Question about Brother Sewing Machines
Brother lb6800 grinding noise and machine has frozen
  • terrie Feb 21, 2012
    The machine made a horrible grinding noise and came to a complete stop. The needle will not move up and down
  • Leigh Anne Peterson
    Leigh Anne Peterson Sep 12, 2013
    I'm having the same problem. Did you ever find a solution?
Needles hit the loopers making a grinding noise
Take it for a service and re-timing ...NOT a home fix
Apr 02, 2014 | Brother 1034D Mechanical Sewing Machine
Brother sewing machine noise
Sound like the whole unit needs a good cleaning.
My rule is "if it moves give it a lube", be careful not to get oil on electric boards or in the motor. What is the make and model of your machine. I will try to help you more.
Feb 26, 2013 | Sewing Machines
My lb6800 says raise pressure foot bar and it is, tried unplugging, nothing helps. It sews when embroidery unit not attatched.
it sounds like the sewing machine needs to be checked
to see if there is somthing wrong with the computer in the machine.
Nov 05, 2012 | Brother LB6800PRW Mechanical Sewing...
Motor makes a grinding noise
it sounds like the machine needs to be serviced at a sewing machine shop
May 24, 2012 | Brother CS6000i Computerized Sewing...
The machine is making a grinding noise and giving E6 error code. There are no threads in the machine and I have it open but cant find the problem.
I would call Brother at 1-877-276-8437, it may be a malfunction. They will be able to advise your where to take it for authorized service. Good luck
Oct 07, 2010 | Brother CE5000 Computerized Sewing Machine
Machine makes a loud noise and will not make stitches.
sounds like something is broken. best to get it checked out. take to the sewing machine doctor.
Oct 16, 2008 | Brother CS-8150 Computerized Sewing...
Sewing Machines Logo
70 people viewed this question
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
