PS3 to samsung LE40N87 bdx/xeu via Samsung AV-R720
Hello everyone newbie here so please be patient.
I have purchased a Samsung LCD TV LE40N8 and have connected it to Samsung AV - R720 unit via HDMI from HDMI out socket to HDMI1 socket on the TV.
I have V+box (in HDMI 2 - satellite) on the back of my AV unit and also PS3 connected via (HDMI 1 DVD socket) to the AV unit.
All the HDMI are the latest Cambridge Audio and have been tested on other equipment>>>
OK so now for my problem. When I turn on my PS3 select the output from my AV unit to DVD the AV unit selects and picks up the PS3 output but I get a blue screen and a message-saying mode not supported. To solve this I have to put the TV on stand by and then back on for it to pick up the signal.
Does anyone have any ideas as to why this might be and any idea how to solve this problem as it is getting on my t**s now.
Thanks in advance
5 Suggested Answers
  • 20 Answers
SOURCE: HDMI connection problem
On your TV set remote are you selecting the proper input; for example when you have different devices connected to the back of your tv set, dvd player, vcr, cable box etc; you have to tell the tv which device you want to use by selecting the right one on your tv remove input selection. Hope this was any help.
Posted on Sep 08, 2007
SOURCE: the settings on my samsung
i have read about this problem when searching for tv reviews. The problem i believe is the tv is in shop mode. This is whats used for tvs being shown in store which can be played with so the settings reset every day. You need to go into the settings and change from shop to home. Not sure where you change this but it comes up on initial setup. Hope this helps.
Posted on Jun 17, 2008
  • 4 Answers
SOURCE: PS3 not recognized by Mitsubishi WD=52525 tv through HDMI
FYI,
PS3 has output settings and would need to be adjusted if you are coming from the RCA input. Check out www.sony.com/ps3 trouble shooting under display problems. I believe the solution is to turn on the PS3 unit and keep holding the I/O button for more than 5 seconds. I had the same issue going the other way.
Good Luck.
Posted on Jan 10, 2009
SOURCE: I have an Onn 15''
The LCD should have a Source button.This will select the AV input.Using the right arrow instead of "OK" button should help select your input.
Posted on Mar 20, 2009
  • 265 Answers
SOURCE: HDMI PORT STOPPED WORKING!!
the best option here is connect via a standard PS2 avi cable or componet cable until your tech guy comes out!
Posted on Apr 30, 2009
Change tv/video mode for samsung pck 520 r home theater
look for function on remote or an inbound arrow icon and square or tv/av button and press it till u see av 1 or av 2 or dvd and u are ready to watch video via your samsung hmoe theater
Jul 14, 2013 | Samsung Televison & Video
Apr 30, 2009 | Televison & Video
Hi,I have a Samsung LCD TV -Model LE40R82BX/XEU.The display is cracked and I have Rainbow colors down one side of it.I can take the tv apart and I want to put in a new LCD.Any ideas of a good cheap site[s]...
Unfortunately, the LCD panel itself may cost more than a replacement set. Check in your local area for a Samsung parts distributor. They should be able to provide you with the part number and cost for the replacement.
Dan
Dec 31, 2008 | Televison & Video
Please advise if you would be able to guide me as to where i could purchase tv parts...
Hello MMJB,
Here are the link to purchase your parts.
674e151.gifhttp://www.partstore.com/Part/MCM+Electronics/MCM/LA7845/New.aspx
183b00b.jpghttp://www.partstore.com/Part/Matsushita/JVC/TDA6111Q/New.aspx
4509847.jpghttp://www.partstore.com/Part/Samsung/Samsung/HCN653WX/Samsung/Samsung/0502001230/New.aspx
Best regards
circuitcity
Jul 09, 2008 | Samsung HCN653W 65" Rear Projection...
The settings on my samsung tv keep reseting them selfs its a LE37 R87 / R88 BDX/XEU
Jun 09, 2008 | Samsung Televison & Video
1080p high def issues
The HDMI cable I had originally wasn't a good enough quality. I purchased an HDMI v1.3 cable and everything works at 1080p. You don't need to pay loads for a cable, got mine from Play for £9.99.
Mar 29, 2008 | Televison & Video
NEED SIGNAL PANEL FOR SAMSUNG LCD TV MODEL LE32R87BDX/XEU
www.partsstore.com is a certified distributor for samsung just enter the make and model number of your set and it will bring up all the parts they carry. They usually have circuit boards for samsung
Mar 12, 2008 | Televison & Video
SAMSUNG 19 INCH HD READY WIDESCREEN LCD TV LE19R71BX/XEU
We will need a list of the everything you tried.
Usually, this kind of thing is caused by hookup errors.
Dec 27, 2007 | Samsung HLN617W 61" Rear Projection HDTV
Televison & Video Logo
309 people viewed this question
Top Televison & Video Experts
Electro Med Services...
