Question about Packard Bell Computers & Internet
What's wrong with a laptop that has no light inside it?
  • 4 Answers
If there is no light coming from your screen, but you can still see Windows displayed very faintly, then the backlight or inverter probably needs replacing! If you plug an external monitor into the VGA port & can see a normal picture, then it's usually a backlight/inverter problem.
Posted on Feb 21, 2012
After 7 yrs of use, it just stopped working
I agree that It could be one of the other reasons listed here.....
But, I had the same problem with a 1,000 watt Kenwood amplifier and it worked like a boss for the whole two years that I had it and then one day the box that I had my subs in somehow came apart and after I changed out boxes the amp quit working. It came on but it wouldn't work anymore except for when I turned it a certain way or sat it against something.. Anyway it ended up being a loose female port plug on the inside where the auxilary cables plug up.
Hope it helps.
May 11, 2013 | Clarion APA4320 Car Audio Amplifier
Maintenance call indicator light is blinking on my Minolta 1083, how do I get rid of it?
The light is a counter inside the copier that needs to be reset by a service tech after replacing the drum & developer in the copier. If it is working let it go till there is a problem.... Good Luck
Oct 09, 2012 | Minolta EP1083 CS/PRO Copier
My amp protection light came on one day. Now it won't turn on. What's wrong?
There is more than likely an issue with your amp, it could've happened from a wire being shorted to ground or a damaged sub causing bizarre impedance issues at your amp. Uninstal it and have it bench tested.
Jun 03, 2012 | Rockford Fosgate Power T1000-4 Amplifier
Screen on presario 2500 is black blank and won't change
If your laptop appears to boot up and the hard disk LEDflashes, then the problem is probably a back light fault. This can be a faultyinverter or a faulty CCFL lamp. Please click on this link and follow myinstructions to identify the fault and possible fix :- http://www.fixya.com/support/r3598095-faulty_laptop_lcd_screen
May 19, 2012 | HP Compaq Business Notebook NX9010
I have wired up my kicker ds 65 (two of them) they were playing now they don't ..what's wrong with them??
Does your amplifier power light come on? Is the amplifier Protect light on? If the Protect light is on, there is either a shorted wire or an internal fault with the amp. Else check your wires inside and outside the sub box/speaker box and check for resistance across your sub terminals to check for blown subs/speakers.
I’m happy to help further over the phone at https://www.6ya.com/expert/jeremy_69f3cc28d95bf514
Oct 01, 2011 | 2001 Honda Civic
I have a sony 1000w zr1852. The power and ground cables touched at the amp. I fixed the connection but now the power save light is on. what could be wrong? thanks
Sounds like there's either some fuses blown, or a short circuit happened inside the amp. However usually they're pretty good about not shorting out. Check your connection at the battery, In-line Fuse, Cap, Distro, and Amp and make sure everything is connected fine. Check the Alternator in your car to make sure it's outputting the right voltages, and the battery to make sure it's between 12V - 14V. I've had some weird things happen over the years with my Car Audio, and it always ends up being wires or fuses.
Jul 04, 2011 | Car Audio & Video
Computers & Internet Logo
104 people viewed this question
Top Packard Bell Computers & Internet Experts
Alun Cox
carey w mason
carey w mason
Are you a Packard Bell Computer and Internet Expert? Answer questions, earn points and help others
