Question about GE Refrigerators
GE PROFILE TCX22PAC
BOTTOM FREEZER
  • 1073 Answers
SOURCE: GE Profile French Door bottom
IT IS STILL UNDER WARRANTY call ge at 800-386-1215 for factory service
Posted on Apr 15, 2008
mosesclive
  • 191 Answers
SOURCE: ge profile with bottom freezer
Poor cooling is often the result of a heavy frost build-up on the evaporator coils or a condenser that is clogged with dust, lint, and dirt.
Evaporator coils Poor cooling is often the result of a heavy frost build-up on the evaporator coils. You can't see these coils without removing a panel on the inside of your freezer. A sure sign that there is a build-up is the presence of any frost or ice build-up on the inside walls, floor, or ceiling of the freezer. Such a frost build-up usually indicates a problem in the self-defrosting system or damaged door gaskets.
The refrigerator is supposed to self-defrost approximately four times in every 24 hour period. If one of the components in the self-defrosting system fails, the refrigerator continues to try to cool. Eventually, though, so much frost builds up on the evaporator coils that the circulating fan can't draw air over the coils. There may still be a small amount of cooling because the coils are icy, but with no air flow over the coils, cooling in the refrigerator compartment is quite limited.
Here's an inexpensive, though inconvenient, way to determine if the problem is with the self-defrosting system. Remove all of the perishable food from the refrigerator and freezer, turn the thermostat in the refrigerator to Off, and leave the doors open for 24 to 48 hours. (Be sure to have several towels ready in case the melting frost and ice causes the drip pan to overflow). This allows the refrigerator to defrost "manually." When the frost and ice build-up has completely melted away, turn the thermostat back to a normal setting. If the refrigerator then cools properly, it indicates a problem with one of three components in the self-defrosting system:
  • The defrost timer
  • The defrost thermostat (also called the bi-metal switch)
  • The defrost heater
If it still does not cool properly, there may be a problem with the refrigerant level or the compressor. You may need to consult with a qualified appliance repair technician to further diagnose the problem
Condenser Self-defrosting refrigerators all have a set of coils and a cooling fan, usually under the refrigerator, that need to be cleaned regularly. If these coils get coated with dust, dirt or lint, the refrigerator may not cool properly. The coils may appear to be a thin, black, wide radiator-like device behind the lower kick-panel. To clean them, disconnect the refrigerator from the power source, use a refrigerator condenser brush and your vacuum cleaner to clean the coils of any lint, pet hair, etc. You may not be able to get to all of the condenser from the front, it may be necessary to clean the remainder of the condenser from the rear of the refrigerator.
Posted on Jul 29, 2008
SOURCE: removing freezer drawer
my son fixed it - thx. problem solved
Posted on Nov 24, 2008
  • 5 Answers
SOURCE: I have ice forming in
probably have a clogged drain at the rear base of the freezer unit check at the very bottom of your freezer at the back look and see if the drain is covered with ice..
Posted on Jan 15, 2009
  • 105 Answers
SOURCE: GE Freezer Leaking
Open the freezer door, remove the bottom tray, smash the ice on the floor with your fist to remove it. Now get a glass of hot water and pour it into the trough which is at the bottom of the back wall of the freezer. Allow a few minutes for the ice to melt then remove it with an ice pick or scrrewdriver. Once the ice is out, pour more hot water into the trough. Now take a long tube ( an old washer fill hose works perfectly) and stick one end in the hole in the trough. Now fill your mouth with warm water and blow it very hard through the tube. Once the drain is clear, pour some hot water and a very little amount of bleach through the hole.
Posted on Apr 07, 2009
Cleaning the base of a GE Profile with a bottom freezer drawer.
Click Here=> PDS22MHR and go to page 11 in the PDF. I believe that will answer your questions of removal. If need you may contact me here on Fixya or my Forum=> Appliance 911 My contact information is located above the Fixya Ad on my blog here=> Sea Breeze Appliance Parts and Technical Services, www.pcappliancerepair.com
Thanks, Sea Breeze
Mar 18, 2010 | GE Profile PDS22MHR Bottom Freezer...
Freezer temperature fluctuating way up and down. 0 recommended. 11 degrees right now. 18 earlier. Food defrosting. Ice cream soft. GE Profile bottom drawer freezer. Only 3-4 years old.
Your problem could stem from an issue with the defrost timer, the compressor or its attachments (e.g.: relay, capacitor, etc.), or the freezer/evaporator fan motor. Contact an appliance service company.
Feb 10, 2010 | GE Profile PDS20SFS Bottom Freezer...
GE Fridge/Freezer, defrost cycle leaks water in freezer bottom
Hi, this is because the defrost drain is blocked. Follow this LINK which will take you to my tips and full instructions on clearing the blockage. If you have any additional questions please feel free to comment. Mike
Dec 27, 2009 | GE Refrigerators
My GE Profile bottom freezer and frig's temps are also up..help
has a FF error shown up on your display. If so that is your freezer fan, and if not it still might be the FF motor is running to slow.
Jul 20, 2009 | GE Profile Stainless Bottom-Freezer...
GE Profile Freezer not cold enough
VACUMM THE COILS UNDERNEATH THE THE FRIDGE THEY MAY BE CLOGGED WITH LENT AND DUST...... HOPE THIS HELPS
Jun 10, 2009 | GE Profile Stainless Bottom-Freezer...
Blocked defroster drain GE profile tfx25pr, tft25pr
Remove the freezer bins and shelves.
Remove the rear freezer panel.
The drain is on the bottom center of the freezer after the rear panel is removed.
May 25, 2009 | GE Profile PSW26P Stainless Steel Side by...
Removing freezer drawer
Nov 23, 2008 | Pds GE Profile Bottom-Freezer Drawer...
Ge refrig
I have a ge profile side by side. when it auto defrosts the water runs to the bottom and out the freezer door instead of down the drian??
May 31, 2008 | GE Profile Arctica Stainless Steel Top...
Refrigerators Logo
228 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
dweatherby
