Question about Hitachi Deskstar 7K80 Hard Disk 80GB, 7200RPM, ATA-6, 2MB Cache, Desktop, 20PACK (HDS728080PLAT200A3021020PK) Hard Drive
Trying to get data off an IDE drive from a dead system
I have tried pluggin this IDE 80 Gig Hitachi Deskstar drive into a system running Win/98 as well as Win/XP. I have tried it as a master and a slave. In all cases the most I get is the drive is recognized at the BIOS but is never acknowledged at the OS. When I make it the master on the XP system, it sees it at the post but immediately goes to a 'windows did not start successfully' dialog and loops back to a screen to choose safe mode or start windows normally,,,,,I don't think the drive is hosed,,,I just can't seem to get it recognized at the OS of any box.....
  • 38 Answers
This MS link will help you configure it so you can read it
http://support.microsoft.com/kb/309000
Posted on Oct 27, 2008
I have a Deskstar 80GB hard drive and I am adding another drive to the computer. How do I set the Deskstar to the Master. I'm not sure what the pin settings should be?
If you have the EIDE cables on your PC, it is easy. Your drives need to have their jumpers in the CBL SEL (cable select) positions (identified on the case on the sticker) and then you simply connect your Deskstar to the Master connector, and your other drive to the Slave connector.
Feb 12, 2011 | Hitachi 80GB IDE Hitechi DeskStar 7K160...
I have delete the logical drive in disk management. my hitachi 40GB IDE hdd is not detected in diskmanagement, and i cannot format that drive. ple. help me
The hard disk is not detected, inaccessible or unreadable because of possible hardware failure, corruption and/ or I/O errors.
To troubleshoot this issue, restart the computer or rescan the disk to try and return the disk to Online
To rescan the disk, open Computer Management, and then click status. Disk Management. On the Action menu, click Rescan Disks.
Just make sure ide cable is fixed properly to the hard drive when scanning.
Feb 04, 2011 | Hitachi Deskstar 7K250 80 GB IDE Hard...
Re built XP system on a WD ide drive - worked fine. When I added a 2nd drive (a Hitachi deskstar which works fine on another system) the system hangs after detecting drives. Both drives' details are...
Please try attaching the desktar at a different cable aside from the master, use another cable,attaching it to another IDE cable. In short, dont have the WD and the deskstar on one IDE ribbon.
Oct 20, 2010 | Gigabyte GA-8PE800 PRO Motherboard
Hard desk can't dectet the hard desk
I would recommend TechRx, inc. for a free exam of the drive. The Hitachi Deskstar drive has some unique featues that allow a data recovery company to do firmware repair easier than other brands of drives. When a drive is not detected, it could be due to NVRAM corruption on the drive. If you find my answer helpful, please leave feedback/rank.
http://techrxgb.com
Aug 17, 2010 | Hitachi Deskstar 7K250 80 GB IDE Hard...
At boot up my Hitachi Hard drive clicks once. Not shown in BIOS
Sounds like a system area problem. If you want to send it to us at TechRx, Inc. we can take a look for you. Free estimates http://techrxgb.com
May 14, 2010 | Hitachi 80GB IDE Hitechi DeskStar 7K160...
I am assuming that this is the hard drive in the computer. Try a safe boot up to see if you can get to the hard drive. use the F8 key at startup for safe mode.
Mar 24, 2010 | Hitachi 80GB IDE Hitechi DeskStar 7K160...
I want put my Hitachi Deskstar 7K250 80GB Hard Drive from a t2885 emachines on a HP/Compaq K8N8X-LA mother board without losing my data.
You won't loose your data Why wold you think you would? once data is written to a hard drive it remains there until it is removed be a user, it works on the same principlea a floppy, the magnetic coating on the surface of the anodized disks inside of the HD are written to and retain memory of the data, the only things in a computer that won't keep their data are the RAM chips which need electricity running through them to work.
Dec 07, 2009 | Hitachi Deskstar 7K250 80GB...
Cloned hard drive "C" (WD 40GB) to A Deskstar 8oGB using external enclosure. When I remove the old drive and install new drive and boot up I get Msg drive 0 not found retry or enter setup. If I enter setup...
there are few thing you ahve to keep in mind
there are two type of hard disk
1. IDE
2. SATA
As per your hdd capacity it should of IDE type.
Now there are two IDE slots on motherboard. One is Primary and other is Secondary
You can fix two hdd with one IDE Slot that mean you can fix up upto faour IDE hdd at a time
Now again there are Primary master and Primary Slave
and
Secondary Master and Secondary Slave
Now You have to examine what was the location of previous hdd
1 Primary Master
2 Primary Slave
3 Secondary Master
4 Secondary Slave.
Now you have to make a HDD master or Slave.
just in between data cable connector and power cable connector there is a jumper. that specify the master or slave. do reply me if it works well thanks
Oct 01, 2009 | Hitachi Deskstar 7K250 80GB...
Recover Data from Hitachi Deskstar (Model: HDP725050GLA360)
IDE and ATA are synonymous to one another for the most part. It will work. Jason
Feb 28, 2009 | Hitachi Deskstar 7K500 500 GB Hard Drive
Computer
Because different computers have different internal parts. The operating system may not know about things inside of the other computer.
Dec 14, 2008 | Hitachi 80GB IDE Hitechi DeskStar 7K160...
Computers & Internet Logo
522 people viewed this question
Top Hitachi Computers & Internet Experts
Alun Cox
Are you a Hitachi Computer and Internet Expert? Answer questions, earn points and help others
