Question about SAMTRON 55V 15" CRT Monitor
15 pin VGA connector damaged.
My monitor is Samsung Samtron 56V. My 15 Pain D-type Vga connector is damaged. Please tell the color coding of the 15 pin Vga connector or anyone who can provide whole wire with its connectors.
  • 3 more comments
  • jitender Nov 13, 2007
    i want to know smtron 56v vga connector configuration
  • applebuddika Feb 28, 2008
    My Moniter is Samsung 56V.My Monitor VGA Cable is damaged.Please tell me to it colour code.
  • Anonymous Mar 01, 2008
    My monitor has problem in colour display from 1 month as my monitor wire has only 13 pin connector is it probelm in wire my freinds says that it should be 14 or 15 connector help me
  • Anonymous Mar 05, 2008
    i want color code fo 15 pin vga connector of 55v
  • ashuravi Aug 18, 2008
    MY 15" SAMTRON 56V MONITOR VGA CONNECTOR IS DAMAGE I WANT TO REPLACE IT ,SO PLEASE TELL ME PIN CONFIGURATION OF THIS VGA CONNECTOR.
I want to know that what is the color combination of vaga cable connector
Posted on Jul 10, 2009
  • 27 Answers
I will give the 15 pin color coding in a couple of days as i am not in the station. If you want it urgently try any samsung service centre(the address can be found on samsung website for your location) and may cost you approx Rs.500-800/-
Posted on Aug 28, 2006
    Problem Solver:
  • 3 Answers
Pin
Name
Function
6
7
8
9
10
11
12
13
14
15
RED
GREEN
BLUE
n/c
GND
RED_RTN
GREEN_RTN
BLUE_RTN
VDC
GND
n/c
SDA
HSYNC
VSYNC
SLC
Red Video
Green Video
Blue Video
not connected
Signal Ground
Red Ground
Green Ground
Blue Ground
5 VDC supply (fused)
Signal Ground
not connected
DDC/I2C data
Horizontal Sycn
Vertical Sycn
DDC/I2C Clock
Posted on Nov 27, 2009
My system is IBM p3 boot nahi karta
Posted on Aug 12, 2008
Viewsonic 15 inch crt monitor 6+7pin color code.
vga cable fail, colors change,
vga new 15 pin conect , pls send my emil id, please rectifie this problem,
krishna.bangaram@yahoo.com
Posted on Sep 08, 2010
Show vga pin ports image
Posted on Apr 25, 2008
4 Suggested Answers
SOURCE:
ErusTownsend
  • 592 Answers
SOURCE: VGA Cable disconnect form the
here is the basic vga pinout
Posted on Jun 29, 2011
Sahill
  • 23 Answers
SOURCE: monitor
SIGNAL CABLE WIREING.
1) RED
2)GREEN
3)BLUE
4)GROUND
5)BLACK SHIELD
6)BLACK SHIELD
7)BLACK SHIELD
8)BLACK SHIELD
9)BLACK
10)VILET
11)
12)ORANGE
13)SHIELD
14)YELOW
15)WHITE
Posted on Jan 24, 2008
  • 109 Answers
SOURCE: VGA connector wiring detail
Pink - red input - pin 1 green - green input - pin 2 blue - blue input - pin 3 ground shield wire - pin 6,7,8 and 10 black - ddc 5v - pin 9 violet - screen raster - pin 11 white - data or sda - pin 12 orange - clock or scl - pin 15 yellow - vertical signal - pin 14 clear - horizontal signal - pin 13
Posted on May 17, 2010
I have a Problem in vga cable of my Samtron 56V Monitor.. Pls tel me how to replace
connect another cable as follows
1-red
2-green
3-blue
4-gnd
5-gnd
6-red gnd
7-green gnd
8-blue gnd
9-+5v from display card
10-stand by
11-synchronus ground
12-sda
13-hsync
14-vsync
15-scl
the numbers of pin are given
under pin
May 20, 2010 | SAMTRON 55V 15" CRT Monitor
Shrinking of the display
The DB15 VGA (Video Graphics Array) connector contains however 15 pins in three rows of 5 pins each. These five pins carry the color and synchronisation signals, also a digital I2C interface for two-way communication between the video controller and monitor. The common 15-pin VGA connector found on most video cards, computer monitors, high definition televisions which support VGA connections. The following schematic diagram and table shows respectively connector and pin assignment of DB15 VGA.
Pin
Name
Function
6
7
8
9
10
11
12
13
14
15
RED
GREEN
BLUE
n/c
GND
RED_RTN
GREEN_RTN
BLUE_RTN
VDC
GND
n/c
SDA
HSYNC
VSYNC
SLC
Red Video
Green Video
Blue Video
not connected
Signal Ground
Red Ground
Green Ground
Blue Ground
Signal Ground
not connected
DDC/I2C data
Horizontal Sycn
Vertical Sycn
DDC/I2C Clock
Aug 10, 2009 | SAMTRON 55V 15" CRT Monitor
Monitor display in blue shade
It may be due to the loose contact of the monitor signal cable
Contact the nearest Repairman
Let me know that your problem is solved and rate me as Fixya!
May 27, 2008 | SAMTRON 55V 15" CRT Monitor
13pins "from the monitor" "to 15 pins VGA connector"
You will have wires of 7 colours. Solder it as per the data below...
White 7
Red 6
Black 10
Yellow 9
Blue 12
Green 1
Brown 13
The pins are numbered as follows
4 3 2 1
8 7 6 5
12 11 10 9
13
Apr 02, 2008 | SAMTRON 55V 15" CRT Monitor
Replacing vga cable
A VGA cable is a D-Sub 15 pin cable.
Connector information:
http://en.wikipedia.org/wiki/VGA_connector
Pinning information about midway down the page:
http://myhometheater.homestead.com/vgacable.html
Is that what you were looking for?
Mar 27, 2008 | SAMTRON 55V 15" CRT Monitor
Monitor
1) RED
2)GREEN
3)BLUE
4)GROUND
5)BLACK SHIELD
6)BLACK SHIELD
7)BLACK SHIELD
8)BLACK SHIELD
9)BLACK
10)VILET
11)
12)ORANGE
13)SHIELD
14)YELOW
15)WHITE
Nov 14, 2007 | SAMTRON 55V 15" CRT Monitor
Samtron 78DF signal cable conductors
This is solved by the author himself
May 30, 2007 | SAMTRON 78DF 17" CRT Monitor
SAMTRON 55V 15" CRT Monitor Logo
8,064 people viewed this question
Top Samtron Computers & Internet Experts
William Miller
William Miller
pankaj rautela
pankaj rautela
Richard Lilja
Richard Lilja
Are you a Samtron Computer and Internet Expert? Answer questions, earn points and help others
