the flicker and speed the laptop up
get a new battery... if discharges too fast.. like less than 45 minutes
cursor jumping around.. watch your touchpad..
commonly you are touching the mouse pad during some keystrokes
you can set the mouse pad sensitivity downward under control panel--> mouse---> synaptics mouse pad sensitivity also
Jan 21, 2011 | Computers & Internet
Microsoft Mouse cursor jumping around
maybe u can use mousepad, with fabric material
May 28, 2009 | Microsoft Windows XP Home Edition
Cursor jumps around
If your cursor moves erratically on the screen (for example, if it jumps around the screen, moves at varying speeds, or selects items on its own), perform the following steps:
  1. Clean the surface of the touchpad with a dry, soft cloth to remove grease, sweat, moisture, or other liquids.
  2. Adjust the sensitivity of the touch pad:.
    1. Click the Start button and click Control Panel.
    2. Click Printers and Other Hardware.
    3. Click Mouse.
    4. When the Mouse Properties window appears, click the Pointer Options tab. (Figure 1)
      Figure 1: Pointer Speed
    5. Under Select a pointer speed:, click to move the slider bar closer to Slow.
    6. Click OK.
    7. Check to see if the touch pad still behaves erratically.
  3. If the touchpad still caused the cursor to behave erratically, attach an external mouse to your computer and restart your computer. Use the external mouse to see if your cursor still moves erratically.
Aug 14, 2008 | Computers & Internet
Acer aspire 5520-5334
press insert usually solves the problem
Jul 13, 2008 | Acer Aspire 5500 5570-2609 Laptop
Dell Latitude D531 Laptop Computer   PC Notebook Logo
146 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
