Question about Refrigerators
Whirlpool Frbb2vaf20 American fridge freezer - Not holding temperature
I have just bought a graded Whirlpool Frbb2vaf20 American Fridge freezer & are having problems with the freezer. It doesn't seem to want to freeze. We put it on the fast freeze & it then flashes -- & it then states the temperature & about 1/2 hour later the alarm beeps & it flashes --. it doesn't freeze anything, however it does produce the ice cubes. We have had this problem since we purchased it 2 days ago. Can anyone help?
  • 2,290 Answers
Get a hold of who ever you purchased it from. It should be under warranty and they should get it working for you.
Posted on Jun 23, 2017
  • 171 Answers
SOURCE: freezer is icing up and
Hi miss_i2000
I'm Harvey the Master Plumber
Your question is: freezer is icing up and fridge temperature has risen to 10 from 5. Also alot of condensation in the fridge and the fan doesnt seem to be working in fridge. Correct temperature on freezer -18 but ice. new frost free fridge freezer bought 1.5 weeks ago
This is no problem for you. You are under warranty and as long as you have not tryed to repair it yourself you are completely covered. Look for the manufacturer's warranty phone number on the paper work that came with it or call the sales man, he will be happy to track that down for you because he wants repeat business.
If you bought it used the only answer is to return it. You could get a local pro to repair it at yuor own expense but I wouldn't recomend that for a frige only 1.5 weeks old!
Feel free contact me again!
Please give me a rating here at before you sign off
Thank you,
Harvey your Master Plumber
Posted on Sep 11, 2008
  • 2651 Answers
SOURCE: Ice maker
sounds a liitle to fast actually, its rated for 8 cubes for "harvest"(cycle, and each cycle problably about 1:45, ittl take a while to fill the bucket , perahps 36-48 hours. once filled though maintains good normal use levels.
Posted on Oct 29, 2008
SOURCE: ice cube maker on daewoo american fridge freezer
Hi i have installed my american fridge freezer DAEWOO FRSU20DC but the ice cube maker don't seem to be working. There is not even any water going in to the ice cube tray but there is water going to the water one. Hope someone can help thanks
Posted on Feb 24, 2010
  • 185 Answers
SOURCE: Ice maker only produces 30 cubes per day (24 hrs) since new.
You probably need more water pressure going to the frig. check that first.!!
Posted on Mar 22, 2010
  • 82 Answers
SOURCE: Fridge Freezer Ice maker problem
If water does not flow into ice maker, first make sure the rubber tube is not blocked with ice.
Next, with the ice maker turned on, open the freezer door and check that the Infrared panel light flashes twice.
If it does, it's an IR panel fault or Ice maker; if it does not, power is not going to it from the rear board.
Posted on Dec 23, 2012
Hi, i need to set temperature for my 6th sense american fridge/freezer.. panel shows -24 deg for freezer and 5 deg for fridge..can you help me pls ?
There are buttons for fridge temperature and freezer temperature on the control panel. Just press the relevant button repeatedly until the temperature you want is displayed.
Jul 15, 2014 | Refrigerators
Whirlpool 6th sense fridge freezer electronic panel - how do i unlock? child lock not on
The lock and unlock feature is accomplished by holding the lock button for 3 seconds, and you will see a count down number just above it that indicates 3, then 2, then 1, and a soft tone along with the lock icon appears. To reverse this hold the same button for 3 seconds following the same procedure and the unlock icon will appear.
Jul 14, 2014 | Whirlpool 25.6 cu. ft. Side-by-Side...
I had probably the same problem. After a little discussion with the factory they sent a technician as a "Good Will Gesture." The technician told me it was the control board down by the compressor. I overheard a conversation between he and his central repair office that it was a common problem. The factory would not admit it. I have a feeling the electronic control board he replace (which would have cost several hundred bucks) was probably made in China. Now I'm having more problems with my Ohio made Whirlpool side-by-side. The freezer is working fine, the fridge is not very cold. By the way, the internal lights was one of the keys to the problems.
May 21, 2009 | Whirlpool ES5FHAXS Side by Side...
Fridge side of American Fridge/ freezer not cooling down.
does the fridge have 2 motors or 1 if it have only 1 motor the gas level in the system are low. if it have 2 motors check if the fridge side motor runs
May 17, 2009 | Samsung Refrigerators
Plumbing in fridge/freezer
That is the water inlet for the ice maker. It is 1/4 inch diameter and will need to connect to a valve of that size with 1/4 inch plastic or copper tubing.
Please rate if this helps-
Mar 23, 2009 | Whirlpool Home
Frost in fridge
you have a defrost problem call service
Mar 01, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
I have a 6 year old American style fridge freezer. In recent times the freezer alarm has been permanently flashing and sounding periodically. The freezer does not appear as cold as it once was and it's...
Hi thanks for the question. first i would clean all the coils at the back. remove panel and clean . then check to see if the fan in freezer works. then see if any Frost has built up on back wall of freezer. if frost on wall, you have a defrost problem. thanks the appliance doc
Oct 01, 2008 | Whirlpool Refrigerators
Flickering display panel on Whirlpool american style fridge/freezer
Also have the same problem of flickering Whirlpool American Fridge Freezer display, which seemed to start when I changed the filter.
Jul 16, 2008 | Whirlpool Refrigerators
Refrigerators Logo
114 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
