Question about Gateway GT5220 PC Desktop
Computer beeps three times and then nothing - Gateway GT5220 PC Desktop
    Sergeant:
  • 233 Answers
Open the computer case
extract RAM
clean it with dry cloth
brush the RAM slot from dust
put the RAM back
check it
Posted on Feb 22, 2012
  • Darwish Al-helo
    Darwish Al-helo Feb 22, 2012
    if no progress do the same for your VGA card (if any)
How to fix a dell PC that beeps three time then dot do anything
This usually means there is a memory problem or no memory at all.
Jul 11, 2014 | Dell Microsoft Windows XP Home Edition
How to fix a laptop that doesn't turn on but beeps 1 long beep and 3short beeps
This POST cade is related to RAM problem
one beep, three short beeps
three short beeps, one beep
  • Memory problem: bad DIMM or bad DIMM slot
Try reseating the RAM, if this does not work then remove the RAM module and take it to your friendly computer repair shop and get them to test the RAM for you.
May 12, 2012 | HP Pavilion ze2000 Notebook
When i press the on button, the fan comes on and three beeps that follow and nothing else happens.
three beeps indicates a ram (random access memory) problem remove on at a time ensureing the computer is switched off and power cable removed leave it for 10 mins before opening the comp as there could still be electricity or static inside the unit.
Oct 06, 2010 | E-Machines T5088 PC Desktop
Screen went blank, have yellow indicator on monitor, try to reboot, getting three beeps, nothing more.
One beep during startup is "good", but THREE is not good.
Three beeps means a hardware fault -- probably that the video-adapter on your computer has failed.
Connect the monitor to another desktop/laptop, to confirm that it still works.
Turn the computer off, and disconnect the power-cord.
Remove all the RAM, and then re-insert just one stick.
Reconnect the power, and try to boot.
If you still get THREE beeps, turn it off.
Disconnect the power-cord, and reinsert the remaining RAM sticks.
If you still have the problem, then it's time to replace the video-card on your computer. Take the computer to a computer-store, so that they can sell you a video-card that will be compatible with your motherboard.
Hopefully, if you buy the video-card from them, they will install it for a modest fee -- ask them.
Dec 31, 2009 | Intel D945GTP Motherboard
My computer doesn't boot up, all it does is beeps three times and nothing happens.
sounds like memory problem but to be sure contact the manufacture and find out what the 3 beeps mean.
Oct 01, 2009 | Computers & Internet
At start up, before windows loads, a consistent series of annoying beeping occurs....
If they're occurring right as you turn the computer on, it's your Power On Self Test (aka POST) letting you know. Since I can't be more specific, here's a synopsis of POST beeps:
One single beep followed by three, four, or five beeps -- System-board problems, possibly with DMA, CMOS setup chip, timer, or system bus. The computer usually won't boot when this is the problem.
Two beeps -- The POST numeric code is displayed on the monitor, usually nothing to be concerned about, but you might google the code on another computer and see what you get.
Two beeps followed be three, four, or five beeps -- First 64K of RAM has errors. Solution is to replace RAM.
Three beeps followed by three, four, or five beeps -- Keyboard controller failed or video controller failed. Either you won't be able to see or type with this error.
Four beeps followed by three, four, or five beeps -- Problem with serial or parallel ports, system timer, or time of day. Check your BIOS settings (usually F2 at start up) to make sure everything is correct.
Continuous beeps - problem with power supply. Probably won't do much with this error. At the very best, your computer will boot and run very, very slowly.
Hope that helped.
Sep 01, 2009 | Compaq Computers & Internet
I have a dimenison 4600 that just beep and won't boot
Possibly a memory issue. Double check your memory is clipped in properly. If you have two sticks you should be able to run on just one to test and see if one is damaged.
Feb 19, 2009 | Dell Dimension 4600 PC Desktop
Laptop won't boot up. Only 3 beeps.
listen to the beep heres some information on beep code errors
Beep Code: Description of Problem: No Beeps Short, No power, Bad CPU/MB, Loose Peripherals One Beep Everything is normal and Computer POSTed fine Two Beeps POST/CMOS Error One Long Beep, One Short Beep Motherboard Problem One Long Beep, Two Short Beeps Video Problem One Long Beep, Three Short Beeps Video Problem Three Long Beeps Keyboard Error Repeated Long Beeps Memory Error Continuous Hi-Lo Beeps CPU Overheating
Jan 25, 2009 | Toshiba Satellite X200-AA3 Notebook
Dell precision 3100 machine will not boot up
If your computer is beeping at you, 9 times out of 10 its going to be an issue with the memory or video. (more often the memory) Try re-seating both. If your still hearing the beep fest, below is a list of the most common beeps and what they refer to. This will help you to find out what needs replacing.
Long beep followed by 3 sequential short beeps. This issue is linked to your Graphic card configurations
Short beep followed by three sequential long beeps You are facing a system memory problem
Beep- PAUSE- Beep- PAUSE- Two sequential beeps This error is linked to your CPU
Three beeps-PAUSE-Three beeps-PAUSE-Four beeps You have an issue with the video memory
Three beeps-PAUSE-Four beeps-PAUSE-Beep This is linked to an error with your Graphic Card
Four beeps-PAUSE-Three beeps-PAUSE-Beep You have a system memory problem
Five short beeps You are facing a problem with your CPU
Long constant beeps It’s a system memory problem
Short constant and high-pitched beeps The temperature of your CPU is too high
Jan 05, 2009 | Dell Dimension 3100 PC Desktop
I formated my computer....a asus p4b 1.5 mhg....turn it on and off while re-installing all of my software. once done i turned the puter off to clean the cpu fan... since the puter would not turn itself...
hi hope this helps.
Oct 18, 2008 | ASUS Computers & Internet
Gateway GT5220 PC Desktop Logo
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
