Gateway M3419 Laptop, just shut down and now won't reboot. I have removed the battery to see if I would work with just the adapter but still not working. I then just used battery only, but again it will not work. The computer comes on... along with the fan and I can open the DVD player by pushing the button. Help!!!
  • 38 Answers
Do you have a restore cd?, If so, put the disc in the drive and try rebooting from the disc. It may work and let you fix the problem
Posted on Oct 27, 2008
Will not power on
MPC has since dissolved, leaving thousands of customers without dedicated support when their Gateway laptop won't start.
Remove the AC adapter from the laptop and attempt to boot the laptop from battery alone. Attempt to turn on the laptop.
Replace the AC adapter and remove the battery from your laptop.
Ensure the adapter is plugged in. Attempt to turn on the laptop.
Disconnect the AC adapter and leave the battery removed from the laptop.
Hold down the power button for 30 seconds.
Nothing should happen on the screen.
Reconnect the AC adapter to the laptop.
Attempt to power on the laptop.
If the laptop boots, replace the battery once the operating system loads.
Try the process again with a new AC adapter and battery if possible.
Contact Gateway support if you aren't a former MPC customer.
Alternatively, take the laptop to a computer specialist if it still won't start.
Nov 19, 2013 | Gateway 17.3" NE71B06u Laptop PC with AMD...
Won t start after dead battery
take out the battery and reboot without the battery in
Oct 23, 2013 | Gateway Computers & Internet
Ms2285 gateway shut down on it's own now it won't restart
Bring it to the computer manufacture gateway to diagnose the problem.
Oct 21, 2012 | Gateway MS2285 15.6in Laptop X2 2GHz 4GB...
How do I reformat the harddrive if windows wont load?? I have a virus and everything froze, so I tried rebooting windows with a cd rom so i could wipe the hard drive, but i get a message that windows...
That sounds like you have a very nasty virus that has infected the memory.
Switch off, unplug and remove the battery.
Using just the AC adapter, place your OS disk in the drive and as the laptop gets to the BIOS option, press F2 or whichever F button lets you in to set your master boot device as DVD/CD Rom.
close the laptop down and remove the AC Adapter.
Plug the AC Adapter back in and boot the laptop, that should get you into the CD ROM disk for formatting and replacing your system. I hope you remember to download all of the required drivers.
Hope this help.
Dec 12, 2010 | Gateway LT2021u Netbook
Laptop will not turn on
try remove your battery n insert again...or try use ac adapter without battery
Jul 31, 2010 | Gateway NV5378u Notebook
Sa1, screen black I can here the cd and HD working but screen stays black. how can I fix? M series gateway. laptop
Please perform the following steps to resolve the issue:
Power drain process:
1. Shut the computer down.
2. Disconnect the AC adapter and remove the battery.
3. Press the power button down for about 30-60 seconds.
4. Reconnect the AC adapter and the battery.
5. Restart the computer.
Alternately you can test your Notebook power by removing and inserting the Memory and Hard-Disk iin their locations.
May 25, 2010 | Computers & Internet
I have a gateway 450rog laptop and the problem is
Yes, it could be the battery is no longer working correctly. To isolate this, try to test your laptop.
1. Remove the battery
2. Connect the power adapter to the laptop and turn the laptop ON.
Once the laptop work without any problem, then it's the battery. You may need to check if the laptop is still under the warranty and have the manufacturer replace the battery.
Have a great day!
Sep 26, 2009 | Gateway Computers & Internet
Abit wireless adapter unable to locate wireless network
well!! I have an answer for you.your comp is loosing the IP address.connect your computer through cable then goto start - programmes - accessories - dos prompt. type`ll get ip address,subnet mask,default gateway.copy it. goto network and sharing center in vista and network connection under control panel in XP,IN Vista,click on view status,goto properties and double click on internet protocol(tcp/ip) or IPv4In XP,right click wireless network connection and goto properties and double click on internet protocol(tcp/ip).type in the IP address,subnet mask,default DNS server address type the default gateway in primary DNS and in secondary your connection won`t drop after this.
Jun 26, 2009 | Abit (WLP-01) Wireless Adapter
My Gateway 7510GX shuts down after ten minutes. I
i think there are two causes for this reason.1/ ur processer fan is not working properly. at that time u should get this message as thearmal heat. then ur computer shutdown. 2/ setting of power option my be fixed 10 minnutes. we should kee poweroption always never shutdown.
Jun 11, 2009 | Gateway 7510GX Notebook
Gateway Laptop M350WVN- not booting at all
it may need to be left on charge for a while...
when u first boot by pressing power wait for a minute or so and press and hold power button til shut down then try reboot..also try boot from disk....need to distinguish whether motherboard or software issue.
Feb 05, 2009 | Gateway Computers & Internet
Computers & Internet Logo
53 people viewed this question
David Payne
David Payne
