Question about Brother IntelliFax-2820 Laser Fax
IntelliFax 2820 jams constantly
Hello, For the last couple of months, our Brother IntelliFax machine has been jamming on more or less every page it prints out. Normally, when I get a "paper jam" message, I pull out the paper feed tray, and find that a single sheet of paper has gotten stuck just after being sucked out of the stack. I pull this sheet out, put it back in the stack, then close the tray; another page will print, and then the "paper jam" error will re-appear. Does anyone have any troubleshooting suggestions? Or, is it time to just buy a new machine? Thanks
  • ml20120221 Feb 22, 2012
    This is a duplicate of the other question I just posted. My mistake.
SOURCE: Brother 2820 constant paper jams
Most likely the fuser is worn out, and needs replacement
Posted on Jun 06, 2009
  • 120 Answers
SOURCE: brother 2820 Says clear scanner jam and press stop
Make sure there is nothing caught where the documents go it. List up the scanner cover and look inside. It may need a separator pad or clean the feed rollers with some alcohol. Lawrence
Posted on Apr 23, 2008
SOURCE: Brother Intellifax 2820 JAMMED
Clean the rollers, but also check the drum/toner. at the front there is a peice that breaks on occasion that will cause a jam.
Posted on Dec 17, 2008
  • 30 Answers
SOURCE: paper jam message but there is no paper jammed. opening and closing cover doesn't work.
hi,are you sure no paper jam ok check very very small paper in your machine or clean the sensor.
Posted on May 14, 2009
  • 46 Answers
SOURCE: REPEATED REAR PAPER JAMS-BROTHER INTELLIFAX 2820
Try making prints or copies with the rear door open. If it does not jam your fixing unit (hot area) is functioning properly. With the rear door closed try again making copies or prints. If it jams it's most likely the exit rollers acting up.
1. I've seen the exit sensor break on these units and sometimes the drive gears wear and do not feed properly.
2. If using after market toner or refills this may also coat the exit roller with a film which prevents the exit rollers from feeding parper out by reducing the friction of theses rollers. Clean with fantastic untill cloth does not turn black.
Posted on Sep 03, 2009
I have a Brother IntelliFax 2820 machine that jams repeatedly. A page or two will come through fine and then the others will all jam. Some just jam in the back of the machine and others get stuck in the...
  1. Clean all feed wheels and guides with methylated spirits.
  2. Look for any switch or guide that may be bent or out of place.
  3. Look for any small piece of paper or staple that may have lodged in the paper path somewhere.
  4. Ensure the paper is dry. Not stored in a cupboard in the kitchen or the printer is not setup infront of an air vent.
Nov 11, 2009 | Brother IntelliFax-2820 Laser Fax
Sep 01, 2009 | Brother IntelliFax-2820 Laser Fax
Jun 02, 2009 | Brother IntelliFax-2820 Laser Fax
I have an Intellifax 2820 and there is an error message of paper jam inside... I have cleaned all paper out of machine... please help me
A jam sensor may be stuck by a paper scrap. Try manually pushing a sheet of paper through the machine IN THE DIRECTION IT IS NORMALLY FED. This may force out any stuck scraps. The jam sensors are usually located where the paper feeds and where it exits the machine. Also, make sure ALL ACCESS PANELS YOU OPENED TO CLEAR JAMS ARE CLOSED PROPERLY. Otherwise, the jam code will not clear.
Nov 25, 2008 | Brother IntelliFax-2820 Laser Fax
Paper jams continue to occur on brother fax 2820
Depends on the location of the jam is. Feed wheels need cleaning, clean with windex. or and most likely you have a bad drum unit,
Jul 28, 2008 | Brother IntelliFax-2820 Laser Fax
Brother fax machine Fax-2820 MFC-7225N
Hi. Open the document control panel and look in with a flashlight and see if the jam switch is stuck. also look for a small piece of paper that might be stuck in there. The jam is in where you put documents in to fax out. Lawrence
May 08, 2008 | Brother IntelliFax-2820 Laser Fax
Brother 2820 Says clear scanner jam and press stop
Mar 23, 2008 | Brother IntelliFax-2820 Laser Fax
Brother fax 2820
Out of the lower paper tray when you go to print? Try this, remove the cassette tray and use a water dampened cloth and clean the gray paper pickup roller off. A lot of times this has paper fiber build up that causes the paper not to feed. The printer has a certain timing pattern for when paper should reach a certain sensor, and if it doesn't, then a jam error will occur.
Jul 18, 2007 | Brother IntelliFax-2820 Laser Fax
Brother IntelliFax-2820 Laser Fax Logo
102 people viewed this question
CheckitRight
CheckitRight
Ron Dufek
Ron Dufek
James Cagle
James Cagle
