Question about Garmin StreetPilot c340 GPS Receiver
Broken power button
The power button broke on my Garmin Street Pilot 340 and will not turn on. Garmin wants 150.00 to have it sent to them for repair. My c340 is only 1 1/2 yrs old and I can not see spending 150.00 to repair it, considering a new one cost 179.00 online and by the way, I paid 499.00 when I bought it.
where can I can get the power button repaired without costing me an arm and a leg?
  • mebason Nov 07, 2008
    Somewhat helpful. I e-mailed Geek Squad to see if they repair GPS'S and waitng a return. I might pass on gettng it repaired, because I bought a new GPS
  • Anonymous Dec 28, 2008
    well, Ihave the exact same issue
  • 502 Answers
If you're into self repairing things it may be worth it prying the switch open to see if you can replace the switche's membrane, or short the switch to see if it is really the powerbutton that is causing the problem. If all else fails there's a couple of repair services that specialize on gps repairs www.portatronics.com being one of them.
Posted on Nov 13, 2008
I would see what the geek squad at best buy would charge.
Posted on Nov 05, 2008
Do you have to change the batteries in a GPS C- 340?
The battery should last a long time but eventually it will not hold a charge. Here is a very helpful link on how to change the battery if needed.
Thanks for using FixYa
http://www.batteryeducation.com/2010/08/garmin-street-pilot-c340-battery-installation-instructions.html
Jul 16, 2011 | Garmin GPS
Garmin 340 street pilot
Remove the battery out and put back in after 5 minutes to reset it.
, check also that the in car power cable is working, and the Garmin is not drained. Tru to connect it to power outlet if you have an adapter
Mar 29, 2008 | Garmin StreetPilot c340 GPS Receiver
HI, MY GARMON STREET PILOT C 340 IS NOT WORKING, IT JUST SAYS, SEARCHING FOR SATTELITE MY SON IS IN WILDWOOD NJ AND HAS THIS PROBLEM WITH IT
Give Garmin Technical Assistance a call. They will run you through a series of diagnostic and reset button sequences to try. The unit may just be faulty; in either case you will find out after the diagnostics are performed.
Jun 23, 2011 | Garmin nuvi 350 GPS Receiver
Our garmin street pilot c330 tells us the battery is dead when it's plugged in and then goes blank. Can this type of battery be replaced?
yes the battery needs to be replaced, even when the GPS has external power the battery must be good for it to work,
May 15, 2010 | Garmin StreetPilot C330 GPS Receiver
How do I change the batter in a Garmin Street
Hi! You may need to change the fuse periodically, which is at the tip of the adopter! regarding battery, you may need to contact waste disposal section for disposing the unit since it contains lithium. Don't consider much presence of high amount heat and direct sun rays at new battery for longer duration and have fine
Dec 21, 2009 | Garmin StreetPilot C330 GPS Receiver
My garmin 340 suddenly stopped working
Ummmmm "Low battery"....... not too hard to figure out. You need to charge it for several hours. If the battery is low it WILL go out on you and during that time, the battery may recover enough to come on briefly then go off again. Please charge your battery!
- Jim
Sep 13, 2008 | GPS
Garmin street pilot c340 battery appeared low, used USB cable to hook up pilot with my computer but device doesn't appear to turn on, computer cannot locate device on Drivers, can I rechare steet pilot...
I followed the instructions of the Online manual for the Garmin Street Pilot c-340, I removed the faceplate of the Street Pilot and then using my thumb pressed down on the reset button. I then pressed the power on button on the side of the device- the screen lit up, I then plugged one end of the USB cable into my computer and the other end into the device. The information on the screen of the device indicated the Lithium Battery was charging properly.
Jul 14, 2008 | Garmin GPS
I cannot even tunr on my brand new fresh out of the box street pilot 340? Any ideas?
there is a red button on the side of the unit, hold that and the unit will come on.
Nov 28, 2007 | Garmin StreetPilot c340 GPS Receiver
Garmin 340 streetpilot won't even turn on?
I had the same issue with mine during a trip. Probably needs to be reset. See page 31 of the users manual on Resetting your c340. Once I did this it worked fine.
http://www8.garmin.com/manuals/StreetPilotc340_OwnersManual.pdf
Garmin StreetPilot c340 GPS Receiver Logo
241 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
