Question about JVC RA-P11 Portable Audio System - Made Remote Control, Speaker System for iPod ( Black )
I want to put a JVC KD-R320 in my 2005 Toyota Corolla LE
I would like to install this JVC head unit in my 05' Corolla, but the wiring in the oem is really messed up. The colors dont even seem like they match. Any advice?
  • Kraig Pierce Feb 21, 2012
    i didnt mean to put the JVC RA-P11 as the display.... sorry
  • 149 Answers
SOURCE: JVC KD NX 5000 NAV UNIT NOT CALIBRATING TO MY LOCATION
If youve rigged it to watch dvd's while moving. the sat nav thinks the parking brake is on and wont move. The vss cable needs to be connected as well.
Posted on Mar 17, 2008
etirbynnor
  • 655 Answers
SOURCE: color codes for my jvc arsenal kd-ar560 wire harness
Hello jlj2382,
Here's the wire colors for your KD-AR560:
Black = Ground (to vehicle chassis)
Yellow = Constant 12V (power)
Red = Accessory (to vehicle accessory terminal)
Blue/White = Remote turn-on lead (to remote amp)
Orange/White = Illumination (to vehicle light control switch)
Brown = Cell Phone terminal
White = Left Front Speaker positive (+)
White/Black = Left Front Speaker negative (-)
Gray = Right Front Speaker positive (+)
Gray/Black = Right Front Speaker negative (-)
Green = Left Rear Speaker positive (+)
Green/Black = Left Rear Speaker negative (-)
Violet = Right Rear Speaker positive (+)
Violet/Black = Right Rear Speaker negative (-)
Hope this helps.
Posted on Apr 24, 2009
etirbynnor
  • 655 Answers
SOURCE: How to wire car speaker to JVC CD Receiver.
Hello anstrayer,
On your JVC wiring harness the speaker wire colors are:
Left front (+) - White
Left front (-) - White/Black
Right front (+) - Gray
Right front (-) - Gray/Black
Left rear (+) - Green
Left rear (-) - Green/Black
Right rear (+) - Purple
Right rear (-) - Purple/Black
You can download a the manual from Crutchfield. A complete wiring diagram with color codes is on page 41.
Hope this helps.
Posted on Jun 01, 2009
  • 52 Answers
SOURCE: JVC KD-AVX 40 compatiable USB H/Drive
You can use any non powered USB drive (gains its power from usb only). You just have to plug it into your PC and select Properties > Format then make sure you format it in FAT12, 16 or most commonly (recommended) FAT32 file system.
Once you've done this you can transfer all your music onto it then plug it into the USB port lead from the back of the head unit
Posted on Jul 02, 2009
SOURCE: one rca jack for subwoofer (jvc kd-avx44)
I run this set up im runng a 1000 rms Alpine and 2 alpine type S and everys good
Posted on Jan 25, 2010
My jvc kd-r520 will not turn on. It's as if
make sure the fuse in the fuse box is good then check the relay to the radio is good ( factory relay ) if all thats ok, check the fuse on the backside of the head unit.....
then while the head unit is out check the wires to make sure a mouse did not bite any wires...
Feb 24, 2012 | JVC Car Audio & Video
After market receiver periodically resets itself (JVC KD-DV5300)
In KD-DV5300, replace capacitor C751. Capacitors dry with age.
Feb 16, 2012 | JVC Car Audio & Video
I have just installed my JVC KD-R720 in dash reciever in my 1999 Pontiac grand am and also have subwoofers. The amp turns on but i am getting nothing to the subs. I know its not the amps connection cause...
Check a few things. Make sure the head unit is getting power. Then make sure that your RCA cables are connected to the right output RCA's fromt the head unit. If this is ok, check to make sure the RCA cables didn't get crimped somewhere. If this is still all ok, check the volume on the unit and to see if you have the unit on mute. Sometimes it's little things like that. Did you adjust any settings to the amp? If so, check the gains. Hope this helps.
Aug 18, 2011 | JVC Car Audio & Video
Why does my jvc kd-r526 reset to factory default everytime i turn it off
Try connecting the yellow wire to a constant power source. That is, a source that still has power when the key is turned off. The yellow wire controls the memory of the radio.
Jun 02, 2011 | JVC KD-R800 Car CD/ MP3 Player
I have jvc car audio model # kd-g335 how to connect my sub woofer?
You can not connect the subwoofer directly to your head unit. You need an amplifier installed to play the sub woofer. Asuming that there is an amplifier installed then: If your head unit has an RCA output on the rear, connect that to the LINE IN of your amplifier. Also there should be a Blue&White cable at the rear of the head unit.(amplifier remote) That should be connected the the remote terminal on the amplifier. (this will turn the amp on and off when the head unit turns on or off) Hope this helps. dreamsystems
Feb 08, 2011 | JVC KD-G340 Car CD/ MP3 Player
How to install an amp on a jvc kd-avx77
How do I install a set or a sub to this head unit with only one wire output marked sub,I'm not sure if may amp will play correct.
Dec 03, 2010 | JVC Car Audio & Video
Install JVC KD-G351 into a toyota corolla 1998
if you go to your local audio store they should sell a kit to wire in your radio, so you dont have to cut any wire on your car it will just plug right in to the factory wiring
Dec 29, 2008 | Kenwood KDC-MP335 CD Player
JVC RA-P11 Portable Audio System - Made Remote Control, Speaker System for iPod ( Black ) Logo
27 people viewed this question
Top JVC Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a JVC Audio Player and Recorder Expert? Answer questions, earn points and help others
