Question about Giant Bicycle Inc. Cypress SX
Giant cypress sx shifter cable
How do I replace the shifter cable?
What year was a giant cypress bike serial number 6s762902 made
Google "Giant serial number" to see if a database is available. If not see my tip for other options. BUT generally year, model is not that important. How to determine the year value etc of your bicycle
Aug 11, 2017 | Giant Cycling
Giant Cypress DX. How do i remove the front tire?
unthread the axle bolt on both sides and lift it off the frame .
Apr 17, 2016 | Cycling
How can I tell what year my Giant Cypress DX bike is?
Made from 2009 to 2014. Have to ID by paint scheme, equipment, decals. Search model at BikePedia
Mar 19, 2016 | Giant Cycling
How do I change my right shifter?
It depends on how mechanical of a person you are. In simplest terms we'd unscrew the old one and put in the new one. Calibrate and then ride. Without model number or any other specifics we can only give you a general response.
For my bike, I'd change gears to the smallest gear first. Then I'd locate the screw holding the whole thing in place along the underside... unscrew. Then unhook the shift cable from the shifter. Then unthread that cable through the bike frame until I get to the derailleur. Remove / loosen the screw that holds it in place. Put the new shifter in place. Hook the cable back in. Change shifter to position of the current gear and thread the cable back through the bike to the derailleur. Slip cable back into place and tighten. Calibrate and ride...
Aug 30, 2015 | Giant Cycling
Creaking noise from handlebar stem on giant cypress bike
Hi Martin, I would suggest you ask them to check your headset as well, that could also cause the noise.
But if it is the stem, get some carbon paste from a shop and loosen your stem yourself, apply the paste thinly to all surfaces that makes contact and tighten it again.
That should keep it quiet, but something else to keep in mind, don't ever use high pressure cleaning equipment on your bike!
Dec 20, 2011 | Giant Cycling
(giant brass sx) its not so much as a problem as it is a question iwas wondering if i could convert it to a single speed
Any bike can be converted to single speed.
Any search engine answers how "convert to single speed mountain bike"
Aug 13, 2011 | Giant 09 Brass Sx Dirt Jump Freeride...
How do i lock front wheel axil
Web search "operate qucik release skewer"
Aug 07, 2011 | Giant Bicycle Inc. Cypress
How do you adjust the saddle down?
Loosen the bolt on the tube that holds the stem of the seat. The seat will adjust all the way down to the top of that tube. Bolt should be 1/2 or 9/16 or 12 mm
Apr 26, 2011 | Giant Bicycle Inc. Cypress LX
Giant Bicycle Inc. Cypress SX Logo
136 people viewed this question
Top Giant Bicycle Inc. Cycling Experts
Michial Gueffroy
John Egan
John Egan
Are you a Giant Bicycle Inc. Cycling Expert? Answer questions, earn points and help others
