Question about Nokia 7205 Intrigue Holster wSwivel
Remove sim card on Nokia 7205 - Nokia 7205 Intrigue Holster wSwivel
How to i find sims card in my nokia 7205
Posted on Oct 09, 2012
Need to remove sim card
Nokia Lumia 920 has a SIM tray on the top of it. You need a needle or a clip to open it.
If you need to put in a different SIM card in the device you should first make sure it is unlocked to the network provider. SIM unlocking will enable you to use your device with other SIM cards from other carriers. To Unlock Nokia Lumia 920 you need an unlock code. Follow the Link to know more about Nokia Unlocking.
Apr 22, 2013 | Nokia Lumia 920
I look into the phone nokia 7205 but i cant find where to insert sim
Usually the SIM card goes underneath the battery, remove the phone's battery than look for a metal or plastic door, it is usually behind that small door, if not there look for an other cover you can remove...
Mar 22, 2011 | Computers & Internet
How to remove sim card from nokia c7
RIGHT SOLUTION: To remove the SIM-card, press the SIM-card a bit further down the slot (with another sim-card, a memory card, your nails if they're long enough,...) and then release the pressure. The SIM-card will come out far enough for you to pull it back out.
Feb 28, 2011 | Nokia C7 (8 GB) Smartphone
Dropped in toilet
Congratulations!!! remove every parts you can i.e. battery, SIM card and memory card. Make sure each and every single drop of water is out. Wrap the mobile phone thick with a piece of cloth and keep it on a warm place ( Not too warm ) like Above the TV( thats the best i can suggest) for couple of days, 3-4 days will be sufficient. Make sure you don't switch it ON while its wet otherwise the Flash IC might get fried by the battery. After 3-4days of evaporating the water from your Mobile, keep fingers crossed and switch ON the Mobile. If switched ON perfectly for 10-15 minutes (try checking all the feature in this time period) the mobile phone is in good status and if it doesn't kindly purchase a new Phone because i won't suggest you to get it repaired as once Nokia phone goes for a repairing it will always ask for repairing after 2-3 months.
May 05, 2010 | Nokia Intrigue 7205 Cell Phone
Need programming codes for Nokia 7205
Is there a specific reason you need the code? The following are the most common nokia programming codes: On the main screen type in:
*#06# for checking the IMEI
*#7780# reset to factory settings.
*#67705646# This will clear the LCD display
*#0000# To view software version.
*#2820# Bluetooth device address.
*#746025625# Sim clock allowed status.
#pw+1234567890+1# Shows if sim have restrictions.
*#92702689# - takes you to a secret menu where you may find some of the information below:
1. Displays Serial Number.
2. Displays the Month and Year of Manufacture
3. Displays (if there) the date where the phone was purchased (MMYY)
4. Displays the date of the last repair - if found (0000)
5. Shows life timer of phone (time passes since last start)
*#3370# - Enhanced Full Rate Codec (EFR) activation. Increase signal strength, better signal reception. It also help if u want to use GPRS and the service is not responding or too slow. Phone battery will drain faster though.
*#3370* - (EFR) deactivation. Phone will automatically restart. Increase battery life by 30% because phone receives less signal from network.
*#4720# - Half Rate Codec activation.
*#4720* - Half Rate Codec deactivation.
Hope this helps, Joe
Feb 19, 2010 | Nokia Intrigue 7205 Cell Phone
How do I get the sim card out of a 3100 nokia
1.remove the back panel
2.remove battery
3.remove sim lock
by this you can remove your sim out from your phone.
*but switch off your phone before removing your battery.
Dec 15, 2008 | Nokia 6010
Nokia 7205 Intrigue Holster wSwivel Logo
107 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
