IBM ThinkPad T43 Notebook Logo
Posted on Feb 22, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Fan error the cpu fan was broken by compressed air I have replaced it but it still won't start up I am hoping to isolate the location of the fan control on the motherboard
Steve Allison
Level 3:
  • IBM Master 5,569 Answers
  • Posted on Mar 01, 2012
Steve Allison
IBM Master
Level 3:
Answers
5569
Questions
Helped
2002494
Points
16452
Compressed air can cause the formation of very high static voltages which can cause semiconductors to fail instantly. I learned this the hard way. . .
1helpful
Toshiba satellite l355-s7915 heatsink location...keeps randomly shutting down
Overheating When the CPU overheats then it will shut down (i.e. thermal overload) and won't boot up again until it has cooled down. If this is the problem is not fixed then the CPU will eventually fail.
A faulty fan causes the problem or the fan and heat sink assembly are clogged with dust.
Check the CPU fan to see if it spins freely, if not replace the fan.
If the fan and heat sink is clogged with dust the remove the dust and make sure the vents are clear and dust free. Use a small brush and can of compressed air to do this.
2helpful
2answers
Not booting, no power, overheating
Asus u52 shut down unexpectedly
When the CPU overheats then it will shut down (i.e. thermaloverload) and won't boot up again until it has cooled down. If this is theproblem is not fixed then the CPU will eventually fail.
A faulty fan causes the problem or the fan and heat sink assembly are cloggedwith dust.
If the fan and heat sink is clogged with dust the remove the dust and make surethe vents are clear and dust free. Use a small brush and can of compressed airto do this.
My laptop keeps turning off
OverheatingWhen the CPU overheats then it will shut down (i.e. thermaloverload) and won't boot up again until it has cooled down. If this is theproblem is not fixed then the CPU will eventually fail.
My dell xps won`t stay on
Used ups system w/new & charged batteries,run time=160 min. shuts down in 2 min.
HP 620 laptop shut down and won't start
Shuting down after a few second after windows start up ..
1helpful
Every time there is a problem of overheating error and my system shuts down .when i restart my computer cpu produce beeps . motherboard is of Intel 915 series is used.......
When the CPU overheats then it will shut down (i.e. thermaloverload) and won't boot up again until it has cooled down. If this is the problemis not fixed then the CPU will eventually fail.
If the fan and heat sink is clogged with dust the remove the dust and make surethe vents are clear and dust free. Use a can of compressed air to do this.
2answers
IBM R51 laptop when start the laptop it canot boot and error display thermal sensing error
When the CPU overheats then it will shutdown (i.e. thermal overload) and won't boot up again until it has cooled down.If this is the problem is not fixed then the CPU will eventually fail.
A faulty fan causes this problem or the fan and heat sink assembly are cloggedwith dust.
Check the CPU fan to see if it spins freely, if not replace the fan. If the fan and heat sink is clogged withdust the remove the dust and make sure the vents are clear and dust free. Use acan of compressed air to do this.
Top IBM Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
ExpressFiX
ExpressFiX
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
