Question about Frigidaire FRS26R4A Side by Side Refrigerator
How do i replace the evaporator fan on frigidaire FRS23R4A
  • 61 Answers
REMOVE EVRY THING ON FREEZER TAKE ICE MAKER OUT IF APPLY REMOVE BACK PANEL AND REMOVE FAN AND BLAIT AND INSAL NEW FAN AND REVERS STEPS
Posted on Feb 22, 2012
5 Suggested Answers
peyton32034
  • 410 Answers
SOURCE: Frigidaire Model # FRS23R4A - Not cooling
wihtout replacing the relay there really isnt any way to tell if its the compressor or the relay. the relay is veyr inexpensive in comparison to the compressor usually less than 70 bucks. and the best part is you can replace it yourself as opposed to paying a service company. this is the part number 218721113 and it prices at 38 dollars thru  sears.com.
once you replace the part if the compressor starts you should be ok. if it doesnt start then you will need to call a service company to replae the compressor or look at replaing the refrig. if the unit is less than 5 years old it may be under warranty for the compressor so check into that first. if I can be of further assistance dont hesitate to ask. thanks Peyton
Posted on Mar 10, 2009
  • 358 Answers
SOURCE: compressor doesn't run
If the fan located next to the compresor works that means that the compresor relay is bad or the compresor burned out.
Posted on Jul 19, 2009
heatman101
  • 43501 Answers
SOURCE: frigidaire frs26r4a the freez and
Either the defrost timer or the door switch...
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Posted on Sep 20, 2010
imufo2
  • 3773 Answers
SOURCE: Hello I have frigidaire frs23r4a, when I plug it
NOTE: This
is a multi-solution answer since I don't have all the tech from your question to pinpoint your problem
But the solution is in here generically, if you read and study the solutions very,very carefully.
Sounds like the cold control has stuck . Unplug the two wires from the cold control and plug them together. Turn one wire over and plug it into the other. away from the cold control.
The cold control is the knob in the ref that turns it on and off and has numbers on it. (Thermostat)
If it runs then that cold control (Thernostat) is the problem.
If this doesn't work Do this
The relay on the compressor may need replaced
A relay starts the compressor with a higher voltage and then quickly kicks out
Thats what is happening with yours
Its best for a tech to replace The relay but you can do it
Take your model number to your Local Appliance parts store they will have a diagram
showing you how to install the relay. Its called a hard start relay
also try hooking the two wires together on the cold control to route around the cold control.
If you need more help GO HERE:
http://www.applianceaid.com/procedures.html
Thank you for using fixya
Leo Ponder
PLEASE VOTE FOR ME IF THIS WAS HELPFUL
Posted on Aug 17, 2011
No light in freezer Model FRS20ZRG
Try posting a picture? They are usually somewhere near the evaporator.
Mar 18, 2013 | Frigidaire FRS23R4A Side by Side...
Fridge has a burning smell
Are the coils clean by the compressor?
Nov 26, 2012 | Frigidaire FRS23R4A Side by Side...
Model FRS23R4A - loud humming noise coming from inside freezer section at top behind the ice maker. What might this be?
Somebody hiding in your freezer? Na, I'm just kiddin! Sounds like an evap fan going bad on ya. Eventually you will need to replace the fan!
Thanks and please rate me!
Tips Provided by: www.HoustonRefrigeratorRepair.com Brian Gillespie (GOFAR Services, LLC)
Aug 26, 2011 | Frigidaire FRS23R4A Side by Side...
Frigidaire FRS23R4CW2 side by side refigerator It is running but it is not cold at all. the fan work I check the back of the refigerator. what is the problem.
Hi, if the condenser fan is up and running at the back, what about the compressor? When the fan is on, the compressor should also be on. Place your hand on top of the compressor, but carefully as it could be very HOT if it is locked up! If it is hot, more then likely the compressor has failed and is off on its overload. If you can hear it click on and off so often, it is stuck and tripping on the overload. Check the condenser coil in back to make sure it has no layer of dust covering the front of the coil. This will cause internal pressures in the system to be very high causing the compressor to stop. Check and make sure the fan in the freezer, evaporator fan is also running. Check what I have asked of you and keep me posted.
Sincerely,
Shastalaker7
Feb 03, 2010 | Frigidaire FRS23R4A Side by Side...
I have a frigidaire model#frs23r4a side by side fridge the ice maker makes very little ice and is not working at all now, any repair suggestions ??
Pour about 1/2 cup of water into ice maker . If it dumps , replace the water valve . If doesn't dump , replace the ice maker . Also make sure the coils are clean of dust , lint , etc...thumbs up
Aug 17, 2009 | Frigidaire FRS23R4A Side by Side...
Compressor doesn't run
Jul 18, 2009 | Frigidaire FRS23R4A Side by Side...
Mar 08, 2009 | Frigidaire FRS23R4A Side by Side...
Not Cooling or freezing.
you need to clean the evaporator coil under bottom off refrigerator. and check in the back of refrigerato to see if fan is runing. I not you need a replace it sam
Sep 25, 2007 | Frigidaire FRS23R4A Side by Side...
Frigidaire FRS23R4A
no cool but copressor running
Jun 01, 2007 | Frigidaire FRS23R4A Side by Side...
HELP ME FRIDGE IS BUZZING AND LEAKING
could mean ice build-up on evaporator - buzzing could be fan jammed asgainst ice. remove back panel of freezer to check. this would usually affect fridge as well however
Apr 10, 2007 | Frigidaire FRS23R4A Side by Side...
Frigidaire FRS26R4A Side by Side Refrigerator Logo
53 people viewed this question
Top Frigidaire Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Sal DeAngelo
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
