Question about Westinghouse Televison & Video
Is Westinghouse 32" LCD sk-32h635s firmware available?
I also have a smaller Westinghouse that I successfully upgraded the firmware on and would like to do the same to this TV. There's a USB service port but the Westinghouse site doesn't seem to have an upgrade available.
5 Suggested Answers
SOURCE: Westinghouse SK32H240S 32'' LCDHDTV Picture appears and Disappears
This problem is caused from a problem with the main board. The main board will need to be replaced. It runs from $100.00 to $150.00.
Posted on Jun 10, 2009
techman007
  • 1112 Answers
SOURCE: I have a westinghouse LCD tv SK-32H635S. I used
Hi:
If you are using the television with a cable box try looking a format button the the cable boxs remote to change aspect of the pictue. Also try unpluging the unit from the AC outlet for at least two minutes to reset the unit.
Posted on Mar 14, 2010
Testimonial: "Thank you for your help. Using the cable remote to fix the picture size problem did the trick."
SOURCE: westinghouse 32" lcd tv model # sk-19h210s won't turn on
Try unplugging it . Wait a few seconds and plug it in again.
Posted on Mar 23, 2010
SuperTech-11
  • 1591 Answers
SOURCE: Westinghouse 32" LCD TV model SK-32H240S. When the
the high pitched noise is probably coming from a transformer in the unit, which leads me to believe that there's a good chance you have failing electrolytic capacitors either in the power section or the inverter section or both.
Any caps in these sections that look bulged at the top, or bulged/leaking at the bottom need to be replaced.
If you repeatedly turn it on, eventually it'll probably stay on, but every time you turn it off, the TV will get harder and harder to start up until one day it just won't.
Sometimes you have to do the opposite to start it up and unplug it for 5 mins, then try.
If you aren't tech savvy, this unit needs to go in for repair.
If you are handy with a soldering iron and can identify the power supply and inverter / FM section for the backlights, an inexpensive handful of capacitors will likely fix you right up.
Match the capacitance on the capacitors. Go over voltage if you can, and still have them fit.
IE - it's not a bad idea to replace a 10V cap with a 16V or 25V or even a 50V, but don't replace a 680uF cap with a 500uF or a 1000uF (unless you are positive it's only doing ripple filtering).
Most of the caps that go are 10V 1000uF or 3300uF.
I found some great videos of the procedure (for different brand, but same issue) on youtube.
http://www.youtube.com/watch?v=Mm51C_RDIZE
http://www.youtube.com/watch?v=BNHHrgX_6cs&feature=related
http://www.youtube.com/watch?v=8l0AUj8QUkg&NR=1&feature=fvwp
http://www.youtube.com/watch?v=Y7b_nTaZYcU&feature=related
As you can see, this issue spans plasma TVs, as well as large and small LCD TVs and monitors.
The parts are cheap, and skill required is minimal.
Posted on Mar 15, 2011
Starts randemly flipping through tuner channels and won't stop
While it is stable, enter ''menu'' and check ''channels'' menu. Make sure (if you have no antenna) that it is set for ''Cable'' or ''Satellite''.
If problem continues, try unplugging for a _full_ 24 hours, and then do the above.
Ps... If you _do_ have an antenna, set it for ''antenna'' and then select ''scan for channels.'' Do not interrupt process. Allow it to finish on it's own.
May 18, 2015 | Westinghouse 32" Flat Screen Lcd Hdtv,...
What kind of cords do I need in order to hook up my vcr & dvd player?
You will need to consult your manuals, or look at the hookup panels on each type of equipment.
RCA Cables will probably be used between the VCR and TV, and they may also be used for the DVD player.
25540373-ontvtplkga5hki4wstvvghil-1-2.jpg HDMI cables may be required and look like this.
25540373-ontvtplkga5hki4wstvvghil-1-5.jpg Finally, you may see a small square socket which is used for optical cables.
All you need to do is determine what cables will be used based upon what the appliance has to offer, and then procure them and hook the system up. My TV currently uses all three types.
Mar 09, 2015 | Westinghouse 32" Flat Screen Lcd Hdtv,...
Picture for about 30 seconds but has sound. TW-5592W82003990
I would first take a look at the screen with set on in a very dark room with a flashlight---do you see a very faint image or picture? That would indicate a back light issue-----Good luck getting a board, I hear the company is again out of business.
Nov 05, 2012 | Westinghouse 32" Flat Screen Lcd Hdtv,...
It is a 42" Westinghouse SK32H520S and it worked
It is probably a poor connection through the coax. I would replace the coax and that may resolve the issue.
Mar 24, 2011 | Westinghouse SK-32H540S 32 in. LCD TV
Westinghouse 32" lcd tv model # sk-19h210s won't turn on
Mar 23, 2010 | Westinghouse 32" Flat Panel LCD HDTV
Hi:
Mar 14, 2010 | Westinghouse LTV-32w1 32 in. HD-Ready LCD...
What is the latest firmware vesrion available SK32H240S ?
Their isnt any as a matter of Fact westinghouse does not have replacement Display Panels there for making them Non repairable.
Dec 02, 2009 | Westinghouse SK-32H240S Television
Has sound,picture only comes on for a couple seconds at start up.
This is a Backlight Bulb or Inverter (power supply for backlight) failure.
If in warranty, take it to service
You can try to order an Inverter, or if needed you can get a replacement bulb (not easily available)
May 18, 2009 | Westinghouse SK-32H240S Television
Mar 28, 2009 | Westinghouse SK-32H240S Television
Televison & Video Logo
57 people viewed this question
Top Westinghouse Televison & Video Experts
Jaime Hernandez
Are you a Westinghouse Televison and Video Expert? Answer questions, earn points and help others
