Question about Indesit Washing Machines
Indesit WIDL146 start/reset button light flashing with other two programs lights. According to manual unplug the machine from mains for 40 seconds & it should do the trick. But no luck it's keep doing the same thing. Any help would be much appreciated. Thank you
3 Suggested Answers
walesarumi
  • 6993 Answers
SOURCE: Indesit washer drier widl146 does not advance to
First, try the below troubleshooting tips;
Remove any kinks in the drain hose. Ensure that the washer is not sitting on the hose.
Inspect the household drain. Remove clogs, if possible. Check for drainage problems, which can stop the machine from spinning. Make sure the drain hose isn't kinked and that the drain outlet at the wall isn't clogged. Verify that the machine actually drains at the wall drain by listening for the water.
Add one or two similar items to the load if the cycle won't spin; it's possible that the load is too small, and the additional items will help balance the load.
Check the drain and make sure there is an air gap between the hose and drain. An air gap is necessary to prevent the drain hose from siphoning water.
Clean the pump filter. Open the pump access door. Turn the pump filter counter-clockwise and remove it. Remove dirt and debris. Replace the filter and close the pump access door.
Rearrange the clothing in the load. An unbalanced load can prevent the washer from spinning.
Allow the washer to cool down for two hours. If the washer overheats, it will stop the motor and cool down before restarting.
I hope the above helps.
Good luck.
Posted on Mar 07, 2011
blueextc3221
  • 15935 Answers
SOURCE: WIDL146 washing machine issues
It appears your timer/main controller/CCU has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 15, 2010
Indesit widl 146
Firstly look to check nothing is stuck in the pipes as in coins or wire from bras etc..these will always cause problems for the machines... if this isnt the problem it may be a fuse. Or worst case senario one of the boards needs replacing.
Mar 17, 2014 | Washing Machines
Indesit washing machine IWC6165 will not start a wash cycle.
my Indesit washing machine start washing normally taking water and spinning and draining but for each cycle i have to do manual its automatic cycle is not working by it self the way it meant and suppose to be . for example if i start on number 3 to wash it just stay on number 3 not moving to next cycle . plz can anyone knows why this happen .?
Dec 23, 2012 | Indesit Washing Machines
All lights flash on indesit washing machine soon after switch on
Indesit washing machine lights come on briefly when awitched on at mains and then no power
Feb 17, 2010 | Indesit W 123 Front Load Washer
The wash light Indesit DI 67 dish washer is flashhing ?
Try pressing the start button in for 5 seconds, doing this cancells the old program and starts a new one.
Dec 12, 2009 | Indesit 24 in. DI67 Free-standing...
Sep 09, 2009 | Washing Machines
Zanussi 1000XC Washing Machine - Pause Light Flashing
The ECU is failed. unplug for 40 minutes to try to reset it.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Mar 16, 2009 | Washing Machines
Dishwasher indesit DI62
green light 2 flashing sounds like machines doing something switched of at mains & back on to same flashing green light
Mar 01, 2008 | Indesit 18 in. D41 Slim-Line Free-standing...
The door lock flashes constantly - Indesit WIA101
Switch on machine and start its program. While it is running then turn program selector control to TOP position. After a few seconds ALL lights should flash and machine should stop. It ought now to have been reset to normal.
Nov 01, 2007 | Washing Machines
Indesit WIL143S flashing lights
sounds like your power board is damaged. Did you get any washes out of it before it went wrong
Oct 08, 2007 | Washing Machines
Washing Machines Logo
736 people viewed this question
Top Indesit Washing Machines Experts
Gerry Harvey
Gerry Harvey
Darren Moxam
Darren Moxam
Are you an Indesit Washing Machine Expert? Answer questions, earn points and help others
