Question about LG LSC27910 (265 cu ft) Side by Side Refrigerator
Ice maker make noise and back of freezer is frozen
TH ICE MAKER OR FREEZER WAS MAKING A LOUD HUMMING SOUND AND THE BACK OF FREEZER WAS FROZEN
  • 61 Answers
THE DEFROST CONTROL IS OUT MAY BE THE DEFROST BYMETAL OR A TIMER OD DEFROST HEATER WHAT BRAND AND SIDE BY SIDE OR TOP AND BUTTEM REF. AND AGE. WILL HELP
Posted on Feb 22, 2012
fridgetech
  • 473 Answers
SOURCE: Icemaker flap/door does not mechanically open
The description says you have an LG fridge?  I may need the entire model # from the sticker inside the fridge to tell for sure, but there is a motor behind the dispenser controls that opens the door.  Let me know if you need more help.  Also, you can view parts and diagrams at http://www.appliancepartspros.com/.
Posted on Oct 21, 2007
aborcass
  • 2651 Answers
SOURCE: Water freezing on the tray section under the freezer drawer.
sounds like you have a clogged defrost drain tube. removing back panel of freezer will give you acess to drain trough, melt away the ice with a hair dryer, youll find a drain hole under there somwhere,pouring boiling water down the drain will clear it pretty quickly( i use a steam machine purchased from the infomercials works awesome, after you clear it and all water drain down tube wrap a piece of solid copper wirearound the heater( black calrod heater right above the drain trough) and stick it in the whole maybe an inch or so. now everythime the heater comes on to defrost it will prevent the hole from freezing over
Posted on Mar 15, 2008
SOURCE: Ice maker
I believe the tube that pours water into the icemaker tray is clogged with frozen water and can not fill the tray and your fridge can not make ice. You have to unplug your fridge and let the tube to defrost. It is a long tube (about 1.5 foot) and using a blow dryer may not do the job. You can unscrew the the gray plastic cover at the back of the fridge and pull out the tube and let it defrost and then put it back.
Posted on Apr 26, 2008
  • 358 Answers
SOURCE: Ice Maker Problem with overflowing
When the ice maker calls for water it pours for about 7 seconds if more will overflow and the problem is in the ice maker board but if pours water for nomore than 7 seconds and still overflow it means that was extra water in the ice maker ,that means that the dual water valve(located in the bottom back of the refrigerator) is leaking and needs to be replaced.
Posted on May 02, 2009
SOURCE: ice maker not making ice
Water condensation freezes inside and mechanism gear inside can't move. I made an ugly hole at the bottom to let water condensation out. Never had a problem after that. See images below.
Posted on Sep 02, 2009
I have a ge adora fridge that when pressing the lever for ice makes a loud humming noise & feels like freezer wants to explode. Cab anyone tell me if they have ever run into this issue
You probably have a ice dam in your ice tray. The anger is trying to dispense if but if the cubes have frozen together and produced a large chunk of ice it cannot break up. Open the freezer door completely and lift up and pull out through ice tray. Remove ice until dam removed. Reassert tray and make sure to turn ice maker back on. It is essy to inadvertently bump switch. Try dispensing ice to see. If noise went away.
Hope this helped!
Apr 19, 2016 | GE Refrigerators
ICE MAKER NOT WORKING LBC22518WW (LG REFRIGERATION)
Hello, just like your problem, our ice maker just stopped making ice. We solved the problem by unplugging the refrigerator for about 2 hours leaving the freezer door open.
It started making ice a few minutes after plugging it back in. Obviously the line that supplies the water had frozen and this allowed it to un-freeze.
We didn't remove any of the frozen items in the freezer, at the two hour mark, everything in the freezer was still mostly frozen.
Thanks
Jul 13, 2010 | LG LBC22518 Bottom Freezer Refrigerator
The ice maker on my refrigerator has stopped making ice. Water is still flowing but the tray doesn't fill and the whole mechanism seems not to function.
Pour about 2/3 cup of water into the ice maker . If the ice maker dumps the frozen cubes , but doesn't refill with water , you should replace the water inlet valve , behind the refrig , where the wall water line connects to . If the Ice maker does not eject the frozen cubes , replace the ice maker .
Also , check the ice maker fill tube , from the back wall inside the freezer , to the ice maker fill cup , to see if it's frozen . If so , you will need to remove it , and clean the ice out . This would be caused by a " seeping " bad water valve also .
Check the coils under the refrig , to make sure they are clean of dust , lint , pet hair , etc , as this will raise the freezer temp above 5 degrees , which is the temperature which the ice maker needs to operate properly .
Oct 10, 2009 | Refrigerators
Whirpool Side by Side making loud humming noise from freezer side
I had the exact same issue last night. I would press on the back panel long enough and the noise would go away only to return this morning at 4am. I finally got up took all of the bins and shelves out and found an very large accummulation of ice at the bottom (floor) and walls of the freezer. The ice accummulation was causing the rattling of the tubes in the wall of the freezer (I don't know what you call them), but they were frozen over on one side. I found this out once I took the back wall panel off of the inside of the freezer. I also found the drain hole back there and it was frozen over solid, as well as my ice dispensing unit at the top of the freezer. This whole problem began when I turned on the ice maker 3 days ago. I used my hair dryer and hot water to clear all of the ice from both areas and now it is nice and quiet. Don't know if the acccummulation is due to some defrost switch gone haywire, but at least the rattling is gone and my freezer is back to square 1 for the time being and I saved myself a visit from the appliance guy in the meantime. Took me a total of 1 1/2 hours to do it all.
Aug 07, 2009 | Frigidaire FRS26R4A Side by Side...
AMANA ARB2257C ice maker makes noise/doesn't eject cubes into bin
Hi: First off make sure the fridge is level. Is It too high in front? Making the rear of the icemaker overflow and jam? Also make sure the freezer section is a zero degrees, not just frozen. Ice cream should be rock hard. I hope this helps you avoid calling service. Thank You, Jeff
Jun 13, 2009 | Amana ARB2257C Bottom Freezer Refrigerator
My GE side-by-side refrigerator is making a fairly loud ticking sound--about once every second-sounds like a big clock.
Water line to ice maker is frozen. Thaw out freezer. Put food in dry ice cooler and open freezer door, reset to OFF, and thaw freezer for four hours. It'll work after that.
May 23, 2009 | GE GSH22JFR Side by Side Refrigerator
Ice maker not making ice after replacing water line.
Ice makers are a common problem. On many brands there is a reset button behind the plastic cover. However if you physically see Ice clogging your water inlet to the ice maker, this will without a doubt prevent the ice maker from making ice. Use hot water or a steamer to unclog the ice or you can leave the unit unplugged for a few hours to defrost the freezer. You should be able to hear when the ice maker cycles and lets in water. Note: if you're getting plenty of water out of your in door water dispenser, then it's NOT a water supply problem. You may need to check the solenoid that controls water entering the ice maker.
Nov 29, 2008 | Refrigerators
Frigidaire side-by-side model # FRS26H5ASB4 making humming or buzzing noise
I had the same problem. I found the buzzing noise was caused by ice build up around the fan motor inside the freezer. I believe water must have leaked down around the fan during a defrost cycle. I removed the ice maker, the ice cube bin and ice dispenser auger motor. It sounds complicated, but it isn't too bad. The ice maker and auger are connected with quick connect plugs. So just unplug, remove the screws and remove them from the freezer. You will need to remove several other screws as well, I believe 11 in total as well as the top freezer rack. This will give you access to the white aluminum panel that runs from the top of the freezer to about halfway down the back of the freezer. After you remove the aluminum panel you will see the fan about half way down the freezer. I found a lot of ice around my fan. The fan blades were hitting the ice causing the buzz. Remove the ice and the buzzing is gone. It took me an hour to complete this repair. I hope this helps.
Nov 08, 2008 | Frigidaire FRS26H5AS Side by Side...
Humming in Whirlpool Side by Side Refrigerator
It is probably just your water inlet solenoid being activated. Not to be concerned.
Sep 26, 2007 | Refrigerators
Water Dispencer not working.
check your freezer for ice. do you have alot of ice in your ice maker tray? if so your water line could be frozen. try to self defrost the freezer for about 3hrs to thaw out the water line. check your water valve also. when you call for water do you hear a humming or buzzing noise? on ge fridges ive worked on if you hear a humming noise when calling for water, most likely your water valve is ok. trace the water. meaning where does the water start? at the wall then through a hose then to your valve which is behind fridge on bottom. trace the hoses and you will find the prob
Feb 09, 2007 | GE GSS20IEP Side by Side Refrigerator
LG LSC27910 (265 cu ft) Side by Side Refrigerator Logo
142 people viewed this question
Top LG Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
