Question about Maytag Kitchen Ranges
Mgr5775qdw this matag gas range model #MGR5775QDW all five burners work broiler works oven will not warm up digital temp control starts reads 100 flame does not light got any answers for me ?
jsrock516
  • 5911 Answers
SOURCE: AMytag MGR5775QDW Gas Range
I am assuming the BROILER works fine in the oven, right? If so, you may have a bad igniter for the BAKE manifold. It is common for them to wear out or become weak. Since the BROILER is not commonly used as much as the BAKE function, the BAKE igniter tends to wear out faster. You can check the igniter by removing the bottom plate of the oven, exposing the BAKE manifold. There will be a glow bar type igniter that begins to glow when the turn the oven on to preheat. If the igniter does not glow...a resistance reading will determine if it still good or not. It should read a low resistance if good. If the igniter glows, but still does not ignite, take a current reading. The igniter will have a current reading of 3.2 to 3.7 amps if good. In either case, if you do not get the desired readings, simply replace the igniter. There are two types of igniters listed under your model number:
Horizontal Mount - Part: #1034629 Price: $44.50
Vertical Mount - Part: #949510 Price: $41.70
This depends on how yours is mounted. Refer to your owners manual to see if there is a parts index listing. I hope this helps you. Post back with comments if I can assist any further.
CAUTION: Make sure you disconnect power from the range BEFORE connecting meter leads to the igniter leads. The igniter connector is usually found under the oven behind the lower drawer. In addition: if you DO purchase a new igniter, use care in handling it. The oil from your hands can potentially damage the igniter coil if you are not careful. This will result in a shorter life expectancy.
Posted on Jan 30, 2008
TheMobilian
  • 8220 Answers
SOURCE: maytag model mgr5775qdw range oven will not light
Probably a weak ignitor. Check THIS out
Posted on May 14, 2009
sawdust46694
  • 398 Answers
SOURCE: How to install a hancle on the oven door of a matag range?
Ok open the door to about 1/3 of the way the door will rest there when you let go. Now pull straght up on the door. The door will slide right off. Pull the screws out that hold the door together. look at the bottom of the door then look on both sides for screws. remove them all. Pull the door apart and you can get to the screws that hold the handle on.
Good Day Hope this helps.
Sawdust46
Posted on Aug 26, 2009
  • 106 Answers
SOURCE: oven will not ignite
if the ignitor glows but no gas you just need a new ignitor. If its not hot enough the gas will not come on. Or no glow it mayhave just burned out
Posted on Nov 21, 2009
  • 119 Answers
SOURCE: My maytag MGR5775QDW gas stove-the burners work
YOU NEED TO REPLACE IGNITOR
Posted on Jan 31, 2010
I have a maytag model # mgr5775qdw and the oven will not ignite. I know it is not the gas line as the burners all light, and the broiler lights as well. It is only the oven that does not heat. . .what...
This could be two possible problems. The igniter maybe bad, but doubt it. The igniter works both the oven and broiler, I believe on this model. The first thing I suspect is the switch in your wiring harness. The harness has a switch attached to it for each manifold. The switch for your oven maybe out.
Go to this site for diagram of parts: https://www.maytag.com/digitalassets/MLPDF/Repair%20Part%20List%20-%20W10282172.pdf
Jun 18, 2011 | Maytag Ovens
Maytag oven, model MGR5775QDW The broiler will ignite as it should but the oven will not. The console shows no error codes. When the oven is turned on, the temp shows and remains at 100 degrees and no...
The problem is usually the igniter not reaching the correct amp draw .When the igniter does not reach the correct amp draw it may allow the gas valve to partially open or not open at all. The igniters are inexpensive and easy to replace. This video will walk you thru the correct procedure for testing an oven igniter. It may be a different model but the testing will be the same.You can also enter your model # for diagrams and illustrations of your specific model. Not all models are available. All parts come with installation instructions.
Dec 22, 2010 | Maytag MGR5775QD Gas Kitchen Range
The oven of maytag range mgr5775qdw poorly
The ignitors/burners need to be cleaned properly.
Build up of grease, dirt, rust, mineral deposits, etc can cause improper gas flow resulting in a delayed ignition. That causes a build up of gas and the delayed ignition ignites it all at once, and you have your WHOOMP mini explosion.
Sep 25, 2009 | Maytag Ovens
Why does the surface burners and broiler light but not the oven burner on my Kenmore gas range? Kenmore gas range around 14 years old the model number is 362.7352192. We were using the oven and in the...
The oven gas valve coil has failed Need to replace. Go to repairclinic.com and put in the model and order the coil for the valve. It controls the gas valve.
Sep 11, 2009 | Kitchen Ranges
Sawdust46
Aug 26, 2009 | Kitchen Ranges
Oven won't heat up at all.
broiler on top of oven?? if so it might have a second ignitor that is working. Most units now with gas have an electric ignitor to start gas ovens. What they do is send electric current through an electric "wire", when enough current is flowing through wire to open gas valve the wire is hot enough to ignite the gas flowing over it. When you turn on the oven look at the burner and after 1 imute or so you should be able to see an Orange glow in bottom of oven if not I'm sure its the ignitor, if glows then probably oven valve is bad. I'd guess ignitor because most oven makers use this ignitor to mantain a warming temp (around 100 degree's) so since your display doesnt register over inital "start" temp of 75, i'd bet ingitor not coming on at all
May 21, 2009 | Kitchen Ranges
Maytag MGR5775QDW-TOP works ,broiler and oven don't
If you have lp makes sure the tanks are fill and unit is converted to lp.Same goes for natural gas
Nov 06, 2008 | Maytag CWG3100A Gas Single Oven
Kitchen Ranges Logo
24 people viewed this question
Top Maytag Kitchen Ranges Experts
vince
gbob59
Are you a Maytag Kitchen Range Expert? Answer questions, earn points and help others
