Question about Saeco Classico Espresso Machine
Machine is not making coffee - Saeco Classico Espresso Machine
  • Saeco Master
  • 1,711 Answers
We need some information to be able to help can you describe what is does and what not, do you have water without coffee in it, does it turn on at all, does it heat up, do you get hot water or steam
Posted on Feb 25, 2012
Every time I meke coffee my machine have swill sound and don't make full amount of coffee
Many times when a coffee machine is not working properly, it needs to be cleaned. Pour 1/2 & 1/2 White vinegar and water into machine as if you making the coffee, and turn machine on. It make two treatments t clean out the machine. You can then use some baking soda in water to neutrlize the vinigar.
May 07, 2014 | West Bend 55108 Espresso/coffee Maker
Ok so I have never had or tried iced coffee or latte. I have had coffee and a latter before and loved it. So how do I make iced coffee or latte. I don't have any syrup or anything, i have milk, cream, ice...
Making a good iced coffee is the same as making a good hot coffee except that you put the coffee in the refrigerator and add ice to the cooled coffee. To make the best iced coffee, don't use lousy coffee. so you can't really make that without an espresso machine.
Oct 03, 2013 | Keurig B60 Coffee Maker
Problem with espresso machine
make sure your coffee grind is not too fine. try a coarser grind. imagine two bucket, one with fine sand and one with gravel. the water will travel faster through the gravel. if this works then slowly make the grind finer until creme returns on your espresso. also try descaling the machine.
Jul 14, 2013 | Estro Barista Athena
It only makes one size coffee. When you hit the
my machine is the antony worrall thompson espresso coffee maker breville
Nov 22, 2009 | Keurig Elite B40 Coffee Maker
Coffee not hot enough Is there a way to modify the factory settings to make coffee/milk warmer for the Nespresso Latissima machine?
Before placing first coffee capsule in the machine, run the large espresso cup button into a cup (clear water will come out). This primes the machine and makes for hotter coffee.
Oct 03, 2009 | Nespresso Lattissima 660.R
Grinding coffee but water not making coffee
Check to make sure the quantity button has not been reprogrammed. To do so, push and hold the coffee button until coffee flows through. Also be sure to check the brew-unit. In some cases if the b-unit is plugged, it will not allow water to flow through. Also check to be sure you are not grinding too fine, if coffee is too fine it too will plug the chamber...........Hope it helps.
Steven,
info@northwestkitchenware.com
Jun 30, 2009 | Saeco Royal Digital Plus Coffee...
No coffee
Make sure the water pipe not is broken.
If you take out the brewing unit and look at the chassis on the machine, you can see a hole, there should be a little plastic pipe comming from the machine down to the hole. If this is broken then the water will go to the driptray.
/Mirran
Aug 14, 2008 | Saeco Vienna De Luxe Espresso Machine
Does not stop making coffee
The machine has a reset capability to set the amount of coffee. Just push and hold the button for as long as you want coffee. Then let go of the button and it's reset.
Jul 13, 2008 | Nespresso C100B Essenza Single-Serve...
Saeco Classico Espresso Machine Logo
29 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
espressofixr
Level 1 Expert
83bj60
Level 1 Expert
Shehu Pro
Shehu Pro
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
