Question about Viking VDSC367-4G Dual Fuel (Electric and Gas) Range
Viking range oven not working
Oven not working and went out suddenly.
bigg t
  • 640 Answers
SOURCE: Viking Range VGIC4856GSS
Goto this site. http://www.3wire.com/foodservice/?OVRAW=northern%20parts&OVKEY=northern%20part&OVMTC=standard&OVADID=6566743522&OVKWID=55119092022 they should help you out.
Posted on Feb 16, 2008
  • 42 Answers
SOURCE: my viking electric oven does not have accurate temperature
how bad is the temp off?
Posted on Dec 21, 2008
  • 42 Answers
SOURCE: Viking Range oven door does not close properly
sounds like the door hinges need replaced. order a part #PC020009 qty 2
  • 10865 Answers
SOURCE: viking range burners won't light
All of these ranges have a spark module at each burner sight and they all click when ever you attempt to light one burner. Therefore, it can not be assummed that the spark module for those nonworking burners are actually clicking. Remove the burner covers and actually look for the sparks. If there is no spark make sure the connections are nice and tight. IF they are, you most likely need to replace the spark module.
Posted on Apr 30, 2009
  • 23 Answers
SOURCE: Viking 30" Range - Igniter works - but NO FLAME in oven or ranges
No pilot light need to be ignited. You may need a new ignitor. It might not be catching. If you pull the bottom oven plate off you can see the ignitor on the side of the burner and see if it is in its place or broken or just plain old. It is a simple fix. You can buy a universal ignitor or contact Viking and they will sell it to you. Its only two wires and can do it yourself if you are somewhat technical. Good luck.
Posted on Sep 18, 2009
Digital display on Viking double oven VEDO205 went dark after a power outage. All else seems to work.
Hi try pulling the fuse to the oven for 20 mins and then power it up again doing a hard reset and see how that goes.
robotek
Jul 06, 2008 | Viking Kitchen Ranges
Takes forever for my oven to preheat to 400*. 25 minutes or so. Oven is brand new.
A brand new oven should work. You should not tinker with a brand new oven. A brand new oven that is malfunctioning is probably under warranty and should be repaired under that warranty.
Viking is the Rolls Royce of kitchen equipment. Call your installer or builder or Viking for service for your brand new oven.
Thanks for your question @ FixYa.com
Mar 13, 2011 | Viking Professional VGSC3666BSS (Dual...
I have model GS563LXSS...all of a sudden the oven
It is not good to do the self clean. The electronics take a beating. Probably the ignitor went out. The oven gets too hot.
Nov 03, 2009 | Whirlpool GS563LXSS - stainless Steel Gas...
Have a Viking range, gas top, electric oven, neither work.
Check connector block where electric is brought into stove for loose or burnt wires. Check Breaker in house power box. Push the breaker firmly to off and then return to On position. Read owner's manual to see if ignitor circuit has a fuse and check said fuse.
Sep 12, 2009 | Viking 30" Dual-Fuel Range, VDSC3054B...
Viking oven
We had a hurricane come through and power was out at our house for 2 weeks. The top burners worked but the oven would not. Our outside gas grill worked perfectly also using the utility provided natural gas. We were told by Viking that the oven is designed to work only when there is electric power. This is a safety feature, according to Viking.
Sep 22, 2008 | Viking VGSC306-4B Gas Kitchen Range
Viking VDSC367-4G Dual Fuel (Electric and Gas) Range Logo
24 people viewed this question
Top Viking Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Craig Butler
Craig Butler
Are you a Viking Kitchen Range Expert? Answer questions, earn points and help others
