Question about Frigidaire Washing Machines
Won't empty water
Model number fwt425rhs
2 Suggested Answers
MY REPAIRMAN
  • 61 Answers
SOURCE: water won't empty
IF YOU CAN HERE IT RUNING OR A HUMING SOUND MAY BE YOUR WATER POMP SOME THIG STUCK ON IT VERRY COMAND ON FRIGDAIRE.
Posted on Feb 22, 2012
Washer won't agitate with clothes in. Will agitate when empty with water
It's a whirlpool top load and 17 years old.
I checked the lid switch, water level switch and they are okay. I replaced the motor coupling. The old one was chewed up and crumbling.
When I put everything back together and turned it on to check if it would spin, I heard a buzzing sound and after a few minutes there was a burning smell.
What should I check to diagnose this problem? would help to have make or model numbers to show age of machine
Nov 26, 2012 | Whirlpool Washing Machines
Zanussi 1400 Front Loader: Machine washs clothes as per normal but does not drain the water and cannot go into the spin cycle. Sits there doing nothing then starts bleeping.
This is almost certainly a simple problem with your empty pump filter being clogged. The empty cycle is timed and if it can't get all the water out in time because the filter is blocked and slowing the empty down, then it will fail safe and won't step on to the final spin cycle with excess water in the drum. While it's trying to get the water evacuated, you will probably see the machine doing a slow tumble for up to 8 minutes and you may also hear the empty pump running too.
You need to locate and clean the filter. Depending on the model (You haven
Aug 30, 2011 | Zanussi Washing Machines
I have a stackable unit model numberltf2140fs2 it will not drain and go into spin cycle is there a strainer that needs cleaning how do iget to it
You need to locate and clean the filter. Unfortunately, on this model, it's in a horrible place!
Rather than try to describe it, if you go to the Sears Parts direct site and look at the diagram for the motor and tub at this web address:
http://www.searspartsdirect.com/partsdirect/part-model/Frigidaire-Parts/Washer-Parts/Model-LTF2140FS2/1428/0153200/R0906023/00003
You will see a diagram of the drum and associated parts. You can zoom in on the diagram. In the bottom right section of the diagram, you will see part number 41, the filter housing ad part number 40, the filter its self. You will need to:
Remove the clip (No. 48) that holds the housing to the empty pump
Remove the clip (also No.48) that holds the air chamber to the housing
Remove the clip (No. 42) that holds the housing to the drum
You should now be able to remove the filter housing and filter. Strip and clean it before reassembly.
If the above doesn't get you where you need to be, please come back to me with a comment and I will provide further assistance
Aug 15, 2011 | Frigidaire Washing Machines
Washing machine won't pump out to go into spin cycle is there a strainer that needs cleaning
You need to locate and clean the filter. Depending on the model (not familiar which with the model you mention) there is probably a round filter cap on the front of the machine at the bottom (It may be behind a small door or hidden behind a clip on panel on the bottom) Many models of this design also have a small hose to the right of the filter cap that you can pull out, remove a plug from and drain off any water in the filter before you remove the filter and get your floor wet, so take a look for this before you remove the filter and get soaked.
Model 57051A0ww does not drain (humming noise). Drains manually when hose lowered.
I'm not familiar with the model number and you have not supplied a manufacturer, however, this is almost certainly a simple problem with your empty pump filter being clogged. The empty cycle is timed and if it can't get all the water out in time because the filter is blocked and slowing the empty down, then it will fail safe and won't step on to the final spin cycle with excess water in the drum.
You need to locate and clean the filter. Depending on the model, there is probably a round filter cap on the front of the machine at the bottom (It may be behind a small door or hidden behind a clip on panel on the bottom) Many models of this design also have a small hose to the right of the filter cap that you can pull out, remove a plug from and drain off any water in the filter before you remove the filter and get your floor wet, so take a look for this before you remove the filter and get soaked.
Jul 18, 2011 | Washing Machines
LG washing machine fail to spin at end of the cycle
Jul 07, 2011 | Washing Machines
My machine does part cycle than all lights flash than when restart it will start washing but want go throw the cycles ie rinse spin drain
Teh make and model of the machine is important here, because WHICH lights flash and the number of times they flash is an error code taht we can look up if you tell us the make and model. However, from what you have said so far, this likely to be a problem with your empty pump filter being clogged. The empty cycle is timed and if it can't get all the water out in time because the filter is blocked and slowing the empty down, then it will fail safe and won't step on to the final spin cycle with excess water in the drum. You need to locate and clean the filter. Depending on the model (not familiar which with the model you mention) there is probably a round filter cap on the front of the machine at the bottom (It may be behind a small door or hidden behind a clip on panel on the bottom)
Jul 06, 2011 | Washing Machines
Spin part is not working
Not a lit to go on here. A model number would help a solution, but here is a generic suggestion I think will help:
This is potentially a simple problem with your empty pump filter being clogged. The empty cycle is timed and if it can't get all the water out in time because the filter is blocked and slowing the empty down, then it will fail safe and won't step on to the final spin cycle with excess water in the drum.
If I
Jul 06, 2011 | Samsung Washing Machines
Lg washing machine suddenly stop during washing
It would help to know at what stage the machine stops, however, lete me take a blind guess that it stops just before the spin cycle. If I'm guessing wrong, please tell us when the machine stops and if it displays an error code or any flashing lights (Please note WHICH lights flash and the number of times they flash, as this is an error code that will help pin the problem down).
If I'm right, then........
Jul 05, 2011 | LG Washing Machines
My LG washing machine model-fuzzy logic WF-s6607tc, is not spinning
The filter for your empty pump is probably clogged. The machine can't drain the water in the alloted time because it is draining to slowly through the clogged filter. The machine won't start the spin cycle if all the water hasn't been evacuated. You will need to find and clean out your empty pump filter (Probably behind a little door at the bottom of the machine.
Jun 23, 2011 | LG Washing Machines
Washing Machines Logo
16 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
