Question about Epson TX100 Series
My epson tx110 prints fuzzy half way through printing. I have tried to align heads to no avail! What else can I do. I use genuine inks.
My printing is fuzzy half way and sometime all of the page. I have tried OVER and OVER again to head align but it is not working.
night71
  • 328 Answers
SOURCE: Print Head Alignment
Get the driver here:
http://www.epson.com/cgi-bin/Store/support/supDetail.jsp?BV_UseBVCookie=yes&oid=14428&prodoid=9935&infoType=Downloads&platform=All
Posted on Oct 29, 2007
Metawatch
  • 96 Answers
SOURCE: Epson Stylus CX6400
Blank pages are indicative ofdried ink.
If the printer has not been used for a long time ink may have settled and dried in the heads.
You may need to replace the cartridges (IF they are very old) and run several head cleanings if there is no improvement.
I typicall try to print a few test pages to see if some of the color work.
http://www2.clicshop.com/Stores/metawatch2/Files/metawatchprintertestpage.pdf
Posted on Feb 09, 2008
SOURCE: Lines on prints
Hi kids! I decided to have another go at sorting out my 'lines' problem and have sorted it. See if this might work for you: I had previously done the head cleaning via the printer itself - holding the central ink/paper black button for 3 secs. This time I went to the Epson 1290 window on my Mac and clicked on the utility box. Though the Nozzle check print came out fine I went ahead and did the head cleaning in this box. The next print came out almost perfect so I ran the Head cleaning again and it printed a perfect print. Hope this might work for you. Keep on trying! All the best. Trant
Posted on Mar 28, 2008
Basti
  • 1447 Answers
SOURCE: printing blank pages
hi-
You might be having a clogged nozzles, if you want you can try to dismantle and check on the nozzles, heres the link on how to check it just click HERE
Pls rate as fixya if it helps. Thanks!!
Posted on Jun 17, 2008
  • 4 Answers
SOURCE: Epson Stylus CX5000 blurry or smudged printing
epson uses pigmented ink and compatibles use dyes and thus if the paper is not of good quality then you can have this problem.
do the following
change the paper and try.
As there will be ink in the head and the ink feed tubes , print some 10 -15 copies of all color prints so that the original ink starts to get into the head and then the paper.
this should solve your problem
Also use your printer every 2 -3 days if you dont have any prints then give a noozle check and then switch off the printer. This will avoid the printer from doing a head clean very time you switch on the printer and also the ink will give you more output as there is less amount of head cleaning
bye
Posted on Sep 30, 2008
E02820 Adj. Failed - Irregular alignment pattern
YOU MUST BE USING REFILLED CARTRIDGES. AFTER A COUPLE OF REFILLS THE TECHNOLOGY USED BY EPSON IS "BUBBLE JET" TYPE WHERE THE INK IS EJECTED/SPRAYED ON THE PAPER. after CONTINUAL RE-FILLS THE NOZZLE OF THE PRINT HEAD WIDENS, THUS GIVING YOU SMUDGY/SPRAYED TYPE OF PRINTOUTSW
Dec 10, 2013 | Canon Office Equipment & Supplies
My epson stylus cx6000 has stopped printing black. I've cleaned the print head, changed the cartridge and it still won't print black. What else can I do?
Be sure you are using genuine epson ink. Epson printers are "smart" and will not allow generic ink to work properly. Even after you replace a generic with a genuine it may take several print outs and alignments to get it to print again.
May 05, 2011 | Epson Stylus CX6000 All-In-One InkJet...
Vertical lines when printing. Have genuine Epson cartridges installed and most are brand new. Have done a print head alignment and cleaned the nozzles.
You have a clogged print head. If repeated running of the head cleaning routine does not work, you can take a Q-tip and dip it in warm or hot water and gently rub it across the print head. You should see ink on the Q-tip. Do this a couple times until it appears that more ink is flowing then try the head cleaning routine again. This is a common problem when inkjets sit unused for awhile.
Mar 10, 2011 | Epson R1900 Printer
Epson Stylus C84 Fuzzy printing every five rows of
Try re-aligning the heads using the alignment software function
Jan 01, 2011 | Epson Stylus C84 InkJet Printer
Epson Stylus CX5400 will not print. This printer was unused and stored for 3 years. We replaced the ink cartridges and cleaned the print head and aligned the print head and ran a nozzle check. The printer...
Did you use Epson Genuine Cartridges? ALL…. Epson & Brother Requires Genuine Cartridges. !!!!!!!!You might have dried it up.
This is the only advice I can give you.
The next step would be to disassemble the Epson, and clean the Pads/Heads. Click on link below.:
http://www.hm2k.com/posts/parts-inside-your-printer-are-at-the-end-of-their-service-life
I located a page on http://www.fixyourownprinter.com forum, which had plenty of details about similar issues.
If you find this helpful, pls rate me.
Thanks and Good Luck :0)
Apr 11, 2010 | Epson Stylus CX5400 All-In-One InkJet...
Epson printer tx110 inkpad end its service life...how to fix this
ink pad end? end life? Reset waste ink counter using epson tx110 resetter.
Mar 18, 2010 | Epson Stylus Multifunction Inkjet Printer/...
Printer Epson DX6000 ... all new cartridges .... will not print any text. I can print the head clean test page as well as the head alignment page ... but no text
You said all new cartridges.. But are they Epson Genuine Cartridges???? I had the same problem when I replaced with new, but generic cartridges.
After finally, going thru 2 sets of each, removed them and put in Genuine., and finally, everthing started printing fine. Weird , but true.
I suggested my answer problem below.
Good Luck :0)
Problem for Epson Stylus C84 InkJet Printer
Re: C84 I'm using generic ink, but the red
By mclamemo on Nov 12, 2009 re: C84 I'm using generic ink, but the red doesn't work at all. I've done all the printer cleaning programs and swabbed inside the printer with alcohol, and re-inserted the cartridge multiple times. it still doesn't print at all.
Also now even the black every few lines prints the top half of the line or the bottom half of the line, or its smeared, etc...
Help!
Best Solution
posted on Nov 12, 2009
cns assoc
Rank: Wiz Expert
Rating: 84%, 22 votes
I have learned from experience, that Epson does not like generic ink. You must use Epson Genuine Cartridges. Hopefully, you haven't screwed up the printer, like I did. I did try cleaning the heads and doing everything possible. Use 2 cartridges of ech set, for cleaning, cleaning, cleaning. ......But Nothing.
Had to go out and purchase a new printer.;
Good Luck :0(
Asker's Testimonial
" Thank you. Called Epson also and they didn't say it as directly, but advised real Epson ink too. Hope I didn't kill the printer! Generic ink for sale " - mclamemo
Comments:
Nov 12, 2009
- Funny. hahahahah,
Me too! I would say, about 2 dozen cartridges to be exact.
lol :0) :0) :0
Nov 15, 2009 | Epson Stylus C86 InkJet Printer
Blurred and fuzzy print quality
i think you use a compatible ink... use genuine ink for epson ok...
Jan 04, 2008 | Epson Stylus Color 740 InkJet Printer
Oct 29, 2007 | Epson Stylus Color 440 InkJet Printer
Computers & Internet Logo
129 people viewed this question
Top Epson Computers & Internet Experts
teamtech
teamtech
Are you an Epson Computer and Internet Expert? Answer questions, earn points and help others
