Carver CT-6 Tuner/preamp - LED display is failing. Symptoms include long time to warm up and the display is very faint at best. Thanks! Craig.
4 Suggested Answers
Gurudristi
  • 98 Answers
SOURCE: Connecting NAD 314 Receiver\ preamp to Carver M-500t to speakers
Dear Tim,
Yes, you can connect your NAD as a preamp to the Carver power Amp.
Connect the NAD's pre-out to the input of the Carver Power Amp. You can then connect the Klipsch speaker to the Carver. Set the gain control on the NAD.
Now you should be able to control all the input and the main volume control from the NAD.
Posted on Mar 12, 2009
petraman7
  • 1175 Answers
SOURCE: Carver CT-17 Preamp Power Cap Values
Hi John...
Are the caps completely destroyed?
http://www.free-service-manuals.com/Audio___Hi_Fi/Carver/index.html
For $14.00 / 3 months D/L as many as 3 manuals a day.
I use it A LOT.
Cheers,
Scott in Verrrrrrrrrrrrrrmont
Posted on Mar 24, 2009
SOURCE: Carver preamp has no output
This is most likely caused by a failed Audio output amplifier, or perhaps there is a fault with the power supply, and it isn't suppling enough current to make it work correctly, there really is no simple way of determining this without troubleshooting, from the power supply outwards.
if you wish to DIY, then you must obtain a service manual and use that to troubleshoot the problems, usually it is replacement of parts that's required, if they can even be obtained.. Or get it looked at by a competent service center, always ask for a "Quote' for any repair before proceeding, this way at least you can make an informed decision as to what to do, repair or replace.
Posted on Feb 10, 2011
Carver TFM 35 amp what is the best way to hook it to a Marantz AV8003 pre app
No. You should use the line(or preamp output) to the Carver input. The only way you could use the tape output is if the Carver has input volume controls.
Dec 21, 2014 | Marantz Audio Players & Recorders
How to hook up a Marantz AZ8003 pre amp to a carver TFM 35 a.m.
Please see my last few comments on the same issue. If you can't find it, please let me know. BTW, Marantz does not show the AZ8003 to be a valid model.
Carver ct 17
You don't. Unless you open it up and put in a switch. These lights are part of the look.
Aug 26, 2014 | Audio Players & Recorders
Carver CT-28v Tuner preamp - Has a hum/buzz (soundls like a ground loop) that is heard as soon as the unit is turned on. Does not increase with volume, just stays the same and is continuous. Changing...
Reverse the polarity of the AC plug and try it. Is there a headphone jack on the preamp? Try headphones with the preamp standalone without the amp attached.
Are you sure the preamp is the problem? I assume you also have an amp or you wouldn't hear anything. Power up the amp with nothing but speakers attached. Hum??? It's in the amp. No Hum? Attach just the preamp with no external components. Hum now? It's the CT-28. Turn it off an exercise every switch and knob throughout its range numerous times. Try again. Still humming? Manipulate source selections, Tape Monitor, everything.
Nov 19, 2009 | Audio Players & Recorders
Hi John...
I use it A LOT.
Cheers,
Mar 23, 2009 | Audio Players & Recorders
Carver C11 preamp problem
I found out through the Carver Audio forums that metal shavings inside the case are an issue with this unit. So I used an achohol based spray and cleaned the switchs and the circuit board, (there was a fair amount of shavings found). It has been running for 14 hours with no problems.
Aug 02, 2008 | Audio Players & Recorders
302 people viewed this question
 Grubhead
Grubhead
