Washes fine (agitates) but does not spin leaves cloths soaking wet.
can hear water pumping out.
model#atfb6000es1
I have a frifidaire atfb67007s0 baswment got 4 inch's water now the washer pump water but no spin circle
Ours still new..mind you....did the same thing and has done it again... so that makes twice and when we got the fridgidair person out it was just a clog drain pump. he cleaned it out then my dad cleaned it out the drain pump the next time.... so i am guesssing yours may be the same case.
Its the door lock error code 47
Looks like chat support session must have timed out. The answer to your last question was, yes, pres. analog switch with a red, a white, and a blue wire to it.
During our chat session, you never indicated the wash tub moved at all when it was time to spin, only that the machine did pump out and did not spin. Can not give out good help when full info is not disclosed. You'll have to find another helper, I stop helping when you lock in a thanks for trying. Good luck. Next time don't be so fast to lock in your rating.
Oh, and now you think all my efforts to date are inappropriate? I'll let you know that we experts are not employees of FixYa. We offer free advise to many many people, and low cost help to many others and do have other full time jobs we must attend to, so responses are often not as fast as you might expect. I did leave our original chat line open, waited for a half hour, then finally had to leave to repair a washer. When I got back, I saw you had posted and then closed the chat. Then you post a rating and change it twice? I certainly could give further advise, but why should I? It's not worth my time to attempt to help you any more. Call a local repair service if you can't deal with the constraints of FixYa or similar online help.
I see the chat session was rated helpful, which I agree is fair, but what I didn't like was the change from Thanks for Trying to FixYa and then to Inappropriate all within 24 hours on this thread http://www.fixya.com/support/t1177657-wa....
By the way, from what you have said and now checked, it sounds like you have a problem with the motor control board. Contact a Frigidair dealer to see if they can locate one for that model. (my parts supplier shows it as no longer available)
Thanks for changing your rating to a FixYa. Hope you are able to find a part for your machine. If not, look into the front loaders by LG, which are the highest rated by consumer reports and use a direct drive motor (with a 7 year warranty on the motor). Even their lower end machines are very good.
It can be the motor coupler, the coupler should be checked and eventually replaced.
Check also the lid switch.
See It pumps, but doesn't spin.
Two possibles here, if the drain pump is clogged and therefore the unit will not go into a spin. After pumping, it will error out and just shut off. If the pump is ok, then the motor control unit has failed.
THE SPIN CYCLE IS 12MIN LONG IT PUMPS WATER OUT FOR 4MIN THEN SPINS CLOCKWISE THEN COUNTER CLOCKWISE VERY SLOW FOR 2MIN THEN SHUTS OFF CLOTHES ARE STILL DRIPPING WET
My washer washes but will not go into spin cycle or drain the water. You can hear that it is trying to drain but then just stops. How do I fix this?
The water does not drain out leaves clothes wet, When wash cycle is over it sounds like it want s to drain but isnt draining, then will start to spin but not a fast spin. It will sit there and make a sound like it is trying to drain the ater out.
Washer will complete wash cycle, drains, spins slowly, but then shuts off.
it sounds like a problem with either the motor or the drivebelt.....Do you hear the motor speeding up as if it's spinning but the drum doesnt spin?, or is there no noise from the motor at all?
not spinning on 60 wash or 40 wash clothes soaking wet
The clothes are soaking wet after the warm wash cycle
