Question about Canon NP 6551 Black and White Copier
Canon copier np 6412
Hey......
We have a really old copier, stopped printing. Ordered new toner. Accidentally removed the whole chamber which holds the toner cartridge and now I can not get it to lock back into place. Any suggestions????
  • 168 Answers
Wow that is hard to do i made the mistake doing that one time promised myself never to do that again took me quite a while to get it back in i dont know of any trick except persisitance just dont let the springs come off
Posted on Dec 19, 2008
Canon NP 2120 copier printing very very lightly?
do you already change your drum?pull out your developing unit and you can see cooper plate inside the machine,possibly its broken or this problem due to yourHV board.You can try change your AE sensor.
Very old model
Nov 03, 2011 | Canon NP 6050 Copier
Price of Canon NP 6035 Copier
Hey!To be honest and talking from experience,dont buy the machine!Its a old model and spares are all ready a problem to get hold of!!Rather see if u can not get something like a IR type machine!!
Good Luck!
Dec 24, 2010 | Canon NP 6035 Copier
Np 6412 copy dirty lines length of paper
Sounds as if the drum needs to replaced. How long has it been in the copier? They are supposed to be good for 30,000 copies or one year. It could also be dirty optics ( mirrors and glass ). Drum is easily installed by the customer. Just practice with the old drum - removing and re-installing before using the new drum. Too expensive to damage when installing. **** open the copier, Look under the control panel and you should see two levers. Move the right one to the right - this moves the developer away from the drum. Then move the left one down and this releases the drum for removal. Reverse procedure and power up the copier. It will automatically run and set the new drum settings into the copier.
Dec 08, 2010 | Canon NP 6551 Black and White Copier
To replace the Canon GPR-11 black drum, do you just take the old one out and put the new one in? That is what we did and there is a band of black toner printing on the top of each sheet.
The new toner cartridge snap's into the top of the Hopper > just look on the box on how to install it. Once you have pulled the tab till you can read "STOP" push the slid back in and release the toner cartridge and you are done...... Put the empty cartridge into the "G" file
Oct 01, 2010 | Canon NP 6035 Copier
My Church purchased a Canon F132500, NP 6412, Number 25676. The copier an analog one, is over 8 years old. I have been trying to replace the drum. Can you help?
What is the problem with replacing the drum unit??? The developing unit has to be disingaged and the drum has a thumb srew & you pull the drum out & put the new one in and you are done... Good Luck
Apr 20, 2010 | Office Equipment & Supplies
How do you replace toner for canon np 6035 copier
Close but the toner container is replaceable, you do not have to pour any toner in the container. The replacement toner should be the exact same toner bottle, all you have to do is just swap out with the old one.
Mar 26, 2010 | Canon NP 6035 Copier
Canon Copier 6025
The Waste Toner is located in the the drum unit it self. You need to remove the drum unit & on the top of the drum unit is a white or clear rectaular cap. You need to open it carefully and vac out the toner in side the unit. FYI if you are empting the waste toner the drum is just about worn out... Good Luck
May 18, 2009 | Canon NP 6551 Black and White Copier
Canon pc980 copier...changed toner cart. now the image it produc
Cartridge is defective. I suspect it was a 'compatible' or remanufactured unit vs. an original. Replace it and it will work fine.
Apr 20, 2009 | Canon Office Equipment & Supplies
Canon NP-1215
1-toner may be bad (moisture)
2-primary wire not charging - no contact or broken (unit with a thin wire above drum)
3-seperation unit shorting out (wires under the drum)
Sep 01, 2008 | Canon imageRUNNER 1023iF Black and White...
Canon copier NP 6412
It is a older copier, it could be a fan is not working, is it making noise. It may be failing......
Jul 13, 2008 | Canon NP 6551 Black and White Copier
Canon NP 6551 Black and White Copier Logo
101 people viewed this question
old marine
old marine
