Question about Keurig B60 Coffee Maker
Prime appears on screen and says add water - Keurig B60 Coffee Maker
  • Keurig Master
  • 1,711 Answers
We have a very good video for this problem What to do if your brewer indicates prime
Posted on Feb 25, 2012
When power is turned on the word prime appears in the LCD control center screen and the water low lights flash in the water reservoir but reservoir is full What is wrong?
the word prime means that you have to fill the unit first so that all air is removed
check for some sort of bleed valve /screw at the top
fill the unit first then connect it all up
all these sort of instructions will be in the user manual for you to follow
Mar 10, 2016 | Keurig Platinum B70 Coffee Maker
Tip
Saeco, Gaggia, Spidem VENTILATE, Prime what is mean, how to perfrom
Ventilate or priming or else loading all means the filling the machine system full with water, like pump, piping and boiler. This must perform first time of starting up the machine.
It will also appear if the water system in not full of water especially after the steam preparation some steam can be blocked in the system and the machine recognized it by luck in the pressure.
Another reason that ventilate it appears on screen is because air have been insert and blocked in the water system usually from water filter or water softener located in water tank.
So here how you Ventilate or Priming or loading:
Place a container beneath the steam tube.
Turn the knob counter clockwise to start loading the circuit.
Wait until a steady stream of water flows out from the nozzle.
Turn the knob clockwise
to terminate the circuit loading process.
Remove the container. The machine is warming
up; lights are flashing.
Note: You must load the circuit before starting up
the machine for the first time, if it has been inoperative
for a lengthy period or if the water tank has
been completely emptied. The circuit must also be
loaded each time the light flashes
on Aug 28, 2010 | Coffee Makers & Espresso Machines
How do i prime a gould j5 pump
to make it easy to prime a pump I put a "T" piece in the suction line close to the pump. When it needs priming I take out the plug and put water in the line until the pump is full
Oct 17, 2014 | Goulds Pumps Goulds 1 Shallow Well Jet...
Says prime and asks for water when full
I am not sure but the little filter may be dirty and need to replace
Mar 31, 2014 | Keurig Special Edition B60 Coffee Maker
Won't prime
The water pump system is not primed properly. Remove the water tank while the pump is running and put back a couple of times. If not working, when the power is off, using a straw, blow air through and try to **** through the water port at the bottom of Keurig. Plug the water tank again in and start the system. It will take some time to prime, keep trying. There is nothing wrong with the machine, but the water pump circuit.
Oct 18, 2012 | Keurig Elite B40 Coffee Maker
Reservoir is full but "add water" still appears on screen
the problem is the floating sensor magnet doesn't float
Jun 15, 2012 | Keurig B60 Coffee Maker
Is prime the same as descale
I knew the paperclip trick, I tried the air shot to reverse the flow of water. After running Vinegar and water through and letting sit overnight. I tried the air blast then make a cup, another blast X 4....though I get a good flow through the K-cup area, I still only get 2/3 cup of water.
Jan 15, 2012 | Keurig Special Edition B60 Coffee Maker
Beans grind and are wet but coffee doesn't come out... it goes through the cycle and spits out a little. When cycle is complete, the water light comes on, but after priming the same thing occurs.
This tells me that either the grind is too fine and or the brew unit screen, and discharge tube needs to be cleaned. Try this first press the button for making a espresso using the manual function, do not add coffee through the door then press the brew button. If water flows freely then the grind is too fine, if you get the water prime error then the screen under the red o-ring on the brew unit needs to be cleaned.
Oct 19, 2011 | Saeco Incanto Classic Espresso Machine
Message "prime" appears on display
There is air in the lines and it is blocking the water flow...
Here is a tip that will help you getyour Keurig to prime...
Keurig CoffeeBrewer will not prime
heatman101
Jul 14, 2011 | Keurig B60 Coffee Maker
Keurig B60 Coffee Maker Logo
975 people viewed this question
Top Keurig Coffee Makers & Espresso Machines Experts
Lisa
Lisa
Jason
Are you a Keurig Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
