Question about Mantis Garden
I messed with my carb adjustments and now runs like ****..
    Sergeant:
  • 316 Answers
Hello sir,, now there are two types of carb.adjustment screw covers,the old one where there are plastic over the screws,simple remove the plastic covers with a pair of needle nose pliers or cutting off,,,second are the new ones that are above the adjustment screws,which you have to take your drummel tool with the cutting blade and cut slots in the screws, after you get this done it is important to count the number of rotations in until stops make note how many. because you are going to reset the same way.now remove the screws,put to the side when you get ready to put screws in put in all the way than back out as many turns that you noted, now that is factory set there should only be a small adjustment to do. the rule of thumb is turn both out 1 1/4 turn and adjust in until saw runs smooth and idles ok, it is hard to adjust the top speed when saw is running wide open,let saw idle when adjusting top speed is easier that way, when you go to cut wood you may have to readjust top speed, the above does apply some what if you are not using fresh gas mix and dumped out the old fuel and starting with fresh,and a new plug CJ8Y,and as you know the saw has to breath in and out by this i mean a clean air filter,make sure the small screen on the muffler is not cloged,this will keep saw from running at peak speed and sawing wood, ok i have ran across a few saws to where the small screen in the muffler is cloged so the saw would idle but not run at high rpm's,if you do and check all of the above your saw should run,oh btw check compression should be above 60 to 160 lbs, hope this helps,any comments welcome,thank you. ~~
Posted on Feb 23, 2012
I replaced gaskets and fuel lines now when i prime bulb gas runs out of carb,also need factory settings for H-L and throttle,i know i messed up somewhere?realy need my saw running,thanks
take apart your carb--sounds like your carb diaphram is not installed right the settings should be
1.5 turn out low jet
1 turn out high jet
that should get it running then some fine adjustment once its running
Sep 04, 2015 | Poulan P3314 14Inch 33cc 2Cycle Gas...
Solo 662 chainsaw carburetor adjustment
most non professional grade or smaller saws are only adjustable by re jetting the carb. if they are adjustable there will be a low, high and idle adjustment on the side of the carb, however unless you have a portable tach and know the rpm limits or are experienced doing it "by ear" i wouldnt suggesting messing with it as youll more than likely burn up the power head.
Jan 08, 2014 | Solo 662 667 Chainsaw Carb Carburetor
L100 john deere runs but has erradic idle, okay when blades engaged???
Never mess with the air adjuster .. If it was set correctly once It should never need messing with. Now you have another variable to the problem. More then likely the fuel Jet has some obstruction in it. Drop the fuel bowl and take the Jet out and clean it.
Sep 27, 2012 | John Deere 420,1020,2010,2020,2510,2520...
My 98 suzuki vz800 marauder sputters at low speeds but cruises great is this carb adjustment, fuel air mixture or sync
Could be a combo of all. Replace your spark plugs sync carbs, and run it to see how it responds before you mess with the mixtures. Also check for any vacuum leaks. Hope this helps.
Jul 29, 2011 | 1998 Suzuki VZ 800 Marauder
Starts runs but high speed or on tree runs rough like gas problem
there are two adjustment screws on the carb that you can mess with it sounds like it is out of adjustment a little bit one should say hi the other lo try the high adjustment count the number of turns so it can go back where it was
Jan 07, 2011 | Husqvarna , No.455 Rancher, 20" Gas -...
Runs when choked. cuts out on full throttle. Is there a carb adjustment?
yes there is but most of the time u don't need to mess with it just take the carb off and clean all the jets with eater gas or carb cleaner and that should fix the pro
Aug 03, 2010 | Garden
My chain saw will not start. I gave it to a guy who messed up the carb adjustments. Need to know the initial carb setting.
Turn both jet screws CW to stops (lightly), then back each out CCW 1-1/2 turns. This is a basic setting and should allow the engine to start and run. Start the engine and allow to warm up, then pull the throttle full on. Turn the H needle CW until the engine starts to speed up, but still 4-strokes. Correct adjustment is when the engine 4-strokes running free, but immediately 2-strokes when cutting. Release the throttle and adjust L needle so that the engine idles fairly well, but allows the engine to 'follow the throttle'. Adjust idle speed screw so that the chain stops turning, but the engine continues to run. Hope this helps!
Jul 11, 2010 | Husqvarna Craftsman 36cc, 16 In. Gas Chain...
Whats the best and easiest way to set the carbs on a 1990 yamaha radian yx600
Your problem is probably the sycronizing as long as you havent messed with the fuel screw or jetting. If you dont have a set of vacuum guages you can eyeball the slides in the carbs to at least get you by and you can usually get them pretty close. Find the carb that is directly linked to the cable. the other carbs are adjustable to that carb so you need to make all the other carbs identical to that one. Look at the gap from the bottom of the slide to the bottom of the bore of the carb on that base carb with the throttle at idle bike not running. With the adjustments on the linkage to the other carbs adjust the other slides to the same height as that base carb as close as you can. Measure if possible to get all the carbs as close as possible to each other. you may have to adjust the idle after. If the adjustments on the carbs are all cables, for example there is a cable to each carb directly connected to the slide just adjust each cable accordingly and achieve the same as above. make sure you have a little freeplay at the throttle when you are done. you can adjust that by the cable adjustment by the throttle which will keep all the carbs in sync
Jul 29, 2009 | 1990 Yamaha XJ 600
2005 yamaha yzf 250-unstable idle
I had the same problem, Turns out that my shims were finished, replace the chims and check clearences.
Mar 12, 2009 | 2004 Yamaha YZ 450 F
Garden Logo
320 people viewed this question
Top Mantis Garden Experts
paulfvincent
Matt Olenzek
Matt Olenzek
Mike Squire
Are you a Mantis Garden Expert? Answer questions, earn points and help others
