Question about Brother MFC-8860DN All-In-One Laser Printer
MFC-8860DN I have a Brother MFC-8860. I am getting a "No Paper" message even though there is plenty of paper in the paper tray. I have tried changing the drum since I had the message that the drum life was near the end for quite a while, but the copier kept working fine. I have also tried unplugging the machine for several minutes. When I turn the machine back on, it looks like it is going to be fine and then when it goes to feed the paper, I get the "No Paper" message again. I have tried cleaning the paper tray also. Any ideas?
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 56 Answers
This is a common issue.
Here is the solution:
Pull out the paper tray
On the left of the feed roller there is a black piece of plastic that is a sensor. It is jammed forward. Gently bend it out to the left and push it back until it snaps back into place.
Be careful not to break it.
Posted on Jan 15, 2009
Printer makes a horrible sound when trying to print also the blue button on the right side making a loud clicking noise. the paper won't feed.8860 dn
I have had the exact same problem. The problem is in the tray. It won't raise the paper properly despite how much paper you have in it. Make sure that all of the springs are there, and that the plastic sensors are correct.
I've found it useful to just buy another tray. You can find it as low as $30-35.
It's a very typical mechanical problem, but most likely resolved by changing the tray.
Apr 01, 2011 | Brother MFC-8860DN Printer
When I try to print a document, the printer is saying "No Paper" and the yellow light is flashing. However there is plenty of paper in the tray. When I open the tray and replace it, the printer...
It sounds like 1 or 2 paper sensors are out of place, Brother has a bulletin about this problem. You can call Brother at 877-276-8437 to find a Brother repair center.
Feb 18, 2011 | Brother MFC-8860DN Printer
Brother mfc-8480dn no paper error I have a new brother laser printer and it is telling me there is "No Paper" but the paper tray has paper. I have tried removing the paper and reloading the tray...
Open the file you are trying to print, go to "file", "page setup", "Paper" and choose "Default tray" under paper source. It may give you an error message that the margins are outside of the paper. Click on "Fix this", then you can print. I had the same problem.
Jan 12, 2011 | Brother MFC-8860DN Printer
I am having a problem with the paper tray for Brother MFC 8860 dn printer - The paper tray clicks when it is printing a page and then says there is no paper in the paper tray or that a page is jammed -...
The paper is not feeding from the paper tray. The loud click is alarming, but not the problem. Check the adjustments in the paper tray. The left and right guides should be snug, but the rear guide should give between a 1/16 inch and a 1/8 inch of free play. If the rear guide is tight, that is the problem. You can check for this by depressing the lever on the right front of the tray. Depressing the lever should raise the stack of paper out of the tray so that it can slide forward.
If you remove the paper from the tray, but will see calibration marks for the paper size you are using. Unlock the read paper guide n the tray, squeeze the release and move the guide ot the mark for the size paper you are using. For example, it you are using letter size paper, the read guide should point to "LTR".
Oct 13, 2010 | Brother MFC-8860DN Printer
Brother MFC 8860: Display reads
I have exactly the same problem with my Brother 1250 mono laser printer.
Any solution yet?
May 11, 2010 | Brother MFC-8860DN Printer
Brother MFC 8860DN. ''No Paper'' error message and CLICKING SOUND
Pull the paper tray out, look in the top middle by the roller holder, you will see a black plastic lever (edge actuator) hanging down, it should be flush with the roller, be careful when pushing back in place.
Feb 01, 2010 | Brother MFC-8860DN Printer
No Paper Error
make sure you have an 1/8" gap between your paper and the rear paper stopper in cassette.
hth,
razors
May 27, 2009 | Brother MFC-8860DN Printer
No paper in traY
make sure the tray is set for letter size, many times the handle moves and the settings on the tray change, so the paper moves back to the settings of legal paper, so when the printer tries to load paper, it cant.
Apr 13, 2009 | Brother MFC-9440CN Laser Printer
NO paper light
Something worth considering: Check that there is enough slack in the paper tray to allow the gears at the front to lift the paper to the pickup wheel. I've found that on my firm's 8860DN, the paper tray being set too "tight" can cause too much friction, preventing it from moving. If you can raise/lower it by hand (using the gears on the side of the tray), you should be fine.
Dec 04, 2007 | Brother MFC-8860DN Printer
Brother MFC-8860DN All-In-One Laser Printer Logo
535 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
