Question about GE Profile 26.6 cu. ft. Side-by-Side Refrigerator with Dispenser TFX27PRBWW
I have a 15 year old side by side ge profile refigerator. The floor of the freezer constanly freezes order and leak under the freezer side, What is the cause?
26.6 cu with dispenser
  • 61 Answers
LOOK IN SIDE THE FRZ ON BUTTEM BACK WAY LOW BACK THER A DRAIND AND IS PLUG UP OR FROZER NEED TO UN PLUG TRY TO USE HOT WAER AR A HOT STEMER TO UNPLUG DRAIN.
Posted on Feb 22, 2012
  • 56 Answers
SOURCE: Hello, I have a GE
You can possibly burn out the solenoid valve. There is an off position on the ice maker itself and possibly a switch to turn the power off to the IM.
Posted on Dec 08, 2008
  • 531 Answers
SOURCE: smelly water dispensed from ge profile refrigerator
flush the water tank put a glass press for water and keep flushing on till smell gone
Posted on Mar 31, 2009
erpaalai
  • 999 Answers
SOURCE: GE Profile Series - Side by Side Refrig - No Water Dispensing
Tubing/resevoir is coiled behind the crispers and can freeze.
Eric
Posted on Jun 20, 2009
  • 351 Answers
SOURCE: We need for our GE
whirlpoolpartssurplus.com i can ship it out fast and give you a good price
Posted on Jun 23, 2009
Sea Breeze
  • 4654 Answers
SOURCE: The ice will not dispense from GE profile sid by
The problem could be as simple as the door switch for the lights because the door switch when closed turns the control panel on. Or the problem may be the control board. WR55X129 Control Board Thanks, Sea Breeze
Posted on Jul 23, 2009
GE SIDE BY SIDE MODEL #GSH22JFRE CC FREEZER COIL FREEZING AND REFRIG NOT COOLING. DEFROST MANUALLY AND REFRIG COOLS FOR A COUPLE DAYS, THEN FREEZER COILS FREEZE AGAIN
We have a GE side by side that was only 4 years old before it starting giving us problems-coiling freezing over. The warranty period was only one year on all parts, including the compressor. Through our research we learned that profile appliances have or did have a better warranty. I believe it is 5 years on all or certain components. Either way it may be worth contacting GE customer service to help you with the issue and determine if repairs and parts for your appliance are still covered under warranty. They were very helpful in our case and ultimately discounted the parts I ordered and replaced myself. Replaced the the temperature sensors on the freezer side, the defroster thermostat and defroster heater before finally breaking down and replacing the control board. The control board was the problem. It was very easy to replace. While working through the issue, we would defrost the coils located on the inside of the freezer side with a hair dryer. It would get us by until the parts came in or they frosted over again and prevented air from circulating over them, thus causing the freezer not to cool. Good luck. Hope this helps you.
Nov 23, 2010 | GE Profile 23.1 Cu. Ft. Side-by-Side...
Refigerator is not cooling properly. Temp
Refrigerator or freezer is not cold enough check this part:
* Check the temperature setting
* Assure that there is enough room for air flow in the refrigerator or freezer
* Check for air flow restrictions in vents
* Test the temperature control
* Clean the condensor coils
* Check the door seals
* Test the door switch
* Test defrost heater
* Test defrost timer
* Test evaporator fan
* Check for a clogged drain tube
* Check for refrigerant leak
Mar 28, 2010 | GE Profile Stainless Bottom-Freezer...
Ge side by s
found norcold #160107210--new #160107200-----on E-Bay ,under RV Thermostate-----thru seller---- eastcoastrv---Lexington,South Carolina
Oct 26, 2009 | GE Refrigerators
GE profile counter depth side by side stopped
Is the compressor coming on at all? If not a capacitor may be bad .
Jul 05, 2009 | GE GSH22JFR Side by Side Refrigerator
GE SIDE BY SIDE FREEZER LEAKS
There is a fix and I have seen it done. Yes GE will not pay for this but if you are willing to spend the time to do a few things to keep it from freezing. Appliance Parts and Repair just below your link and myself can point you in the right direction on how to repair your defrost drain entrance from freezing over. Thanks, Sea Breeze
Jun 16, 2009 | GE Profile Arctica Stainless Steel Top...
Fan in freezer under ice maker won't stop running.
Hi yes the fan blade could be hitting the shield or ice, remove the fan cover & check
Dec 23, 2008 | GE Profile PSW26P Stainless Steel Side by...
Freezer leaking on Ge Profile
The drain is frozen over and water cannot escape when it defrosts. You will need to remove the back panel inside the freezer and run some hot water down the drain until it has thawed. Hope this helps
Sep 24, 2008 | Refrigerators
Fan keeps freezing
HI .did you pull the fridge, away from the wall, and clean out the drain tube ,at the back. if not pull fridge away from wall, find the drain tube, and clean. thanks the appliance doc
Aug 04, 2008 | GE PDS22SBRLSS Bottom Freezer Refrigerator
Water leaking - GE Profile Refrigerator, Model: TPX21PRX
Check to see if the drain at the bottom of your freezer is plugged. When the refrigerator goes on defrost, the water has to go somewhere. Look below the coils in the freezer section and see if there is ice in the drain.
Jul 15, 2008 | GE Profile 20.7 cu. ft. CustomStyle...
Ge profile leaks from front of freezer
your drain will be plugged under the tray. there is a hose that runs to the drip tray. the back cover comes off you can then get at the hose
Sep 05, 2007 | GE GSS25JEMWW Side by Side
Refrigerators Logo
70 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
Charles T Nevin
Charles T Nevin
RepairNinja
RepairNinja
