Question about Kenmore Dryers
Kenmore mod# 110.73012102, sounds like igniter is working ,drum turns, air blows ,but no heat
Was working fine,then stoped heating,you can hear the igniter fire up may get warm for a few seconds but does not get hot, changed the settings to whites, towels did not help ,mod#110.73012102 ser mp1802001
  • Kenmore Master
  • 2,128 Answers
Pop off the bottom panel,there's two clips that are on top of the bottom panel,stick a screw driver or putty knife in and pop the clips and pull out the panel to remove,start the dryer,if the flame ignites and then after a few minutes it doesn't ignite any more you have bad gas coils located on top of the gas valve,part number 279834 and they're around 25 dollars,if the flame ignites but goes out to soon most likely you have a blockage somewhere from lint buildup,pull off the vent line from the back of dryer and see if it runs any better,also unplug the dryer,remove the lint filter,remove the bottom panel and then remove the metal duct that the filter slides into and clean it out,vac and blow out all lint with a shop vac on the motor and inside the cabinet,if your vent line is a long run,remove it from the back of dryer and blow it out with a leaf blower,first check outside to make sure there isn't a cage or anything blocking the air flow before you blow out the line,if there is remove it and don't put it back.let me know how you make out and good luck.
Posted on Feb 22, 2012
Testimonial: "thanks sal"
AlmostBob
  • 550 Answers
SOURCE: dryer stpped working
with power disconnected
if any wire disconnected before any test, reconnect & test dryer, reconnect wires after each test
disconnect wires from start button and test, conduct when pushed, no conduct when release
if fail replace start button test dryer
disconnect wires from door switch and test, conduct when pushed, no conduct when release
if fail replace door switch test dryer
follow leads from start button to relay(relay is first device connected to start button), and make sure all wires connected at both ends. If any wires disconnected, test dryer
locate thermostats and thermal fuses on fan housing and ducts
individually disconnect wires from each and test. conduct good, no conduct fail
replace any failed thermal fuse or thermostat test dryer
if all prior test OK
replace relay, test dryer
Posted on Oct 12, 2008
djz83
  • 88 Answers
SOURCE: Kenmore dryer does not heat up. Mod#110 60912990
First I would make sure that you have 240volts coming into the dryer. Then I would check the thermal cut-off in is a fuse on the housing of the element. that should be it but if not look for the heater relay.
Posted on Jan 13, 2009
  • 56 Answers
SOURCE: Kenmore dryer 110 708 12990 Igniter glows, but
replace the two coils on the gas valve use the maytag coil kit much cheaper and same part
Posted on Jun 30, 2009
heatman101
  • 43501 Answers
SOURCE: I have a Kenmore dryer, mod 110 60956990, ser
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Posted on Oct 29, 2010
heatman101
  • 43501 Answers
SOURCE: our kenmore dryer 600 series,model
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The
Dryer Repair - The
heatman101
Posted on Jan 18, 2011
I have a 2005 hyundai elantra heat blows cold air i changed thermostate and radiaor and blew out the heater core any sugestions
check to make sure the blend door is changing from cold to hot. With the engine off and the key in the run position set the blower motor to the highest speed. Turn the temp dial to full cold and wait 30 seconds. Now turn the temp dial to full hot a listen carefully. You should hear a difference in sounds as the blend door sweeps through its full range.
If it is working and the engine is fully warmed up feel the heater hoses where the pass through the fire wall. One should be very hot and the other should be pretty warm. If one is hot and one is significantly cooler than either the heater core is plugged or there is air in the heater core causing a block in flow.
Jan 07, 2016 | Hyundai Cars & Trucks
I have a bosch aquastar aq 125fx probably 9 to 10 years old it heats fine but after about year 2 it stopped working when you fire it up shortly or immediately after firing it up before. in other words it...
You either have a weak spark from your ignitor which needs replacing, a bad elec connection to the ignitor, or it needs to be repositioned nearer the burner. Check connections and try repositioning it before you install a new on.
Apr 30, 2017 | Bosch & Tankless LP Hot Water Heater
Hi, I've a fagor feb20e Eco plus combi boiler in
There is a flow sensor in the circuit and it is not sensing the lower flow from just the hot water. When you put it on heat though it does.
May 31, 2013 | Water Heaters
Oven won't heat up when baking (Maytag MGR5775QDS)
Check the Manual/Auto Clock setting to be on Manual not auto . The Oven is waiting for the Right Time to start up .
Jun 13, 2012 | Maytag MGR5775QDS Dual Fuel (Electric and...
Pilot light is lit fires up for 30 seconds then shuts down.
do you have a CO detectors? If so try resetting them
Feb 22, 2010 | Heating & Cooling
My Whirlpool accubake is taking a very long time to heat up
It is possible that the igniter that lights the gas is getting weak... as they weaken it takes longer for them to heat up hot enough to ignite the gas. When you light the oven, you should be able to see the orange glow of the igniter within a few seconds (it's similar to a cigarette lighter from a car) within 20-30 seconds you should hear the gas light.
Sep 01, 2009 | Whirlpool Accubake RF362LXTT Electric...
Protherm 100EC boiler not firing up
You likely have a flame sensor problem.
If you can wath the ignition proccess, see if you ever notice a flame. If yes, and it then shuts downm, you have a flame sensor failure, replace the sensor and clean the flame burners and orifices.
If no flame at all, then your ignitor is failing, or you are not gatting gas to the ignitor.
Aug 23, 2009 | Protech Systems FasNSeal FSWMKE4 4" Vent...
Gas Furnace is not heating anymore.
the fan you hear come on at a call for heat is most likely just the inducer motor. the click you hear is probably the relay for the hot surface ignitor which should glow red, then in turn ignite the main burners. your going to have to determine if the ignitor is coming on. if it isnt the ignitor is bad and will need to be replaced. if it comes on and than shuts off after a few seconds the ifc board is probably at fault
Apr 09, 2009 | Heating & Cooling
I have no heat in my 1995 maxima
You need to check your coolant level first & make sure its up where it should be. If that doesn't cure your problem, or you've already topped it up, please get back to us.
Jan 08, 2009 | 1995 Nissan Maxima
Dryers Logo
267 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
