Question about Lexmark X5150 All-In-One InkJet Printer
Lexmark 5650 all in one reads cartridge error
  • Official Brand Answer
  • 3,344 Answers
The problem could be due to a communication failure between one of the printheads (cartridges) and the All-In One (AIO) or by a short in one if the printheads. Please follow the steps below to identify and fix cartridge issues:
  1. Make sure the printer is on.
  2. Open the printer cover. The print cartridge carrier moves and stops at the loading position, unless the All-In-One is busy. Note: If the carrier does not automatically move to the center, turn off the printer or unplug the printer from the power source and then carefully slide the carrier to the center.
  3. Remove both cartridges from the carrier.
  4. Close the printer cover.
  5. Re-brick your printer by pulling out the power supply - black box behind the printer where the power cord is plugged in to, and re-plug after 30 seconds.
  6. When the printer turns on, reinsert one cartridge first. Close the printer cover and check for any errors.
  7. If no error appears, reinsert the other cartridge. Close the printer cover.
  8. Replace whichever cartridge is causing the error to appear with a new genuine Lexmark cartridge. Try to print a document again to verify that the problem is fixed.
Posted on Feb 22, 2012
3 Suggested Answers
CW Oly
  • 240 Answers
SOURCE: refilled black cartridge 36 on my 5650 won't work
The cartridge is electronically dead. This is a common occurrence from improper refilling. To be correctly refilled it must be done under a vacuum to prevent air from entering the print head, which has likely happened. As ink flows through the print head it acts as coolant in an engine, when air is introduced the print head cannot cool, over heats, and ruins the cartridge. These cartridges are difficult enough for us professionals to refill successfully, my recommendation is to leave it to us, or buy original. A refilled integrated print head cartridge will always continue to read as empty because there is no way to reset the cartridge, the manufactures do this on purpose. Lexmark cartridges in general are designed to only last one cycle anyways, multiple refills is attained only with proper technique.
Posted on Feb 02, 2010
  • 144 Answers
SOURCE: where is the printer cartridge
hi first do not switch off the machine simply lift up the top half of the machine from the front there will be a marking and usually oval shape where your hand should fit lift up the ink cartridge will then move to the centre lift the grey latch and remove the cartridge you need to replace take the new cartridge and remove the seal and fit in position relock the latch and close the the top half of the machine it should recognise the new cartridge remember lexmark do not work with refilled cartriges and that the replacement instructions comes with the new catridge as well as in the printer driver tools under maintenance you will find it under printers on your pc good luck
Posted on Nov 23, 2010
LEXMARK 5650 HOW TO RESET INK
HI.. TRY THIS Take a small pice of clear tape. Try covering one of the outside vertical row of contacts at thr front of the cartridge. Re-insert it and it shoudl "fool" the printer into thinking it is a new cartridge. It works for my Lexmark 2600 series all in one. Good Luck.
FORUM PREFERED http://www.fixyourownprinter.com/forums/printer/35235
Apr 01, 2012 | Lexmark X3330 All-In-One InkJet Printer
Installed refilled ink catriges,both black and color used for a few days all was well then, it reads Catridge Error -Error: 50C Go to users guide. what do I do Now cannot find users guide. plzzz help.
Though Lexmark does not recommend using refilled inks. You may refer to this article from the Lexmark website on Cartridge Error 50C and Other Errors on the Lexmark X5100/X6100 Series LCD Screen. If this does not help, try to insert a genuine Lexmark cartridge to determine if your other cartridge is faulty. Thanks.
Feb 24, 2011 | Lexmark X6150 All-In-One InkJet Printer
My lexmark x 5650 keeps saying alignment error, try to remove tape. I've done this multiple times, tried cleaning the cartridge, and it keeps saying alignment problem. ive unplugged and plugged back in...
alignment error usually means that one cartridge is not printing, or paper tray is empty.
try removing both cartridges then stamp each printhead on some folded tissue paper. You should get one solid strip of black ink with the black cart and 3 colour strips with the colour cart.
If you don't...there is your problem.
good luck
LC1000
www.inkbank.com.au
Dec 01, 2010 | Office Equipment & Supplies
Where is the printer cartridge on the lexmark 5650
Nov 23, 2010 | Lexmark X2500 All-In-One Printer
Refilled black cartridge 36 on my 5650 won't work
Feb 02, 2010 | Lexmark X2500 All-In-One Printer
I've refilled my black ink cartridge #36 and put it into my Lexmark 5650. My computer will not let me print - not even to "complete a page" print. It says that I need more ink. I have windows vistas. What...
Lexmark 36 and 37 cartridges cannot be refilled. When your ink levels drop below a certain point your printer deactivates the electronics on your cartridge so you cannot refill them. I own a Cartridge World ink refilling shop and I sell Lexmark originals for the 36 and 37 because of this reason. Unfortunately you purchased a machine that you have to buy expensive original ink for. You need to buy Lexmark original 36 and 37 to get your printer to work. As a refiller I never recommend someone buy a Lexmark printer if they ever want to use refills.
Jan 20, 2010 | Lexmark X5650 ALL-IN-ONE PRINTER
Ink cartridge installation
hi
you can get the user manual with instructions from here
http://images.lexmark.com/publications/pdfs/2007/index/en.html
if your having trouble opening the manual or any other documents install a pdf reader from this page - http://download.cnet.com/Foxit-Reader/3000-10743_4-10313206.html?part=dl-116442&subj=dl&tag=button/
Sep 11, 2009 | Lexmark X1240 All-In-One InkJet Printer
MY LEXMARK 5650 HAS REMOTE FAX ERROR HOW DO I FIX?
I UNPLUGGED THE FAX MACHINE FOR A MINUTE, PLUGGED IT BACK IN AND IT WORKED FINE.
THANKS ANYWAY!
Jun 13, 2009 | Lexmark X4270 All-In-One InkJet Printer
Cartridge error error 50C consult user guide
Hello, error 50c is a cartridge issue. Try taking out, cleaning heads, returning and reprint. Cheers lilacgerry xxx
Dec 02, 2007 | Lexmark X6170 All-In-One InkJet Printer
Lexmark X5150 All-In-One InkJet Printer Logo
50 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
