Question about Arris SURFboard Gateway SBG6580 DOCSIS 3.0 Wireless Cable Modem
How to access to router to enable NAT-PMP and/or UPnP
Need to open NAT for Xbox 360. Router is a Belkin DIR-628 and has already been port forwarded...
In order to open NAT settings for the xbox 360 you will need to enable Universal Plug N Play [UPnP]
To enable this setting in the Belkin DIR-628:
1. Log into the router
2. Click on the "Advanced" Menu on top
3. Click on the Enable UPnP: Checkbox
4. Click on the Save Settings Button
May 01, 2011 | Computers & Internet
I have strict nat type and would like to change the nat type to open for my ps3 gaming online experience to be better. myfriends have trouble connecting to me and i have the same vise versa.
You need to access your router and set uPnP to enabled.
to do this you have yo use your browser to access the router - the address for the router will be an Internet Protocol (IP) address.
Log into the router and select uPnP (usually on the security or advanced option)
if you let me know the make and model of your router I can give you more specific instructions.
If your router does not have a uPnP option (and this is very unlikely) again let me know and I can give you detail on port forwarding and how to do it.
Jan 07, 2011 | Belkin (F5D8231-4) Wireless Router...
How do i Enable UPnP, or disable a firewall system, so my NAT type isnt moderate.
you must access your router settings by opening up a browser and typing in your router's IP in the address bar at the top of the page (ex: 192.168.2.1) it will prompt you for a pass, default is usually admin or leave it blank. Once in you shold check you dns and upnp is open
Dec 15, 2010 | Cisco 3640 Router
Change nat type
To reduce the NAT
1 ) Disable the firewall in the router
2) Enable the Playstation in the DMZ
3) Make sure UPnP is Enabled
Mar 31, 2010 | Arris WR850G Router (DHWR850G)
Getting PS3 NAT Type 2 with Netopia Router ???
I have nat type 1 with this router but no upnp. access your router. click on advanced setup, click on configure, click on connection, choose ppp over ethernet llc/snap scroll down and click on save and restart connection. call your internet provider and get the username and password for your router. you will need it later. on your ps3, go to network settings, select internet connection settings. the ps3 will ask if you want to continue, select yes.select custom, wired connection, auto detect, PPPoE, enter the username and password you got from your isp, select automatic, automatic, do not use, enable, then press the x button to save, press the x button again to test connection
May 05, 2009 | Netopia (3347NWG-VGX) Wireless Router...
Dynex-e402 change nat settings to access x-box live
Dynex DX-E402 router, changing NAT settings(UPnP) to access x-box live. go to router settings web page for router, http://192.168.1.1/, enter user name and password to access settings page. user id is usually admin this also for password. under advanced settings click on forwarding. In listed sub-catagories click on UPnp. click enable. this should solve any NAT issues with X-box 360 signing onto x-box live. dynex dx-e402 was very easy to setup.
Mar 24, 2009 | Dynex DX-E401 Router
The nat type for my xbox 360 is set to moderate
Enable UPnP.....UPnP can help make sure NAT works correctly for Xbox LIVE. Usually, this can be set on your router configuration web page, which is supplied by your router manufacturer.
Jan 29, 2009 | Linksys Wireless-G WRT54G Router
Arris SURFboard Gateway SBG6580 DOCSIS 3.0 Wireless Cable Modem Logo
463 people viewed this question
Top Arris Computers & Internet Experts
Jerry
Jerry
jimmy Leo
Are you an Arris Computer and Internet Expert? Answer questions, earn points and help others
