Question about Garden
Jcb digger arm wont lift
Why wont arm lift bucket
4 Suggested Answers
SOURCE: JCB 801.4 mini digger - no control of digger arm
We have a similar problem on a Mitsubishi MM55SR.
We developed a new control set-up
Posted on Aug 07, 2009
simontricket
  • 235 Answers
SOURCE: jcb over heating after 20 min,s there water in the digger
Clean the rad core with air and get a new thermostat .
Posted on Jan 02, 2010
  • 3600 Answers
SOURCE: how to fill up hydrolic oil on mf fermek 1.5 ton
Should have a pin on one side front or back and should raise straight up if that does not help let me know and I will get back to you. Thanks for using fix-ya.
Posted on Jan 19, 2010
What type lubricant is used in jcb js200l escavator.
where in motor ?hyd fluid? grease in bucket and boom arms?
Sep 27, 2014 | Cars & Trucks
Jcb digger no power to arm
the wire on the safety arm might be grounding out, join the wire to a new live
Aug 19, 2013 | Garden
Jcb jz70 throttle problems
is this a vehicle or JCB digger ?? more details please
Jul 24, 2013 | Cars & Trucks
EX58Mu hitachi Excavator will not lift main boom arm all other hyd actions work well
Is it leaking any fluid. Spool valve may have a blown seal.
Jan 29, 2013 | Garden
Hi i have a 3 tone komatsu digger the ram before the bucket had a leak it was quite bad and the ram would not stretch out you had to get the digger and slowly use the bucket to pull the arm out i have...
Obviously I can't tell for sure but it sure sounds like the ram might be slighly bent therefore it will push hard against one side of the packing not allowing it to extend easily. In time it wears out the packing causing a leak. When you had it proffessionally done it most likely received new packing kit which could make the problem slightly worse because the fresh packing will be a little tighter than the packing that was replaced.
If not a bent ram then you may have a bad releif valve in that peticular hydraulic circut that doesn't close, or open which ever the case might be, thereby not pressuring up the end of the cylinder that pushes the ram out.
Mike
Apr 07, 2011 | Computers & Internet
How to fill up hydrolic oil on mf fermek 1.5 ton mini digger the filler point is under the arm rest. i cant seam to move the arm rest and the filler plug wont lift out because the arm rest is in the way. i...
Jan 19, 2010 | Garden
Looking for JCB 803 Digger Manual
Speak to JCB and ask them to fax over the parts breakdown for this block. It's aluminium, and we had a split in the block which a specialist welder repaired for us. It has to be a specialist otherwise the block will twist or distort and the many little rubber seals will not work properly afterwards. Worth getting a new seal kit from jcb, about £80 i think.
Jun 28, 2009 | Garden
Jcb over heating after 20 min,s there water in the digger
Apr 20, 2009 | Garden
JCB 803 Workshop Manual
I am looking for one as well - did you find one?
Mar 21, 2009 | General Garden
Mar 17, 2009 | Garden
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
