Question about Makita Tools & Hardware - Others
Red and green flashing lights on 18v lxt charger
When I plug the my batteries into the charger I get an alternating red and green flashing light and the battery will not charge. Bother batteries were fine and showed no sign of degradation. Are they shot? Is this common?
  • Makita Master
  • 885 Answers
Batteries don't always look degraded but if they've been in use for a while or have a bad cell, they will show up bad on the charger and it won't charge them. The only way to test the batteries is to try to charge them on another charger. If the batteries show defective on another charger, they are bad and you'll have to replace them. Also try to charge some batteries you know to be good on your charger to see if it's the problem. If your batteries charge on another charger, your current charger is bad and they don't have any replaceable parts in them so you'd be looking at replacing it.
Posted on Feb 23, 2012
Battery charger red charging light blinks once then goes out
Do the batteries charge? Are they charged? The green indicator normally is the status signal that the battery is charged and the red indicates that the battery needs charging or is charging. If you plug in a charged battery, some chargers will flash red momentarily then go out. This is an indication that the charger checked the battery (red light) and if the charge is good, the red light will go out. I hope this helps you.
Oct 24, 2017 | Hilti Drills
Red light flashing on charger
A red light indicates the charger is charging the battery, an amber light means it has switched from fast rate charging to trickle to keep the battery topped off, and green would mean the battery is completely charged. But don't be fooled waiting for green, many times the charger will only be on green for a moment before changing to amber and keeping the battery topped off.
Flashing can be a sign of a problem on some chargers.
A rapid flashing red can on some chargers indicate a bad or shorted battery, or a bad battery contact in the charger itself. If in question, try a different battery on the charger or compare with another charger to determine if the blinking is normal.
Best regards.
Nov 19, 2013 | Motorola htn9042a charger,120v,single unit
Green flashing light
battery is open circuit or charger not working Re: Jeff
Apr 07, 2012 | Makita 18V LXT Lithium - Ion Cordless...
RYOBI CHARGER RED AND GREEN FLASHING LIGHT
Try rotating the plug that goes into the wall. I know it sounds irrelevant but ive had the same issue and it worked for me. The positive and negative may be reversed in the dock.
Jan 04, 2012 | Ryobi Multi-Volt Battery Charger
Makita DC18RA Makstar Li ion Charger three lights
Alternate Red and Green flashing means bad battery. Buy a new one, or take it to a Makita Service center for replacement if it's under warranty.
Normally the yellow light indicates hot battery, but it could also mean dirty battery contacts so the heat sensor can't be read, or that the fan is clogged with dust and unable to cool the battery. The manual says let the battery cool and try again. If the yellow still flashes, it's contacts or the fan.
Read the manual online at:
http://www.makita.ca/data/upload/accessorypbim/417_im_english.pdf
Oct 28, 2011 | Makita 2 Bl1830 18v Battery,dc18ra Charger...
M28 battery is flashing green and red when put on v28 milwaukee charger
Is the battery hot or cold??? either temp. extreme will do that...
otherwise the battery is shorted internally and so the charger will not charge it...the battery will need to be replaced.
heatman101
May 21, 2011 | Milwaukee Tool Milwaukee V28 1/2" Hammer -...
Pronto M6 chair will not work. When the power switch is turned on, the LED light flash Red followed by three Green. I can't find what this error code meas.... Pls Help thanks Phil
Phil the red means battery is low and the green is a speed limit code because of the low battery if you have charged your batteries and you still get the red then you need to check the charger after charging all night does the yellow light on the charger turn green? if when you first plug in the charger if the red light is on and the other light is green then there is a problem with the wiring or connection to the batteries from the charger and you aren't charging the batteries. if when you plug the charger in and you get a red and yellow light then the charger is working but you don't ever ge a green light and the battery level gauge is still showing red then you need to replace the batteries Hope this helps
Apr 12, 2011 | Invacare Supply Group Pronto M61 Standard...
Red and green light flashing on 5 of my bl11830 battaries and they will not take a charge
If you put a battery on your charger and both red and green lights flash it is indicating that battery is defective. There may be a short in the battery or they just may be too old and worn out to charge anymore. If the charger is reading the battery as defective it will not charge the battery. The only fix is to buy new batteries.
Jan 20, 2011 | Makita 2 Bl1830 18v Battery,dc18ra Charger...
Tools & Hardware - Others Logo
358 people viewed this question
Top Makita Tools & Hardware - Others Experts
Jim Thurston
John Porter
Are you a Makita Tool and Hardware - Other Expert? Answer questions, earn points and help others
