Question about Car Audio & Video
Hi i have a fli 400s amp the word fli lights up no green or red light and no sound
  • 631 Answers
SOURCE: amp green then red light then nothing problem please help
It sounds like the output transistors have failed. To eliminate other possible problems, read through the following page.
Troubleshooting - Amp in Protect Mode
Let me know if you have any other questions.
Posted on Aug 05, 2008
  • 5 Answers
SOURCE: red light comes on and amp quits working
it is shutting down to protect it self.you either have a short in your wiring or your speakers are wired at an ohm that the amp can not handle.mke sure that they are not wired wrong like + to - is it getting hot?
Posted on Mar 22, 2009
  • 6 Answers
SOURCE: my protection light comes on then my green light then my red every things wired perfect i need a number that can fix class d amps
make sure your wires arent freyed and touching itll protect if any wires touch so ur system doesnt short check all cables from deck and most of all make sure your ground connection is solid if it rattkes aroud itll fry your amp i had the same prob need n e thing else just holler
Posted on Apr 19, 2009
  • 245 Answers
SOURCE: power light turns from green to red protect mode and then there is no sound coming from my speakers
there are 2 reasons for it to be going into protect mode 1 is heat 2 is the load on it. if it is going into protect mode soon after it starts there is a problem with the speaker. if it is after it has been on for a while it is that the amp itself is overheating. hope this answers your question
Posted on Apr 27, 2009
fingaz22
  • 1068 Answers
SOURCE: amp will not put out sound The red light comes on
yes you have a internal fault of the amp. the circuit that puts it into safe mode is bad and that is a very small chip on the board know as a op amp. needs to be repaired.
Posted on Jan 31, 2010
Fli 1000 watt amp red light
sounds like you have a short somewhere , Or bad relay switch
Sep 18, 2013 | Car Audio & Video
No picture or sound with a red flashing power light. Have replaced the convergence IC's but no change (do not have the chirpint sound). Removed main power board & green LED does not light up
On that model the conv IC is usually not the solution. I believe its the blown capacitor problem with is an easy fix. Check the site www.TvRepairKits.com for a repair kit.
Apr 11, 2012 | Hitachi 53UWX10B 53" Rear Projection...
What is blinking red light on top of dash board by wind shield and what is green light on rear view mirror for
The Green one on the rearview sounds like an autodimmer. (tints the rearview mirror from bright headlights behind you) & the Red one on the dash could be an alarm warning light
Feb 24, 2011 | 2003 Ford Explorer
My amp stopped workin, when i turn the stereo on, the green light is on, then when the music starts to play it turns red and stops working,
The red light on amplifier relates to power supply while the green light is indication of sound functionality. An amplifier that allows sound to generate should display both red and green lights. Howeever, some amplifiers would display only green as long as the sound is functioning.
Solving the problem
First, a red light still on means the power connections to the amplifier is fucntional least requirng repairs.
Second, the green ligh should turn on once the stereo were tuned up to produce sound. If the stereo is still on only least produce sound on the amplifier, check on the connection wires between stereo to amplifier that may have disconnected due to woofing or dubbing sound generals with unfirm wiring.
Third,
Jan 28, 2011 | JVC KS-AR7501D Car Amp
SharpShooter won't charge.. instead of Blinking red light (Charging) I'm getting a blinking Green one ????
Hi just got one myself and after a day same problem. Replace all your remote batteries with new ones And it will charge normally with blinking red then red and green blinking. I enjoyed flying it but enough is enough. There is no replacement blades, It eats batteries. I would go with this sites micros http://www.xheli.com/rchelicopter.html
Im looking at this one, charges with usb so wont kill batt's, Metal frame and also they sell parts http://www.xheli.com/s107-miniheli-blue.html. Good luck and happy flying.
Dec 28, 2010 | Air Hogs Havoc Heli Helicopters
Xplod XM-554ZR Car Audio Amplifier: powr/protect light comes on red not green...
Hi, disconnect all speakers from unit and try again - if red light still shows then your amp has died.
If the light goes green, then start testing for shorted speaker/wiring. This includes speaker wiring to vehicle shorts - there should be an o/c reading on your meter
May 05, 2010 | Sony Xplod XM-554ZR Car Audio Amplifier
LG rear projection tv. sound but no picture.
Go to a repair centre, some parts must be fixed/replaced.
Jul 22, 2009 | LG RU-52SZ30 52" Rear Projection...
Amp green then red light then nothing problem please help
Aug 05, 2008 | SPL Dynamics Z2X-1600 Car Audio Amplifier
Car Audio & Video Logo
143 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
