Question about Maytag MFI2266AES Stainless Steel Bottom Freezer French Door Refrigerator
No ice refrigerator freezes runs constantly - Maytag MFI2266AES Stainless Steel Bottom Freezer French Door Refrigerator
  • nancyhowe9
    nancyhowe9 Feb 25, 2012
    The ice maker quit making ice but we still have water. What are the default setting for the freezer / frig. We lost the manual.
  • 61 Answers
SOME OF THIS NEW REF THE FAN WILL RUN CONSTANTLY IS NORMAN THEY USE VERY LITTLE ELECTRICYTY TO KEEP THE COPRESER FROM RUNING TO LONG.PART OF THR ENERGY STAR. THE ICE MAKER MAY BE BROKEN OR NOT GETING WATER. OTHER TINK CK THE ICE CREAM OR FROSEN JUCES TO SEE IF THERY ARE FROZEN HARD IF THE ARE SOFT THE MEENS THE FREZER IS NOT COOLING GOOD AND I/M WILL NOT MAKE ANY ICE IF IT NOT BELOW 10 DEGREES
Posted on Feb 22, 2012
I have a Kenmore 26' Freestanding Dispenser Side-by-side Refrigerator, Model #596.50692000. I opened the freezer door to find melting ice and thawing food. The warmth started at the top of the...
Hi there
Sounds like bad news I'm afraid.
The freezer evaporator fan runs constantly until the freezer is at temperature.
The chiller fan only runs until the fridge is cold.
If the defrost timer is operating correctly it should only go on defrost about every 6 hours
It is more likely to be the temperature controller
You will need toget a new one.
Regards
Gordon
Apr 22, 2011 | Kenmore Refrigerators
Why is everything in the refrigerator freezing, and, why doesn't the door & doors (side-by-side) close tight?
Sounds like your door or doors are being held open by an object inside. This is causing the cooling system to run constantly and thus freezing items in the fridge. Check that the shelf under the ice drawer is overpacked. the dispenser runs inro things on the shelf right under that storage compartment occasionally on my fridge. Hope that helps.
Jan 28, 2011 | Frigidaire FRS26H5AS Side by Side...
Icemaker not working- red light flashes constantly
The red light should flash twice , pause then flash twice constantly . If you close the flap on the left side , then the light should go off . This shows the optics (ice maker cut off ) are good .
Check the black tube ( fill tube ) , which puts water into the ice maker , to see if it is iced inside . If so , then the water valve behind the refrig is bad . It seeps into the tube and freezes , blocking the water flow .
Pour about 2/3 cup of water into the ice maker . If it freezes and dumps , then the water valve needs replaced . If it doesn't dump , and stays frozen in the ice maker , replace the ice maker . Also , make sure the coils under the front of the refrig are clean , as this will cause warmer temp in the freezer and the ice maker needs 5 degrees to operate .
Sep 27, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
Freezer runs constantly and ices up
It sounds like the thermostat has failed. Have it replaced and it should take care of your problem. Hope this helps, good luck!
Sep 02, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Ice is constantly freezing up in door. I
Hello Frozen Up! Sorry about the freezing problem. Do you and your family use a lot of crushed ice? If so, get used to the freezing up! The same thing happens to our Maytag with crushed ice and we normally clean it out every evening after a day of using a lot of crushed ice. As far as I know, there are no recalls, just happy that we have crushed ice at our disposal. Hope this helps! Ella
Aug 18, 2009 | KitchenAid Superba Architect KSCS25INSS...
Freezer not freezing properly
You have a manual defrost freezer . Ice build up of over 1/2" can act like insulation on wires . If you have no frost build up , and runs constantly , then compressor or refrigerant leak is the problem . Advise to replace freezer . Only 2 parts on manual defrost freezer...compressor and cold control . Compressor will not run if bad cold control . If you have a leak , very expensive to have repaired .
Jul 10, 2009 | Whirlpool GD2SHGX Refrigerator
Ice maker freezing up
its a confirm defrost timer problem.the defrost timer is a device which after every interval of 8 hours defrosts the freezer part if the timer is faulty it wont defrost and go on over freezing.you can buy the defrost timer for aprox 30 dollars from link below:http://www.repairclinic.com/thanks and plse do not forget to rate the solution.
Jun 12, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
Bottom freezer "on" but not freezing and not making ice
Refrigerator running but not that cold, freezer running also but not freezing at all. Also not making Ice
May 17, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Ice dispenser freezes
check your ice dispenser door flap,is it coming all the way down?there is a solinard that opens and closes it,it might be going bad,if you can get in to it it might just need alittle lube,what make?let me know what you find-mike
Oct 16, 2008 | Kenmore 53642 / 53644 Side by Side...
Maytag MFI2266AES Stainless Steel Bottom Freezer French Door Refrigerator Logo
169 people viewed this question
Top Maytag Refrigerators Experts
Bailey's...
Bailey's...
isaac johny
isaac johny
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
