Question about Hardware & Accessories
How to program a timex timer model #12874 (TX12874X)
5 Suggested Answers
SOURCE: cannot get the timer to
Open following links for available Timex manuals:
http://waterheatertimer.org/pdf/How-to-program-Timex-TX12874X.pdf
http://waterheatertimer.org/Woods-timers-and-manuals.html#Timex
Posted on Aug 23, 2011
  • 5089 Answers
SOURCE: instructions for programming timex timer Model tm120wp
Open following link to download possible manual:
Posted on Jun 25, 2012
  • 5089 Answers
SOURCE: need instructions to program a timex indoor timer model #tm120wp
turn on your tablet connect any keyboard.then use keyboard.go to setting and reset it.its very simple solution.
Posted on Jul 01, 2012
bw29
Some of the later Timex timers have slightly different operation. If yours (like mine) has an all-white case:
1. After programming the time, press the ON and OFF buttons together to return to Auto-ON Mode.
2. Press TIME + ON to manually turn the timer on.
3. Press TIME + OFF to manually turn the timer off.
Posted on Dec 22, 2014
Need instructions to program a timex indoor timer model #tm120wp
Jun 14, 2012 | Timex Indoor Timer Multi Setting...
How to use the TM 111D
1) To use the timer:
Make sure outlet has power.
Check outlet with circuit analyzer to make sure polarity issues do not affect timer operation.
Plug timer into outlet for 1 hour until battery is charged.
Some timers have internal battery that do not need to be charged.
After battery is charged, unplug timer to set programs.
Set program(s).
Turn lamp ON and make sure bulb is good.
Leave lamp turned ON
Plug lamp into timer.
Then plug timer into outlet.
2) To program the timer, open following links for possible instruction manuals:
http://waterheatertimer.org/pdf/How-to-program-Timex-TE111.pdf
Take a moment and rate answer:
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Sep 02, 2011 | Timex EASY TO SET TIMER BY TIMEX
I have a timer TX12674T im trying to reset the time by holding time and hour the screen resets itself to 12:00 any combination will rest the screen. what to do?
Timer is not identified.
My files, and web search do not show TX12674T timer, Aug 2011.
1) Add a comment with in-focus photo of your timer posted on flickr for possible identification.
2) I don't have repair for defective timer: What does your instruction manual say? Did timer work before and stop working? Are you using timer for correct Load? Try timer on different outlet and with different Load. Test outlet with circuit analyzer. Timers usually come with 1 year limited warranty.
3) Maybe you have TX12874X. This timer is reset by holding down Hour and Minute button.
4) Open following link to identify timer and download possible manual:
Aug 13, 2011 | Timex EASY TO SET TIMER BY TIMEX
I have a model #Te111(TX12677T), I am having a problem with programming this Timex light timer. I can get the time on, however when I try to program each day it will not hold it's memory. Help ...
Open following link to identify timer and download manual:
If the manual does not match product, then add a comment with clear description of timer and what you have done so far to set timer so I can see problem clearly.
If timer will not hold programming, then try resetting timer if it has a reset button.
If timer has battery, remove battery and replace with new battery, and try resetting timer in that manner.
If functionality is not restored, then move timer to different outlet and connect to different lamp.
And always test outlet with cheap circuit analyzer from home center.
Outlets that are out of code can affect electronics including timers.
If outlet checks out, then timer is probably defective.
Most timers have 1 year limited warranty.
Intermatic DT620 has limited lifetime warranty and might be better value long-term
http://waterheatertimer.org/Intermatic-timers-and-manuals.html#digital
Woods 59377 is nice timer sold under different brand names at Lowes, Target, on-line:
http://www.amazon.com/Woods-59377-Digital-Appliance-Settings/dp/B000IKQRTU/ref=pd_sim_dbs_k_1
http://waterheatertimer.org/How-to-program-Utilitec-0155671.html
Jul 26, 2011 | Hardware & Accessories
Need manuel for timex timer modle 0551,need manuel
Open following link for Timex manuals that might include yours:
Upvote the help.
May 18, 2011 | Day-Timer Timex Electronic Digital 7day...
I can not reset my Timex timer . The timer stopped working after a month and the instructions to not help in programing these timers
The instructions will help quite a lot right now:
1) Typical Timex manual says to re-set timer, press MODE and PROG buttons together.
Compare this information with your instructions.
2) Look on instruction sheet for timer model number, and then add a comment with your model number so I can identify timer manual and possibly post answer that fits your product.
3) Look on instruction sheet for company information.
Timex timers come with standard 1 year limited warranty:
Following phone might work: 1-800-919-3101
4) Scan your instruction sheet into jpg format and then add a comment with link to that jpg, then I can give you best answer for that specific timer.
http://www.fixya.com/support/r6568559-post_photograph_fixya_questions_answers
5) Buy another timer, and return broken timer in new package.
6) Use circuit analyzer to test outlet for line noise and ground fault that affect timer electronics.
7) Buy another brand of timer altogether:
http://waterheatertimer.org/GE-timers-and-manuals.html
Add a comment with your experience so others with same-similar problem can benefit.
Also take advantage of fixya expert assistance live.
Mar 31, 2011 | Timex EASY TO SET TIMER BY TIMEX
How to reset the programming on timex lamp timer TX12694TA
For some Timex timers, press PROG and MODE at same time to reset timer.
Open following link for random Timex manuals:
Jul 14, 2010 | Hardware & Accessories
LOST THE SETTING INSTRUCTIONS OF MY TIMEX MODEL NO. 12/874 (TX12874X)
I couldn't find a manual for your Timex, but here are the setting instructions:
Clear the timer by pushing hour and minute at same time. To set current time, hold time button down and push hour. Then hold time button down and push minute.
To set the time for light to turn on, hold the ON button down and push hour until it gets to the hour you want it on (same for Minute). To set time for light to go off, hold the OFF button down while you set the hour and minute.
Nov 30, 2009 | Timex Hardware & Accessories
Hardware & Accessories Logo
130 people viewed this question
Top Hardware & Accessories Experts
Gene Haynes
Hippy_dd
Are you a Hardware and Accessory Expert? Answer questions, earn points and help others
